Question about Apple iPod nano
Ipod nano wont connect to pc
Ipod nano 16GB Silver. connect to computer via usb , ipod says connected, diconnected, ok to disconnect. alternates repeatedly. USB port(s) recognize device for a second then don't recognize, alternates repeatedly. ipod works on daughters friends computer. Have updated drivers, gone to apple support, downloaded latest version of itunes
  • fiforever Jan 14, 2009
    I have a Gen 3 Nano, and mine does the same thing. I've tried resetting, going in and out of disk mode...but nothing works.
  • Anonymous Mar 22, 2014
    vista is not connecting with a apple i pod nano saying it need another driver
    Scholar:
  • 92 Answers
Try this out
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
then try to change the drive letter:
  1. Open the Control Panel.
  2. Double click on Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
  3. Double click on Computer Management.
  4. In the left column, click on Disk Management.
  5. Locate the iPod and right click on it, then click Change Drive Letter and Paths.
  6. Click the Change button.
  7. Use the drop-down menu to select a new drive letter. Note: Make sure to choose a new drive letter that is not already assigned to a network drive. The drop-down menu will display all available letters that are not assigned to a physical drive. Drive letters that are assigned to a network volume will still be listed here. It is also a good idea to assign a drive letter other than a, b, c, or d, as these letters are usually reserved for other system drives.
  8. Click OK.
  9. Click Yes on the coipod nano wont connect to pc - ts1493_4.jpgialog.
  10. Close the Computer Management window.
  11. Restart your computer.
Then try to restore the ipod to factory settings:
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
This has to resove your issue
Posted on Feb 04, 2009
Ipod password forget, how to unlock
You should be able to connect your iPod Nano to your computer and then perform a factory reset from within Apple iTunes.
Aug 14, 2012 | Apple iPod Nano Video 16GB 5th Gen Silver...
Itines keeps saying it detected A ipod but not
when you connect your ipod with the computer try to hold the usb port cable tightly so that it recognizes your ipod. Thanks :)
Jan 01, 2010 | Apple iPod nano
I need the instruction on how to set up my
here's the website: http://support.apple.com/manuals/#ipod
you can download the user manual from there.
Dec 31, 2009 | Apple iPod nano
The controls on the front of my Ipod Nano 16gb are not working
connect your ipod nano to usb and update or re-install software through online.they can fix all bugs...enjoy
Oct 19, 2009 | Apple iPod nano
Ipod nano 16gb won't connect with pc(itunes).
Is your ipod nano fully charged? and your installed iTunes the latest version?
Please make sure it is charged, and the new iTunes is downloaded and installed from here please do the following steps:
Connect ipod nano to PC. Make sure iTunes is already open prior to connecting it.
If this is the first time you are connecting then your PC will automatically install Apple Mobile Device Driver.
Once installation of the driver is complete, you should see the ipod nano logo appear within iTunes very soon. and start using it.
Jul 20, 2009 | Apple iPod nano
New Ipod Nano 4th Gen 16GB has went blank and will not turn on
HI there,
worst case scenario is that a circuit has broken inside. But your ipod will be under warrenty for a year from purchase.
Otherwise, leave the ipod to charge for a long time. Just leave it connected directly to the computer USB port despite not having any change in appearance. Also, don't connect it via a usb hub or through your keyboard. You will need to plug it into your computer directly.
You can also try entering DFU mode. Here is a great step by step guide to do that. http://iphonefreakz.com/beginners-guide/howto-dfu-mode/
Then restore the ipod and update the firmware. Make sure you have the latest version of itunes installed. By checking through software update.
I hope this helps,
Nathan.
Apr 14, 2009 | Apple iPod nano 4th Generation
Ipod 1st gen black
"OK to Disocnnect" message is normal; not being able to turn on or off while it is connected to computer is normal. If these problems are happening AFTER you have disconnected the iPod from the computer, then it is a problem - you will simply have to reset your player - the reset method for your particular iPod is in your user's manual - you can get this manual from Apple's website if you have misplaced it.
-Tha Mp3 Doctor
May 26, 2008 | Apple iPod nano
Ipod wont show up on itunes
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
---John
Give credit to Randomassist
May 16, 2008 | Apple iPod nano
White ipod nano will not stop showing "do not disconnect" icon....
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more asistance, let me know. Good luck.
Mar 23, 2008 | Apple iPod nano
Charging via ac dc
sounds like your ipod is having trouble reading your firewire connection, it is different than usb. you could probably go to the nearest apple store and get it replaced if its under warrenty.
Aug 28, 2007 | Apple iPod nano
Apple iPod nano Logo
121 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
