Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
Self propel belt is too tight to put back on
I cant get the self propel belt back on my sweeper. please advise
  • 294 Answers
The best way to install it is to put it on the motor shaft first and then to start putting it on the large pulley at the top and roll it on these belts can be hard to put on.
Posted on Jan 22, 2009
Need belt 38528- brush belt
belts will stretch when they slip. There no adjustments on beater-bars. The way to prevent this is to have a height adjustment to be high on high pile and low for low pile rugs.
Oct 28, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Install self propelled belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=647063
Generic problem for all Vacuums
Posted by wmtp on Jun 04, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually the self propelled vacuum have 2 belts and you should replace them both 2 the same time 1st the self propelled belt and then the brushroll belt. Normally you would hook the belt on the pulley side of the brushroll or self propelled unit and then stretch the belt onto the motor pulley side of the motor using a belt puller or a screwdriver with a bend on the end for pulling and or stretching either belt onto the motor pulley. If you have a problem please feel free to contact your local vacuum cleaner dealer.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 02, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
Brush won't turn and self propel doesn't work
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=619779
Brush won't turn and self propel doesn't work (by 2 users)
Posted by brucelk on May 24, 2008
I have replaced both the v-belt and the larger belt with Hoover brand belts and the brushes still don't turn properly and the self-propel function doesn't work. It seems that when I lower the handle all the way down toward the floor it works fine, but no one can vacuum this way. Is there an adjustment to belts to tighten them up? Otherwise I have to get it in to the only repair shop in town which is an hour's drive.X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by chartsell, posted on May 29, 2008 I have replaced both the belts as well. I have tightened the screws as someone else as suggested. The brush still will not turn unless you lower the handle almost to the ground. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 Windtunnel Vacuum. It is not so much the belts, the 2 belts are only part of the solution. The average belt change is every 4 to 6 months as a rule and to change them @ the same time. The Hoover Self-Propelled works on when the handle is lower to a comfortable position then the self-propelled drive may just need and adjustment. There is a self-propelled rod that controls the self-propelled feature and it either needs adjustment or replacement or the part that hold it may be broken but either one can be fixed. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Self-Propelled WindTunnel by Hoover U6445906
· Sometimes grabs the carpet for no reason.
· Comes back too fast when I push it back.
Self-Propelled WindTunnel by Hoover U6445906 Without knowing the brand name or model number you may have the height adjustment to low and the vacuum will say “bite down” on the carpet of which will make the belt burn and might leave marks on the carpet – and if you have a self-propelled vacuum it does come back fast if you because you have a transmission just like a car and you have to control the speed of the vacuum or because it may have a weak belt the vacuum will pull back easier – I really would like to know the brand name and model number so that I could accurately give a better answer . Recommended belt change for flat belt(s) are 4 to 6 months for better cleaning and one a year for a geared belt – both can stretch and lose their cleaning function
Apr 05, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
