Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage will open from remote in car, but wont close?
This just started a couple of weeks ago, and it is true with both my wife's car and mine. The garage will open fine when I hit my in car remote, but the garage will not close with the remote.
We have to get out of the car and manually push the button in the garage.
Any suggestions?
Thanks in Advance
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Check the photo eyes for alignment.
Posted on Jan 06, 2009
Craftsman garage door opener. Why won't it pair with remotes?
If the remotes operate with no problem it's not the board. once you've paired the remote to your home link in the car, you have to go back and hit the learn button on the motor housing unit then go back and hit the home link button you just paired. Keep in mind when you hit the home link button, you should with a firm 3 second push. If that doesn't work it's one of two things. First is all three buttons may have been programmed on the visor not allowing you to reprogram. You would have to wipe out the programming by holding the first and last buttons simultaneously until the light flashes rapidly. Then start over. Secondly it could be the radio frequency. Depending upon the year of the vehicle you have and the opener you have there's a difference in the megahertz. I hope it's as easy as my first suggestion. GL!
Jan 23, 2016 | Building Materials
Lift master formula I will not close, only goes half way down, but fully opens. Worked fine until my wife closed the door on the car, after that it would fully close
I had this problem as well with the door opening just fine but was not closing when using the remotes or when breifly pressing the wall mounted control. The door would close only when using the wired wall mount control. I have experienced this problem with other garage door openers I've had in my previous homes and it was always caused by sensors at the bottom of the door tracks being either misaligned or the lenses were dirty. In this case, and it was just a moment ago today, I simply cleaned the sensor lenses and then the door began to function properly. Give it a try.
Jan 28, 2013 | liftmaster Chamberlain Garage Door Opener...
I installed a Craftsman garage door a couple of weeks ago and all of a sudden it keeps opening by it's self. It is model #139.53918D what is causing this?
Make sure the door isn't closing too far. This will cause it to open. Your opener comes with a warranty. Call Sears repair.
Sep 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
The range for the remote openers (4) for mu Liftmaster garage door opener has decreased to the point of having to be within 6 feet of the door to open it. The liftmaster was installed 5 yrs ago. The...
There is an antenna extender kit available for your opener. The part number is 41A3504 and should be available from any good door opener company that handles Liftmaster or Chamberlain. It should come with instructions.
Jul 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have an older Craftsman GDO setup. 2-3 button remotes,a manual hardwired push button operator and my wifes' car has been successfully liked to operate the opener as well. Up untill just a couple of days...
I suggest you look for a Chamberlain dealer in the yellow pages and explain what you have. You are looking for a 'universal receiver' that will work with what you have.
Mar 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener intermittently not closing
A couple things to check and do. If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit if necessary.
If the main light isn't flashing it may just be a simple adjustment. Locate the 'down force' adjustment on the rear of the motor unit near where all those white wires go. Increase this about 1/4 turn and try.
For the light you should unplug the unit and then using a small screwdriver pull out on the center contact in the light socket.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless keypad closes door but won't open door. Just started this about a week ago. I replaced battery, still no luck. Car remotes work fine.
You keypad has lost signal strength. It has enough to work when the door is open but not enough to penetrate the door. A replacement is needed.
Oct 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
111 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
