Question about Whirlpool Duet GHW9150P Front Load Washer
F24 During the wash cycle the unit stops and displays an F-24 message. What does this mean ??
  • 183 Answers
Heater or drain fault Regards Engineer
Posted on Jul 30, 2007
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
My washer keeps flashing f24 and wont turn on what does it mean?
Hello, This is a water tempreture sensor error due to if the tempreture sensor value is out of range during the water heating up step during the cycle. Unplug washer or disconnect power, Check the water tempreture sensor and connection to it,check the resistance of the heating element using a multimeter. If you have any further questions message me back this error code diagnosis is for a whirlpool duet washer if you happen to have a different type of washing machine message me back your make and model number of your machine. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
Aug 18, 2011 | Whirlpool Washing Machines
What is F-24 error code
The error code means a problem with the heat sensor.
Failure
Code
Condition
Check/Repair
F24
WATER TEMPERATURE SENSOR ERROR
If the water temperature sensor (NTC) value is out of range (23°F to 217°F[-5°C to 103°C]) during the water-heating step
of the WASH cycle.
NOTE: To find correct Ohm reading refer to the Water Temperature Sensor section.
1. Unplug washer or disconnect power.
2. Check the water temperature sensor and connection to it.
3. Check resistance of heating element, if present on this model. (abnormal = infinity)
4. Refer to the Water Temperature Sensor section.
Thanks,
E-ware
Jul 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
It says 24 F- and blinks the same thing over and over
F24 Error
If the water temperature sensor (NTC) value is out of range (23°F to 217°F[-5°C to 103°C]) during the water-heating step of the WASH cycle.
Jan 01, 2011 | Whirlpool WFW8300SW
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 24 error. What does that mean?
Hi
Thanks for using FixYa. F24 is a water temperature sensor error which is caused when the water temp. sensor value is out of range during the water heating step of the wash cycle. To resolve this issue you’ll have to check the water temperature sensor and its connections. If everything seems to be working fine then you’ll have to replace the water temp.sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Kenmore HE2 Plus Front Load Washer
DEUT WHIRLPOOL -problem during wash cycle
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the "F24" Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
Jan 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 24 error code
According to the tech sheet, F24 is a water temp sensor error. If the sensor reading is not within specs during the water heating portion of the wash cycle this code will come up.
It will not hurt to use your washer while you find the fix.
Possible solutions:
  1. Water hoses were kinked...remove the kink.
  2. Connector that holds the connection between the control unit and temp sensor (inside of rear of washer) is broken or loose. Replace or tighten it.
  3. Water temp sensor is bad. Replace it.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
"HO" flashes on display during washing.
HO, indicates that the dishwasher is using Hot Water. It is completely normal.
Mar 08, 2009 | Frigidaire Professional Series 24 in....
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
141 people viewed this question
Sal De
Marvin
Marvin
jimorris77
