Question about Seagate Momentus 4200.2 (ST9808210A) 80 GB Hard Drive
Hard disk not getting attached with Linux
Hi, I tried to install Red HAt enterprise Linux ver5 and Fedora core 5 in my laptop but the installation program doesn't detect the harddisk....it says " no device found,select driver"....it works fine when i load windows.....pls help me out.. thanx
  • 385 Answers
Hi, I'm not too keen on Linux but I found this website that might help you. http://rajibchy.tripod.com/ Check it out.
Posted on May 25, 2007
What version of Linux runs on DL580 G4?
Minimum Supported Red Hat Updates •Red Hat Enterprise Linux 5 Update 1 •Red Hat Enterprise Linux 4 Update 5 6-Core/4-Core Intel Xeon Processor 7400 Series •Red Hat Enterprise Linux 5.22 •Red Hat Enterprise Linux 4.7 Minimum Supported Novell Service Packs•SUSE LINUX Enterprise Server 10 SP1•SUSE LINUX Enterprise Server 9 SP31 6-Core/4-Core Intel Xeon Processor 7400 Series •SUSE LINUX Enterprise Server 10 SP23 •SUSE LINUX Enterprise Server 9 SP44
Nov 28, 2012 | HP Compaq ProLiant DL580 G4 (430811001)...
How do i install a software on red hat enterprise linux
Software on Redhat linux is delivered as RPM packages. you can install these via the internet if you have the YUM utility installed.
May 25, 2010 | fedora Linux Operating System
How to download and install apache on linux5
Hi Follow the below procedures.
How to install and start the Apache or httpd service under Linux
by Milind
Q. How do I install and start the Apache or httpd web server under Fedora core or Cent OS?
A. Apache HTTP Server is a free software/open source web server for Unix-like systems and other oses.
Apache features configurable error messages, DBMS-based authentication databases, and content negotiation. It is also supported by several graphical user interfaces (GUIs) which permit easier, more intuitive configuration of the server.
Use rpm command to install Apache under Linux. You can also use up2date or yum command to install the same.
Task: Install Apache/httpd under Fedroa Core/Cent OS Linux
Type the following command if you are using Fedora or Cent OS Linux:
# yum install httpd
Now, start the Apache/httpd
# chkconfig httpd on
# /etc/init.d/httpd start
Task: Install Apache/httpd under Red Hat Enterprise Linux
# up2date httpd
Start the Apache/httpd
Task: Debian Linux httpd/Apache installation
Use apt-get command:
# apt-get install apache2
# /etc/init.d/apache2 start
Task: Verify that port 80 is open
# netstat -tulpn | grep :80
You can also install httpd from CDROM with rpm command:
# rpm -ivh httpd*
Configuration
Your server is started but you need to configure and use Apache as per your requirement. /etc/httpd/conf/httpd.conf (RHEL/Cent OS/Fedora Core Linux) or /etc/apache2/httpd.conf (Debian / Ubuntu Linux) configuration file. Use text editor such as vi to edit file. This file is very well documented or read official Apache configuration documentation for more information.
Dec 30, 2009 | Red Hat Enterprise Linux ES 3 Standard...
How can i install red hat linux on my hp laptop
Actually, Red Hat Linux is now only an Enterprise Level Operating system. Fedora on the other hand is sponsored by Red Hat and is much better suited for a personal computer. Just head over to fedoraproject.org and download the Fedora 10 ISO. Then burn it to a CD and reboot your computer. It should boot automatically into Fedora.
Hope that helped!!
Mar 07, 2009 | HP Pavilion dv4000 Notebook
Linux Installation problem
Hi!
you have to delete your hard drive partition....
Than you can easily installed any linux in your notebook....
Feb 15, 2009 | Acer TravelMate 2300 Notebook
I want to install RHEL3.0 in SATA DeskStart HD using MSI SATA MB, but not detecting at OS installation time. HOW i can detect, Pls help me!!!!
You need to create a space for which to install Linux. That likely means resizing Windows. Partition Magic is a good Windows utility to accomplish this, although there is a Linux version called Gaprtedthat will do essentially the same thing. You download the Gparted live cd, burn to disk, and run it from your computer. You must go into "setup" and set your Bios to boot from CDROM before booting the Hard Drive. Once booted, follow the on screen instructions. Resize Windows, (but NOT before a thorough defrag of your Windows drive), and create a "blank space" for Linux. Afterward, boot your Linux distro, (RedHat 9 was a great distro, but a newer version of a Red Hat based distro would serve you better, sayCentOS or Fedora Core), and follow the online instructions. Good Luck!
Sep 25, 2008 | MSI 945GM2 H-F (816909015911) Motherboard
Redhat es5
This model was found not to be 64bit but 32bit.
May 18, 2008 | HP Compaq ProLiant DL380 G4 Server
How i can install linux on hp dv2519tu laptop.
i think the cd from which you are installing might have got scratched so the cdrom couldnt read some files which are needed for installation ... so i suggest you to try changing cd....
there is no problem with installing in laptops we can install linux in any laptops......
i suggest you to install fedora core instead of redhat...
fedora core has good functionality and it has inbuilt firewall security also for internet and it has got good options ... so try installing fedora core 5,6, or 7 .. if you dont have means you can download from net as linux is open source to all any1 can download from net ...
there are many other linux available like ubuntu,suse, mandrake etc....
suse linux is also very good it is the very user friendly linux ...
there other linux which can be run by cd only which doesnt need of installing it just like knoppix live cd etc....
be care ful while partitioning if you make mistake you will lose all datas ....
Feb 08, 2008 | Computers & Internet
How can i installed driver of sata hdd for linux red hat
if you are installing red hat 8 and higher there is no need to install extra driver because linux is the only operating system which will install everything including drivers, office suite,programming tools etc .... as far as my suggestion dnt install old versions of linux instead install new version ... there are many linux available
ex: fedora core 4,5,6 ,knoppix live cd linux ( which boots linux from cd no need install it) ,ubuntu,red hat,mandrake,suse ....
you can download it from net 4 free as linux is open source 4 all ...
be careful while installing linux especially during partitioning..... if u make a mistake you will lose all datas
Feb 04, 2008 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Seagate Momentus 4200.2 (ST9808210A) 80 GB Hard Drive Logo
183 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
