Question about Microsoft Xbox 360 Console
Blank screen or a colored screen plus freezing. We took it apart, made sure the fans were running, put it back together, it worked for a couple of minutes and then back to the same.
  • 1 more comment
  • Anonymous Jan 06, 2009
    everything works normally as far as I can tell juat solid black screen I can hear it starting up but no video
  • quintonSR Feb 08, 2009
    Blank Screen when i Turn on Console. I can hear it but I have no video.
  • j88nya May 11, 2010
    are you using AV, HDMI, or Component connection?
    Sergeant:
    Champion:
  • 378 Answers
We can fix this for you email if interested
xbox360fixer@verizon.net
Posted on Jan 06, 2009
Marcy Upright Fan Cycle - Fan Hitting Cage As It Spins
You did great with the assembly, however, you're off on the alignment. Try to adjust to pull the axle in the opposite direction to clear the cage.
Nov 11, 2013 | MARCY MCPL 105 Upright Fan Bike
I have a Compaq presario sr192onx with an Asus A8N-LA motherboard and an AMD Athlon 64 +3500 processor. I took apart the fan and heat sink so I could read my serial number on my processor, and now after...
Try making sure all of the plugs are connected properly (some may have moved during) hopefully you haven't unseated the processor but just repeat process sometimes that fixes the problem. But to me sounds like a connection issue between either graphics card(if you have one) CPU, Power Supply Unit and motherboard
May 04, 2017 | Computers & Internet
I took my Samsung HLN507W apart to replace the color wheel fan... is there a schematic somewhere in the TV or online so I can now put it back together?
You Tube have video by somebody take out the old colors wheel and steps by steps and a replacement of a new colors wheel put into the DLP tv.
May 08, 2011 | Samsung HLN507 50" Rear Projection...
On my 60gb ps3 I was having problems with it freezing after 10-15 mins of gameplay on the loading screens, I have had it since around 2006 so my warrinty was up. I took it apart and cleaned all the dust...
Hi Max,
If your PS3 is freezing up then you need to stop the heat build up internally and to do this you will need to get it repaired.
Now you can send it in and they will fix it for you that is the standard method however bear in mind that there will be a repair charge of $150 for the fix which is quite steep!
The other way that you can fix it is by using a good PS3 Repair guide.
Just a quick word of advice though, make sure you check out these reviews of the top guides so you can be sure what they offer.
Click Here To See PS3 Repair Guide Reviews
Hope this helps.
Mar 31, 2011 | Sony Playstation 3 (PS3) Console
EMachine e627 screen blank
I am assuming you have plugged the screen into a known working power source. You have pressed the 'on' button to turn the screen on and you have hooked up the screen to the back of the computer. What I need to know is if when you power up the computer if you see any text at all from the post AND if you see any lights on the front of the screen itself. (most all screens have lights on the front of them to tell you they are turned on, and most of the time the light is green). If the screen is on but is getting an orange or amber light that means something. Also if you see text or something on the screen initially but not in windows then it could be a resolution or driver issue.
Jul 07, 2010 | Acer Computers & Internet
Took apart, cleaned fan, put back together. plugged in. 3rd light from left comes on briefly then goes out. no other lights on.
Did you make sure that you put all the plugs back in the proper places? One wire not plugged in will make it not work.
Nov 27, 2009 | Dell Vostro A860 Notebook
Computer screen goes blank after a couple of seconds
the back light of my hp w1907 will only come on for a second than go back off?? the rest of the monitor is working can see the image if you shine a light on the screen ..any help??
Comments: Oct 26, 2009 - so this monitor was not in warranty so i took it apart i found a wire broken off one of the backlight bulbs, ( be very carefull the bulbs all four of them and the lcd screen are very very fragile ) so i soldered the wire back on and put it back together and rechecked it it has been working like new
Nov 24, 2009 | HP w1907 LCD Monitor
Fan keeps cutting off after being taken apart and cleaned
If it was wired wrong it wouldn't run. I would suspect uneven tightening of the motor screws.
Aug 08, 2009 | Patton Electric U2-20 Box Fan
The ON button is the only button that responds. Which means that once it is on I cannot press "2nd" and then ON because the ON button is the only button that works. I need to take off the batteries so the...
I fixed my calculator, but i am not sure how I did it. I just took it apart, put the circuit board to a fan, wiped it, and put it back together. Then when I turned it on I pressed "2nd" first then it started working.
Jul 13, 2009 | Texas Instruments TI-84 Plus Silver...
Patton U2 1887 Fan Won't Run After Cleaning
Do you have the cover back on unit tight has a button that kills the circuit when cover is taken off. Be sure it is on. Get back with me if that isn't it. ken
May 02, 2009 | Heating & Cooling
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
