Question about Motorola Mobility RAZR V3
Razr v3 when i flip open my razr the screen doesnt come on and if i hit a button on the siude i get a white screen..... after leaving it open it flashes back and fourth like if i wer to flip it open and closed real fast.... what do i do to fix it?...
  • 35 Answers
It sounds like there is a loose connection in there or a button is stuck. There is a magnet that lets the phone know if it is open. It is located in the lower righthand portion of screen and the sensor is located in the upper righthand corner of the keypad. Get a magnet and play with it. What happened to it? Is it still under warranty? If not crack it open and see. There are numerous manuals online for the razrs. Only for the brave or stupid, but it just a phone.
Posted on May 30, 2007
SOURCE:
When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
Nov 26, 2009 | Motorola Mobility RAZR V3
I have a Moterolla V3,my LCD screen is not displaying correctly, I see white and red, but I can't make out anything else. When the phone initially turns on the screen displays the Verizon perfect...then it...
The flex that connects your screen to the phone board is bad and has worn out. It is commom with flip phones. All you need do is to replace the flex and be very mindful of how you close the flip phone.
Take care.
Nov 16, 2009 | Motorola Mobility RAZR V3
Screen is completely white
check with your companuy and reboot your phone
Sep 23, 2009 | Motorola Mobility RAZR V3
V3 wont recognise when flipped open.
It means ur handsets display strip occured problem
there is only one solution that replace the STRIP
May 19, 2009 | Motorola Mobility RAZR V3
White screen
May be some water get into the phone.Yo need to temove all moisture trapped in the phone: Dry the phone, battery, any accessory, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Aug 02, 2008 | Motorola Mobility RAZR V3
Loose "flip" (display) on a Razr v3. How can I tighten it..??
You may need a new Flip assembly.
The version might depend on your model of V3 (RAZR)
May 22, 2008 | Motorola Mobility RAZR V3
Razor V3
Take it to the service center, the keyboard cable got broken or worn.
May 03, 2008 | Motorola Mobility RAZR V3
Problem
Try the phone while plugged in and see what happens.  If it works fine then it's probably the battery or the contacts to the battery.  I've had a problem with my razr that's similar to this.  My razr is on the keys light up when i press something but the screen is completely blank open and closed and all the buttons work.  Best thing to try is leave out with battery and sim card out and it might start working again.  However if it is only 2 months old it should still be covered under warranty.
Oct 17, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3 - Key Pad not working
have the flexcable replaced take it to a mobile service center and have them replace it for you.
Sep 14, 2007 | Motorola Mobility RAZR V3
Its stopped.
dear check when u push the power button then it shows some light in key pad if then may be lose connection from cable or display ic is crrupted. other wise check software. mosty it prob from software first check for software.
Mar 20, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
67 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
