Question about Dell E177FP LCD Monitor
Dell E177FP monitor won't turn off in power saving mode
My Dell E17FP monitor won't turn off in power saving mode. The screen just turns solid colors. Yellow to green to red and so on. I have had this monitor for years and it has always worked fine but I moved it to a different PC and this problem started. I updated the driver but still no luck. Any idea's?
  • 2 more comments
  • yhen_25 Jan 25, 2009
    My Dell E17FP monitor won't turn off. The screen just turns solid colors. Yellow to green to red and so on. I have had this monitor for years and it has always worked fine. Sometime when the screen saver appear, after a couple of minutes the screen turns to solid colors again. Please help me with this problem....
  • Anonymous Feb 04, 2009
    the only visual i get is in power saving mode.kindly help if u know of the solution
  • Anonymous Feb 28, 2009
    Monitor starts changing colors when going into sleep mode.
    can't turn it off.
  • Anonymous Apr 19, 2009
    Same problem afrer power cut.
    Will try suggested solution later and report
I had the same problem and I went to the first button on the monitor to the left(main menu) then with the button to the right (-) I scrolled down to factory reset. I also did the osd setting and I'm not sure what fixed it, but I havn't had the problem sence.
Posted on Feb 28, 2009
  • 3 Answers
I have the Dell E156FP and have been having this problem. I have found (after much fiddling around) that you can fix this quite simply.
If you get the screen functioning (turn on with your computer) and go to the menu (button at the bottom of the bezel), go into factory reset and go into factory reset within that menu. A blue screen comes up and there is a timer at the bottom; go to reset timer and exit the menu.
Now the screen will turn off and you wont get a disco everytime you go into standby or turn off your PC!
Posted on Apr 27, 2009
    Problem Solver:
  • 5 Answers
Press the Menu button on monitor,press the plus button ( + ) on the monitor til it comes to "factory settings" Press the monitor menu button again,press the plus ( + ) to go to "all settings. press the monitor menu button once more and it should fix your problem,it did mine.Power button fades from green to amber like before.
MikeR
Posted on Sep 02, 2009
What is the number of the power board
Posted on Feb 01, 2010
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
We have rolled out Dell Optiplex 790 machines running Win XP and using E2210 monitors. Recently networking applied power managment options to power of the monitors in 20 mins of inactivity. The monitor...
Turn off power saving mode in your monitor. In monitor beside orange light there will be a menu button press it and find for power management ok it turn of power management. The problem will be fix.
Sep 13, 2017 | Dell E2210 22" Widescreen Flat Panel...
When turning on the computer from standby the computer turns on fine however the screen remains black and the power light is green. I need to reboot the system altogther in order to get the screen to boot...
Please update the drivers for your computer from support.dell.com and also update your windows. This problem should get automatically rectified after the update.
Feb 03, 2011 | Dell E177FP LCD Monitor
Dell monitor E177FPc - light comes on green but immediately turns steady amber and screen is black. this has happened before and I can't remember how we fixed it.
Dell monitor E177FPc - light comes on green but immediately turns steady amber and screen is black? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1742SED2H 715G1492 2 FR Dell ADTV1742SED2H Power Supply Backlight Inverter...
Nov 15, 2010 | Dell E177FP LCD Monitor
Before Windows can boot-up the screen turns solid blue & a Dialog Box state "Entering Power Saving Mode". The screen then appears that the sleeping mode has occurred.
just switch off and switch on the monitor or press any button on keyboard to bring monitor from power saving mode thats all
Sep 23, 2010 | Dell E207WFP LCD Monitor
I cant see colors red l
recheck the signal cable,
each pin on the cable carries a differant signal some just a clock some instructions for an entire color. check to ensure a solid connection on both ends of the cable and that the video card is secured in the machine.
if still no red then replace the cable, best buy 5-10 bucks saves you from buying a new monitor in frustration.
still no red replace the monitor.
Jun 11, 2010 | Dell E177FP LCD Monitor
I have a dell monitor model e177fpv. It is stuck in power save mode. What do I do?
I have worked a great deal with the Dell E177fpv boards and when it is blinking power switch then it's bad. Most the time it's the C204,and C203 compositors that are bad (100uF 10v), and 70% of the time the C159,C154 ( 470 uF 25V are bad as well. now i have replaced them many of time and it had came back to life. i have also found other caps bad on it as well. i know you can order a new board for $39.00 and here is the link. http://www.lcdrepair.us/e177fpv_inverter-power.html
Dec 08, 2009 | Dell E177FP LCD Monitor
LCD Dell Monitor displaying purple and green rather then picture.
sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
Jul 11, 2009 | Dell E177FP LCD Monitor
Dell monitor E177FP LCD Monitor
This is normal, typically you must press the power button (on the monitor) to turn it off.
Mar 09, 2008 | Dell E177FP LCD Monitor
Dell E177FP LCD Monitor Logo
2,674 people viewed this question
Alun Cox
