Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
Wiring diagram for pioneer model deh-p30001b
Bought radio today without inst. need help with wiring, especially speakers. installed in 95 jeep g.c. orvis with factory speakers
5 Suggested Answers
mixmaster
  • 626 Answers
SOURCE: need help with wiring a pioneer deh-5
You do not have the entire Pioneer model number listed, so I cannot provide you with the wiring info for it.
Bu here is the wiring info for your jeep.
Constant 12V+ Pink/Yellow  Switched 12V+ Red/White  Ground Black  Illumination Orange/Brown  Dimmer Black/Light Blue  Antenna Right Front  Front Speakers 6 1/2" Doors Left Front (+) Dark Green  Left Front (-) Brown/Red  Right Front (+) Purple  Right Front (-) Dark Blue/Red  Rear Speakers 5 1/4" Roof Mount Left Rear (+) Brown/Yellow  Left Rear (-) Brown/Light Blue  Right Rear (+) Dark Blue/White  Right Rear (-) Dark Blue/Orange **from the12volt.com
Best of Luck.
Posted on Oct 31, 2007
  • 15 Answers
SOURCE: pioneer deh-p6800mp wiring
You can find the wiring diagram online in a PDF of the installation manual, which is at this location
Hope that helps!
Posted on Jan 14, 2008
SOURCE: wiring diagram pioneer deh-3400
ce3d034.jpgh
ihave this for you
Posted on Feb 06, 2009
Shdak
  • 23 Answers
SOURCE: what is the speaker wire color code for pioneer
Crutchfield has allot of information on Pioneer receivers. They also have a number you can call for support. The wiring diagram can be found here: PDF File
Posted on Apr 06, 2009
lostinfamily
  • 149 Answers
SOURCE: need wiring diagram for pioneer deh-p4000ub
http://akamaipix.crutchfield.com/Manuals/130/130DEHP4UB.PDF
Here is the PDF file for your radio. On page 63 is the start of the wiring diagram. I hope this helps. Please Rate this solution
Posted on May 20, 2009
Wiring colors ford ranger 1992 &pioneer deh 3900 mp need to know which wires are which thanks
I suggest check this diagram
DEH-3900 Installation Manual -->> DEH_3900MP_CRD4131_installation_manual
1992 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Hope helps.
Oct 03, 2011 | Pioneer DEH-3900MP CD Player
Installing DEH-P3700MP in mitsubishi diamante need wiring diagram
The following may help you. The first is for the vehicle the second for the stereo. Good Luck.
Battery WHITE/YELLOW (+) RADIO HARNESS Accesory WHITE/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination RED/BLACK (+) RADIO HARNESS Dimmer RED (-) RADIO HARNESS Power Antenna YELLOW/WHITE (+) RADIO HARNESS Amp Turn On YELLOW/WHITE (+) RADIO HARNESS LF Speaker (+) WHITE LF Speaker (-) ORANGE RF Speaker (+) YELLOW RF Speaker (-) BROWN LR Speaker (+) RED LR Speaker (-) GREEN RR Speaker (+) BLUE RR Speaker (-) BLACK Amp Location MOUNTED TO BRACKET IN RIGHT SIDE OF TRUNK Steering Cntrls YES THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTARĀ® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT. Speed Cntrl NO Radio Security YES Securityiadame_18.jpg
May 14, 2011 | Pioneer DEH-P3700MP CD Player
Nee a wiring diagram for a Pioneer DEH-P3500 for a chevy s-10 pick up
1993 Chevrolet S10 Blazer Car Stereo Radio Wiring Diagram.
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Antenna Trigger Wire: Pink
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4? x 6? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Dash
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
http://www.modifiedlife.com if thats not your year.They have all years all makes&models
Mar 06, 2011 | Pioneer DEH-P3500 CD Player
Wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Nov 17, 2009 | Pioneer DEH-P410
Trying to install a new pioneer radio to a 1999 jeep
try walmart they have the wiring harness that you need to install your radio for about 6 dollars
Aug 10, 2009 | Pioneer DEH-1100 CD Player
NEED A WIRING DIAGRAM FOR A PIONEER DEH-1800
yellow- 12volt
red- Ignition
black- ground
blue/white- remote (amp turn-on)
white and white/black- front left
gray and gray/black- front right
green and green/black- rear left
purple and purple/black- rear right
Black stripes are negative.
Aug 07, 2009 | Pioneer DEH-1800 CD Player
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
Can Pioneer DEH-P7000BT be installed in 1996 Jeep Cherokee?
I can tell you it will be no diffrent installingthis radio then any other radio in any car as long as you got ground +common -common ground and 12V+ Standing power 12V+ ingntion swtich power ons you will be great!! Just make sure you download a diagram of you wire harness on the internet. Print it out and take it to your jeep and careully follow the instructions on there if you need any help give me a shout :)
May 25, 2009 | Pioneer DEH-P7000BT Car CD/ MP3 Player
Having trouble settimg clock on cd car stereo
how to set clock for a pioneer deh-27mp
Mar 24, 2008 | Car Audio & Video
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Aug 26, 2007 | Pioneer DEH-1600 CD Player
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
987 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
