Amani Whisper Series Model KFR 70GW keeps turning itself off
Our split system air conditioner kepps turning off.
The remote says it is still going but the actual machine turns itself off.
No idea why and we have misplaced the manul
Any help out there?
Just had the Amani service guy out. Had the same problem. It was the capacitor. Took about 15 mins to fix. The machine turns off to protect itself because it knows something's wrong
Posted on Jan 06, 2010
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
We have a spit system air conditioner.Celestial KFR-70GW/K it is leaking water/condensation internally behind the fan.I think it it from therear grill and for some reason it does not go into the drain...
Leaking water from indoor is a common problem. Please check the following:
1. Cooling coil and air filter blocked-Clean it. 2. Drain pan and hos dust blocked-Clean it. 3. Non insulated pipelines-Insulate properly. 4.Less rpm of blower motor.-Replace capacitor.
Helpful?
Jan 01, 2011 | Heating & Cooling
How does the Timer and Sleep functions work for the SUMO KFR-70GW Heat Pump
Hi!!
On the timer function, when you press the button, it will ask you the starting time and ending time of when the unit will start and turn off by itself. prior to use this function, the clock on the control has to be set.. On the sleep function, it will give you the option to turn off unit on 30 min. intervals. Just like on a TV.
Aug 10, 2010 | Heating & Cooling
Require instructions and wiring diagrams for Celestial KFR-70GW/K
If you pull the unit out of the case it should have a wireing diagram in a envelope near the compressor
Jul 17, 2009 | Frigidaire FAA065M7A Air Conditioner
My mini split only sometimes responds to the remote
indoor pcb in the indoor unit faulty and the responder.
Jun 09, 2009 | Soleus KFR-18GW Split System Air...
Spilt air conditionerl
Hi deabreu5. I have a spare remote for the fujita split system model: KFR I also have the instruction booklet but no manual.
Mine lasted for 3 years and no cold air comes out anymore. I'm going to have a crack at fixing it myself somehow. But a spare remote came in the box so I'll sell it to you if you like.
email me.
Feb 03, 2008 | Heating & Cooling
Heating & Cooling Logo
895 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
