Question about Bunn-O-Matic Coffee Brewer GRW8
Slow recovery on bunn o matic for next cycle
Approximately 1 year old/ warmer plate works fine
  • 131 Answers
You could have scale building up on the heating element and thermostat probe. try running a 1/3 white vinigar - 2/3 water mix into the brewer, let it heat up completely, then run several pots of clear water through the unit. keep pouring water through it until the vinigar smell is out of the water,
Posted on Feb 13, 2009
Vp17-3 bunn o matic will not brew no water will come out if i wait about 15-20 mins it will start spitting out some water like 1/4 full! The heating elements are working on all 3 burners
You have 2 water valves on that coffee maker a water inlet and a dispense valve the warmers are only heat plates the element is inside tank Bunn has a great site for manuals it's a free download
Nov 13, 2016 | Electrical Supplies
I have a bunn auto brew w/2 warmers.flow control/filter is installed and the basket overflows...
Either the coffee grind is too fine, too much coffee or incorrect sprayhead. Count the amount of holes on the sprayhead.
Aug 29, 2010 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Need warming plate for Bunn Pour O Matic coffee pot
Due to UL regulations, warmer plates can't be sent out. However, you warmer plate can be repaired for a minimal charge. Please call customer service with the model and date code and we will be happy to provide you with the cost and address.
Nov 26, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn-O-Matic Model STF 20 is making loud noises and spewing water after brewing is complete
You may have a thermostat problem.
Contact a Bunn service center and have the unit checked.
Nov 07, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Inconsistent water amount being dispensed
It sounds like there is some build up in the brew line, find the nearest bunn dealer and get a delimming spring, then remove the shower and run spring through brew line.
Apr 26, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
I have an older Bunn-o-matic with 2 extra warmers on each side. The water is supplied automatically to the machine but is not heating up, despite my turning the heat knob all the way up. The warmers are...
Here are some possible causes ,the hi temp cut out ,thermostat, or heating element are bad .a continuity tester can determine whitch one .Also you could have a burnt off wire . The reason the water is still luke warm is a electic warming jacket that bunn put around the water tank to limit the therostat cycles during off peak usage very fixable hope this helps
Dec 29, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
The water is not getting hot
You can check to see if the switch on the side of the tank is turned on and is working, but if the problem is with the tank heater itself, you can't get replacement parts for this model unless you can find a broken one at a garage sale or a Bunn service center. You can obtain a list of service centers in your area from www.bunn.com
Oct 28, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Leak
your tank is leaking
Please Follow LINK for parts etc
Jun 12, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bunn-O-Matic Coffee Brewer GRW8 Logo
144 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
