Question about Canon Rebel XT / EOS 350D Digital Camera
Can't download pictures.
Connected to computer but not getting "Found New Hardware" message. Hear the beep to tell me I'm connected. I am concerned I have previously disconnected incorrectly. Could I have damaged the camera????
This may not be a solution for you but I had the same problem and solved it like this. First go to Canons Rebel XT download site (do a google search on canon rebel downloads and it's the first hit) Then choose your OS (Operating system) in the pull down menu. If it's XP then the first download you'll see on the list is for WIA560EN.exe which is the drivers you need. (if it's Vista it's VU600EN.exe ) Install whichever drivers you need and make a note of where your computer has stored it. In my case (XP) it was a file called EOS 3KRN in the Canon folder.
Now connect the camera to your computer and go to Control Panel and select 'Add Hardware'. The camera should show up with a yellow question mark on it. Go through the 'install new hardware' process and choose (I can't remember the exact words) 'I know where the files are located' or words to that effect. and 'browse' when it wants to know where the drivers or disk are located. When it asks where the drivers are located choose browse and go to My Computer, then C drive, then Program Files, then Canon, then EOS 3KRN (or whatever your downloaded drivers were called depending if its XP Vista or Mac etc) Choose this as the file Windows needs to look at to find the drivers. After a few seconds it finds the drivers and installs the camera drivers correctly and your camera is now ready to work with the computer. That's it.
It looks quite complicated written down but it's not that difficult really. Hope that helps :) If you're confused by the directions I'll try to make it clearer
Posted on Jan 15, 2009
Our computer monitor is not coming up. how can we tell if the monitor is bad or something else is wrong?
The most obvious way to tell is to swap out the monitor. If the new one works, the old one probably has a problem.
When you say "is not coming up" I assume you never see a thing on it. I would ask--do you hear the system beep once indicating that it has passed the POST? If not (and it always did), then I would suspect that since it hasn't passed its own diagnostics, you will never get a signal on the monitor.
I suggest disconnecting everything on the computer but the video, memory, and CPU (you can leave the mouse and keyboard connected).
If the system starts and displays something (most likely you will see a message indication no boot device), then you can assume you have a problem with a piece of the hardware.
Also, if you hear a series of beeps, they will help you troubleshoot.
Jul 12, 2010 | Samsung SyncMaster 953BW 19 inch Monitor
Computer don't recognize the Canon EOS XSi
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 21, 2009 | Canon EOS Rebel XSi Digital Camera
Just beeps at me not hooked up to usb port but is.I cant find the disc that came with printer. downloaded some drvers from dell, but they tell power must be on and connected with usb port.Printer is on and...
unhook the printer from the computer. install the drivers and then hook up the printer. They should self install.
Does the computer tell you it found new hardware?
Jul 07, 2009 | Dell Photo 964 All-In-One InkJet Printer
Wharfedale MP3 player won't install to IBM Thinkpad
Feb 12, 2009 | IBM ThinkPad T40 2373 Notebook
I get one long beep and one extra long beep on startup. Computer just beeps and nothing else.
The computer POST (Power On Self Test) tests the computer, insuring that it meets the necessary system requirements and that all hardware is working properly before starting the remainder of the boot process. If the computer passes the POST the computer will have a single beep (with some computer BIOS manufacturers it may beep twice) as the computer starts and the computer will continue to start normally. However, if the computer fails the POST, the computer will either not beep at all or will generate a beep code, which tells the user the source of the problem.
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
you can determine the meaning of your beeps finding out with your BIOS System installed on your machine.
Usually you probably have some memory problem.
Oct 26, 2008 | HP Computers & Internet
Mobile service
use window xp operating system.
procedure to connect:
connect usb cable to computer.
once you see message new hardware found. press to detect the system automatically.
wait for min. of 15 it will show a message that.
this hardware is not supported.still if you want connect.
press yes.
see whether new drive has been attached or not in my computer
Jul 23, 2008 | Handmark Software MobileLists (950142) for...
Hi, In dowloading picture it must be in play mode to detect camera by your computer try it now , insert usb to camera and computer you can hear alert beep , the downloading icon will appear either from operating system or cd supplied by camera. , just follow instruction
Jan 06, 2008 | Canon PowerShot A560 Digital Camera
Have a loner camera while mine is in repair. Can not download pictures. have usb cord. Camera in repair is Cario also.
try it at the pc level...go to "My Computer" icon and then search for your connected camera as possibly a new pc drive. then double click it and you should see a list of pics on the camera
May 25, 2007 | Casio Exilim EX-Z120 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
165 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
