Hello we have a Infocus Scren play 5000. We just replaced the lamp and now we can not get it to project. It also will not turn off unless we unplug it from the power source.
Have you reset the lamp timer by pressing both of the brightness buttons at the same time it worked on our infocus litepro 720
Posted on Jan 06, 2009
Hello I have the infocus screenplay 5000 projector & after reading all the posts here decided I dont have a similar problem to anyone else. My bulb life expiration came up months ago but the unit works...
working with expired lamp can cause the overheat, and the power supply will be damadged, you need to replace the chemical caps at secondary parts as shown in the picture below:
Feb 11, 2014 | InFocus ScreenPlay 5000 Multimedia...
I have an InFocus Screenplay 61 in. DLP TV. For most of the time, it won't turn on except for the blue buttons on the TV itself. Sometimes, however, the TV would work for a couple of minutes completely...
The tv projection Lamp inside tv now like 1 1/2 or 2 years already?Tv on and in used every day 4 or 5 hours every day?Yes,this problems,the tv projection Lamp live are ending.Replacement of the tv projection Lamp,tv will work again.
Jun 07, 2011 | InFocus ScreenPlay 61" Rear Projection...
Infocus sp5000 wouldn't turn on. i replaced the bulb & it worked fine yesterday...today it won't turn on again. i screwed the lamp cover back on tight so don't think it is that.
take the lamp cover off.
get a toothpick and push it down where the cover operates the swicth and check that it clicks on and off properly.
check the air filter cover as well
Mar 03, 2011 | InFocus ScreenPlay 5000 Multimedia...
I have an Infocus 5000 projector that we have just tried to replace our 2nd brand new lamp. Each time we attempt to replace the lamp we get no picture and the red light blinks once so often. At first when...
be sure and reset the lamp hrs. But you really need to make sure you haven't pushed the lamp connection in the lamp housing out of its cubby hole. I've seen this alot, the connection gets pushed in and when you think you have the lamp in, it's not really connected. Really the only way to check this is to remove the top cover. Before you do this though, one other thing that can happen is the lamp door gets mishapen due to the heat from the lamp and can cause the thing that pushes against the safety switch when the door is on not to depress it fully. you can power the unit up while holding the switch in with something non conductive to see if it is in fact the lamp door. anything beyond this is likely the power supply/ballast being defective, or the blower fan in the right rear of the unit not working.
May 21, 2010 | InFocus ScreenPlay 5000 Multimedia...
I start up my screen play 5000 and no startup menu appears or no picture, the lamp is working as the projection is white only. What is wrong. Regards: Shane Cook
The Projector was sitting unplugged for about a year, after having the projector plugged in for a while I disconected from the power for about a minut and then plugged the power back in.
I guess the battery within the Projector had no power.
Regards: Shane Cook
Jan 17, 2010 | InFocus ScreenPlay 4805 Multimedia...
I replaced the bulb on my InFocus ScreenPlay 5000. The unit turns on the picture is showing a little green while the light warms up. After about a minute, the light turns off but the project remains on as...
there is an issue with the lamp ballast. probably needs to be replaced. send it in to an infocus service center. try av solutions in ny. they're really good.
i think it's www.avsolutionsny.com
Nov 23, 2009 | InFocus ScreenPlay 5000 Multimedia...
New lamp, no power!
if there are no leds lit, i'm surprised that it powers up. but if there is no light when the fans are running, it may be the ballast that needs replacing.
Oct 14, 2009 | InFocus ScreenPlay 5000 Multimedia...
I have an Infocus SP5000. The unit turns on,but
I use an infocus for my church. I don't believe there is a counter shut off, or a reset that would revent the light from operating. I sugest you go ahead and replace the lamp.
Aug 17, 2009 | InFocus Televison & Video
---------->> My Infocus Screen Play 4805 -Popped*
Hello David,
The best way to find the best price is to do some hunting/research. Google "infocus 4805 lamp"
and wade through to find the best price.
You will find instructions on the lamp replacement procedure in the manual. If you dont have the user manual browse to www.projectorcentral.com and search infocus 4805 and on their spcifications page there is a "user manual" Acrobat PDF icon.
click on the icon to open the manual in pdf format
Take Care!
Jun 17, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus LP725 projector
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
May 25, 2007 | InFocus LP725 and LP735 Replacement...
324 people viewed this question
jasbo
jasbo
