Question about Gold Medal 2085 Red Dome Special Popcorn Maker
Gold medal model 2085 keeps tripping the circut breaker after cleaning
5 Suggested Answers
SOURCE: Gold Medal 2086 popper electrical
I'm not sure if this will be helpful or not...
The 2086 in the picture looks like the Ultra P-60 with the copper finish (Part #1866 at http://www.gmpopcorn.com)
You can get some manuals & schematics at the Jarco website:  http://www.concessionstands.com/s.nl/it.A/id.307/.f  (The machine is listed there under part #2086, by the way; is this where it came from?)
Anyway, hope this info is of some use.
B. Bryan Buda, Tx
Posted on Jun 05, 2008
  • 21 Answers
SOURCE: Trips circuit when you turn on the Kettle heat
When the fuse blows see what else in the house is out, maybe you have the circuit overloaded. Try putting the popcorn maker on a different unused curcuit to see if it still blows. Then you will know if it is the popcorn maker.
Posted on Dec 16, 2008
SOURCE: Replacement Kettle assembly for Gold Medal 2121 Econo-pop 14
gold medal products co.
800-543-0862
10700 medallion dr
cincinnati,oh 45214
www.gmpopcorn.com
Posted on Feb 03, 2009
SOURCE: Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Posted on Oct 09, 2010
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Oct 01, 2014 | Gold Medal Kitchen Appliances - Others
I have a Gold Medal popcorn machine model 2085 that is producing a burning wire odor. Have other people reported this problem with their machine
All new popcorn machines will produce a industrial smell for a short while when first heated up. It is from the oils used in manufacturing and that will stop over time.
Burned wire smell is usually associated with cleaning of the kettle. Cleaning compounds that are stuck in the carbon will create a harsh smell.
Sep 25, 2014 | Kitchen Appliances - Others
Why does my Gold Medal Waffle Cone Iron trip GFI outlet when I switch on?
because the iron draws too much power for the GFI. Plug it into a regular socket instead.
Jun 15, 2014 | Gold Medal Products Waffle Cone Baker,...
Cotton candy maker will not power on
If you have checked to make sure it is plugged in, and outlet has power. The next thing to check is a circuit breaker in the front underneath the handle. A small white button to push.
If resetting the breaker, and it runs for a second then trips again, do not reset it again, this indicates a ground fault in the machine and it needs to be repaired by technician.
If the breaker doesn't change the operation (no power) then it should be repaired by a technician as there is no easy fix for the symptoms you have described.
Mar 21, 2013 | Gold Medal Products Gold Medal 3008SS...
Oil to popcorn ratio for model 2085?
All popcorn machines use a 3or4:1 corn to oil ratio. More specifically the model 2085 is a 6 oz popper.
6oz. popcorn (3/4 cup)
1.6 - 2oz oil (1/4 cup)
1-2 tsp popcorn salt
Mar 12, 2013 | Gold Medal Kitchen Appliances - Others
Gold Medal 2005 Popcorn Maker electricutes you if no shoes on
That machine is not properly grounded. If it was it would be tripping the breaker every time.
Somewhere there is a ground fault in the machine, any wire or heater is suspect, also the broken light bulb is suspect.
Get the machine grounded properly, and start flipping switches. which every switch trips the breaker, that is where to start looking for the ground fault.
Jan 17, 2013 | Gold Medal 2005 Deluxe Whiz Bang Popcorn...
Cotton candy machine keeps tripping breaker
possible reason being, You have to many circuits running at the same time causing it to trip the breaker try unplugging some other appliances an see if that helps.
Sep 30, 2012 | Gold Medal Accu Floss Cotton Candy Machine
I need a new pot for model 2085CL . Where can I get one
Replacement parts for Gold Medal products can be ordered online here:
http://www.gmpopcorn.com/store/index.cfm
Unfortunately I did not see that a replacement pot is being made available. Recommend you contact Gold Medal directly via their web inquiry form and see if they can make a replacement pot available to you:
http://www.gmpopcorn.com/contact-us.cfm
You could also try their toll free number: 1-800-543-0862
Aug 02, 2011 | Gold Medal 2085 Red Dome Special Popcorn...
Keeps tripping the breaker
What size breaker?
as long as there are no other appliances or anything on the circuit a 15 amp breaker will do...if you have alot of other items on that same circuit you either need a larger breaker, or use a different circuit all together
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Mar 31, 2010 | Gold Medal 2656 Ultra Popcorn Maker
Gold Medal 2085 Red Dome Special Popcorn Maker Logo
109 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Oloyede Monsuru
john h
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
