Question about Bulova Watch
Taking links out of the band
How do you take links out of a Wal-mart (George) band
  • Anonymous Mar 29, 2014
    gold george round nul outer pins FMDGE315/135 band gift street deal
  • 2,334 Answers
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 05, 2009
Do you sell replacement bands
Hello, Adrienne,
Fixya does not sell can buy replacement watch bands at most jewelry store.. and inexpensive ones at Wal-Mart...
Sep 12, 2017 | Watches
Where can I find replacement links or a replacement band for an aquaforce rothco 04Q US Marines watch It is a very unique band with tag hauer type u shaped links
As far as links go only the manufacturer would carry them. However a replacement band can be easily installed and can be purchased at your local Wal-Mart. You need to measure how wide the band is where it connects to the watch in MM (most bands have a width that is uniform however I've seen some before that get smaller as you move away from the head). The band is held onto the head by a part known as a spring bar. In order to remove the band get something small like a dental pick (that's what I use) and push the bar in while at the same time pulling on the band. If you don't pull the spring bar will reengage and snap back in. Removing the band is fairly simple however the trick is getting them back in. I line the spring bar over the natch and try to get one side in at a time although on some watches both sides of the bar must be pressed in at the same time before the band will fit in the slot. It really just takes patients and a steady hand.
Dec 31, 2013 | Watches
Trying to get a clasp strap for addidas watch model adh1177
Wal-Mart has universal watch bands that are made to fit different band widths at the watch bezels.
Mar 14, 2013 | Watches
Need a replacement band
Have you tried the jewelry department of the nearest Super Wal-Mart? They have a large replacement band selection.
May 19, 2012 | Casio G Shock Mudman G9000MC 3 Gents Watch
Strap broken on timex heart rate monitor watch 30 lap ironman triathlon need a replacement
Hi, Almost any large dealer like Wal-Mart, Sears, or Target will have Timex replacement straps and bands for most popular watches and monitors. Sometimes a local Authorized Dealer will have specialized products that the department stores don't even carry without ordering.
I have had good luck with Wal-Mart on watch accessories. I've also ordered straight from Timex in Little Rock, Arkansas, ph. 1-800-448-4639, but it usually takes more time for just parts.
Thanks, Bill
Sep 06, 2010 | Timex Ironman T59761 Midsize 30 Lap...
Brokem wrist band
Check Wal-Mart, Sears, Target, or other large department stores. Many carry a good selection of replacement bands for Timex. If you still don't find one call Timex in Little Rock, Arkansas at 1-800-448-4239.
I hope this will help you replace your band.
Thanks, Bill
Sep 04, 2010 | Timex 30 Lap Ironman Fast Wrap Midsize...
How do i take my george watch out of 24 hour time?
how do you set the time on the digital george watches?
Nov 21, 2009 | Watches
Need new band. Where can I buy one? Thank you.
Any local retail store like Wal-Mart, Target, K-Mart. Just go to the Jewelry Counter find the band spinner measure the length of where the band is held with the watch.  Find your new band.  Usually everyone place have descent bands.  Ask employer there really helpful as well. Good Luck.
May 25, 2009 | Pulsar PF3347 Wrist Watch
Remove link from Watch Band
I would suggest that you take it to local jewler or watch repair center, it normally runs less then $10 to remove an unlimited number.
Wal-Mart used to be a good place to go, but have since decided to support only watches that are sold in the store, which are crappy at best.
If you want to do it personally...I would discouage it. It is normally a simple process but without training, can turn into a big problem with minimal effort.
Have a great day!
Jan 13, 2009 | Watches
I need to find replacement band for Freestyle Men's Rockaway watch
Google search your watch, choose from list of suppliers etc.
Nov 02, 2008 | Freestyle Watches
Bulova Watch Logo
260 people viewed this question
Top Bulova Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
