Question about Orion 1200D Car Audio Amplifier
Orion cs150.2 amp power light "red"for protected need "green"
What am I doing wrong. Sister-in-law fighting with ex-husband,he took out amp and sub woof when he gave her her truck back and I was trying to help put one of my old amps in for her to get her radio working for her 3 kids,if you have kids you know how hard it is to get aroung without a radio. Please feel free to tell me I'm a Moron and what I'm doing wrong.Again...I have a "red" power light that means its in protect mode,how or what to do to get the "green" power light to run the speakers.
  • Anonymous May 15, 2009
    i just got out of work on a sunny day and when i turned my radio up i noticed the bass went out. i parked and open the trunk to my suprise the woofers arent workinmg. the amp is on and i hear the fan but the "green" power light isnt lit but the "red" protect light is on....i made sure all the wires are connected and none of them are touching neither are they touching metal. I am lost and dont know what to do with my speaker :(
  • 15,935 Answers
Remove the load (subwoofer)...
ensure the power and remote have 12V (remotoe only when the car is on)....
And make sure the ground is a good one - sanded and screwed.
If you now turn on the car, and the red light for protection still stays on, your problem is internal, and it will need to be serviced. This is not something that you can crack open and fix, as there are lethal amounts of stored energy in the power supply and capacitors.
If the light goes on, youe sub(s) is/are at fault. Check the impedence with a multimeter set to OHMs and read the voicecoil. It should read pretty near to 4 or 8 ohms.
But since your amp is the only piece new to the equasion, chances are the problem lies within the amplifier.
It either has fried components, or your subwoofer(s) are wired to a low enough impedence that your amplifier does not like.
With more info... model #s voicecoil configurations I can help you better. I will c/p an answer I wrote recently regarding amplifier failure.
Posted on Jan 06, 2009
  • blueextc3221
    blueextc3221 Jan 06, 2009
    One of the more confusing things with a car stereo can be when the amplifier goes into protection mode. One minute it's working and the next minute it's not. Here's a brief troubleshooting method that will hopefully help you if your amplifiers ever go into protection.
    1. Try to determine the cause. Amp's can go into protection mode for several reasons. Knowing what happened before it cut out can help determine how to fix it. Did the amp not work as soon as it was turned on? Did it happen after blasting for hours (may be thermal overload and it needs to cool)? Did it cut out after you hit a bump (a wire connection may have come loose)?
    2. Tear it down. Get the amp down to it's most basic state. Remove all of the speaker wiring and RCA wiring and leave only the power, ground and remote leads connected. If you still have a problem in this state then either your amp is defective or you may have an installation problem such as the amp touching metal.
    Remember that an amplifier should only be connected to the vehicle through the power and ground terminals. Mounting the amplifier to the metal of the vehicle, including putting the mounting screws into metal, can cause problems for your amplifier. Always mount the amplifier to a non-conductive surface. An easy way to accomplish this is to mount the amplifier to a wood board and then mount the board to the vehicle.
    3. If the amp is OK in this torn down state keep adding the other wires back on until you find what causes the problem. Add the RCA cables first. Then add the speaker wires one at a time. If the speaker wires cause the problem then they are probably touching metal. Check to make sure that a speaker wire isn't being pinched somewhere between the amp and the speaker. Also check that the speaker wire or speaker terminals aren't touching the vehicle metal near the speaker opening. Rear decks and door panels can easily touch unprotected speaker terminals if not properly installed.
    If the problem starts occuring when you connect the subwoofer wires to the amplifier you may have your subwoofers wired at too low an impedence. First check the specs on your amplifier to make sure what kind of loads it is stable under. Then go here and check the wiring configuration to make sure that your load is not too low:
    http://www.rockfordfosgate.com/rftech/wi...
    If you believe your amplifier is defective contact the manufacturer first. Many have flat repair rates that are very affordable and cover parts and labor. However local repair shops may be cheaper if it is just a small repair. Compare the manufacturer's repair rate to that of a local shop. If you don't know the reputation of the local shop it may be better to send it to the manufacturer who will have working knowledge of the amp and parts readily available.
  • blueextc3221
    Protection circuits are beyond the scope of this basic troubleshooting guide but I'll provide a basic introduction to them. In general, protection circuits are designed to prevent damage to the amplifier and, in some cases, they prevent damage to the speakers.
    • The most common protection circuit is the thermal shutdown circuit. It is designed to shut the amp down if it gets too hot.
    • Most amplifiers also have an over-current protection circuit. It's designed to shut the amp down if too much current is drawn from the speaker outputs or when there is an internal fault that causes excessive current draw.
    • Some amplifiers have DC offset protection. This prevents damage to the speakers in case the amp fails in a way that causes rail voltage to be driven to the speaker output terminals.
    • Over and under-voltage protection is employed in some amplifiers. If the B+ supply voltage is too high or too low, the amp will shut down.
    Any of these can shut the amp down. If there are no dedicated indicators to tell you which fault has caused the shutdown, you must determine which fault is causing the shutdown and then find the defective components. With a schematic, it's generally not too difficult. Without a schematic (many manufacturers won't provide schematics), it can be much tougher.
    There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause.
    If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure.
    Transistor Failure/Checking Transistors:
    In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
    Note:
    I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit.
    If you aren’t competent and don’t know what you’re looking at inside the amplifier, please refer to a car audio technician for repair. Internal voltages can be lethal if not de-energized before starting the repair.
Green light comes on for a sec the red light comes on,1200 watt sony xplod amp 10'' Orion sub,I think the subs right around 3000 watts. What's wrong?:(
Your Sony Xplod amplifier turns on briefly (green light) then possibly senses a mismatch between the nominal output impedance of the amplifier and impedance of your Orion sub and goes into protect mode (red light) to prevent internal damage.
Jul 19, 2014 | Car Audio & Video
Cadence 400 watt active sub green light on, no sound from the sub. whats wrong?
proceed according and fix it. However yi\ou must read the diode LED for diagnose. God bless you
Mar 26, 2013 | Exercise & Fitness
Hi there, i have a orion cobalt 2105xp 400. i have hooked all up, but very little bass. i have 1 10" boston acoustic sub. i noticed that the led is constant red, is it supposed to be green, crossover...
amp is in protect mode. check your wiring and make sure your sub is wired properly for ohms. dual 4 ohm in parallel = 2ohm. dual 4 in series is 8 ohms. dual 2 ohm parallel= 0.5 ohms and in series 4 ohms. check ground and power wires. make sure sub isnt blown. a blown sub WILL cause this on any amp.
Sep 10, 2011 | Orion Cobalt 2105 XP Car Audio Amplifier
My amp keeps going into some safe mode and red light blinks and stops base to my sub. I have it hooked up to 1 15.4 Orion HCCA.
The "safe mode" on your amp usually kicks in for two reasons - the ohm load on the sub is too low for the amp (presenting a "short" to the amp), or it's going into thermal protection because the amp is too hot. From your description, it sounds like there's a short in the wire, the sub's ohm load is too low, or the sub is partially blown.
If you have another sub or speaker, connect it to the amp's output and see if the amp still goes into protection mode. If the amp goes into protection with a known-good speaker, then there may be something wrong with the amp's power supplies. If the amp works properly with another speaker or sub, then I would check the sub that's causing it to short out.
You may also want to check whether or not the amp is over heating by just touching the amp when it goes into protection. If it's just warm, that should be ok - if it's hot, then it might be working too hard. In this case, you may need to check the input voltage (12-14VDC) and the size of the power and ground cables. If your ground isn't properly connected, it can cause weird problems like over heating, shorts, erratic behavior, etc...
Mar 04, 2010 | Orion HCCA-D5000 Car Audio Amplifier
Directed d2400 red and green lights on constant and no output...whats the solution
ok ive had an orion amp do this before. oiron is made by directed audio now so its the same style amp. after i checked the ground, power, subs to make sure they were good and not shorted together, i came to the conclusion the amp was bad. its in protect mode right now so check everything with a multimeter and make sure everythings good. if all is ok the amp may be bad. good luck.
Dec 23, 2009 | Directed 2400d Car Audio Amplifier
Orion hcca 250 digital reference
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Subs stopped working & protect light on the amp is red...
well at this point i would say it is both,, the subs fried because your amplifier passed dc [direct current] and fried the voice coils on your subs....return them if they are under warranty,, the amplifier sound like you either operated it beyound its specifications or it has a defective output stage allowing it to pass or leak dc....it turned the voice coils into the equivelent of the runners in a toaster oven....when an amp passes dc it is going to do so to whatever speakers you hook to it....so either bring it to a shop to be fixed/ return it to place purchase for exchange or throw it away.....or you will continue to experience the same problems....I am sorry..ps the amp goes into protection when it detects a short...[ the short is produced by the amp and it is detecting its own fault and putting it in to protection after it BURNS up your drivers....
May 16, 2007 | Volfenhag ZX-4712 Car Subwoofer
Orion 1200D Car Audio Amplifier Logo
1,200 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
