Question about Kodak EASYSHARE 5100 All-In-One Printer
My Kodak 5100 prints colour but not black
I'm following the 'step by step solution' which says 'clean the printhead' and to do that go to the Kodak all in one home centre - how do i get into the Kodak all in one home centre?
  • 295 Answers
Kodak all in one home centre is on ur desktop. with ur printer u might have got a cd. that cd contains Kodak all in one home centre. if u dont have it installed on ur desktop, go to kodak.com/go/downloads and download it from kodak website
Posted on Jul 21, 2009
    Scholar:
  • 60 Answers
If you have the software installed on the computer and if it is Xp then click on start button and go to all programmes and go to Kodak and there would be AIO home center......it is vista then click on start button and go to all programmes and scroll down to find the Kodak and when you click on it there would be AIO home center........there is more if you dont find it so let me know
Posted on Jul 08, 2009
Kodak ESP5 Error Code 3802 and will not print yellow even with cleaning and new ink.
Issue is with printhead
visit www.kodak.com/go/itg
Select all-in-one printer
Select image quality > missing color > follow the steps to order a free printhead
Else
call 18004216699
Dec 22, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Won't print the black have bought new cartridge but it still won't print colour ok but no black
If you have done all the steps to clean the printheas, as listed in the printer's maintenance program, contact Kodak and let their customer support know your problem. You will need your model number (5100 AIO) and serial number (lift the platform where you change the ink. There is a number there. They will send you a new printhead. It takes 30 seconds to replace and there are no tools required.
Nov 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak easy share 5100 all in one printer. I have got problem with colour printing, it should print red but instead of it it is prionting pink. What;s wrong?
follow the step by step solution from kodak.
Choose All-in-one printer and then Print quality and follow the further steps. I think it's a problem with your printhead.
Oct 15, 2009 | Kodak Office Equipment & Supplies
Kodak 5100 printer will not print color
Oct 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak printer won't print
Check out the following link:
http://www.kodak.com/go/itg
For any image quality issues, you will be led through a few troubleshooting steps and if they don't work, you will be given some direction on how to get a replacement printhead.
Jul 07, 2009 | Kodak Office Equipment & Supplies
Printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
Mar 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 will not print in black
please call 1.800.421.6699 to get a new printhead free of charge. Please rate my solution
Feb 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5500 Printer Pa[per jam
Verify that the ink cartridges are intact and securely inserted into the printhead, then make the same print.
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If this will not correct the issue, try to follow these steps
Clean the printhead, then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. Press Menu.
  3. Select Clean Printhead, then press OK.
  4. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  5. When the On/Off light glows a steady green, select Print Demo Sheet, then pressStart.
If these steps will not correct the issue on the printout., you need to call Kodak technical support ( 1 800 421 6699) possible the printhead is defective and it needs to be replaced
Dec 11, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printing Problem
Hello hougher,
You need to clean the printhead of the printer to solve that issue. Because everytime you print, excessive inks are going to the printhead that's the reason why it's clogging the system up. That's because Kodak printers is using "pigments" as inks that's why Kodak printers are producing high quality prints unlike other printers - a photo printed from kodak could actually last for about 100 years. Now back to your issue, you need to clean the printhead from the printer but not manually. You could clean it by going to the software of the printer namely the KODAK HOME CENTER SOFTWARE. You need to click the "?" mark icon on the upper right corner of the software window then under the General Links select Maintenance then choose Clean Printhead. Do it at least twice and then try making prints. If that still doesn't work try calling Kodak Technical Support Representative: 1-800-421-6699
I hope I have been some of help.
Oct 21, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
280 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
