Loud buzzing in Emachine. Already replaced the fan. but buzzing continues. If I leave it off for a long time it will quit for a while but then comes back.
  • Sally A. Tripp Nov 12, 2012
    I haven'tt tried the solution yet, but right now the machine is running as it should. I will try the solution this coming weekend, as I will be out of town this week.;
  • Sally A. Tripp Nov 18, 2012
    You were right! The small fan in the front of the machine was making the noise. Will replace it and that should take care of my problem! Thanks so much.
    Master:
  • 545 Answers
Dust it out. There Should be more than one fan. They run louder/faster when they overheat. Dust will increase the heat.
Posted on Nov 10, 2012
    You were right. There was another much smaller fan and that is where the noise was coming from. Will replace and that solves my problem. Thank you so much!
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
Loud Continious Alarm noise coming from the Piezo buzzer
You are definitely looking at a hardware problem. Your son did not cause this problem.
On the problem computer, disconnect everything but the video, power supply, memory, CPU, mouse, and keyboard.
Now try to start it up. It should start and tell you there is no boot device. If the noise continues, remove the memory and try to start it.
I'm not sure if you have an integrated video card or not, but if it's an add-on, you could try to remove that to see if you can quiet the system.
Once the system starts, plug things back in one at a time to get it working.
Apr 12, 2010 | ASUS P4S533-MX Motherboard
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Jul 30, 2009 | Microwave Ovens
When I turn on my emachine computer, I now get a louder whirring noise. Is this dirt accumulation on the hard drive fan?
Well there is no fan on the actual Harddive Fans, Unless you mean the PC Case fans, in which dust built up on it wouldn't make a loud whirring noise. If it is, it's because the fan's ballbearings are bad and you need to replace it.
The harddrive is a Small rectangular silver or black box on the inside of the case towards the front. If the loud noises have started coming from there then the Harddrive is going bad, and you might want to back up your data immediatly.
Post any comments for further help, hope this answers your question. Feel free to leave positive feedback, and thank you for stopping by Fixya!
Jan 09, 2009 | E-Machines eMachines Desktop PC
Buzzing plenum heater
is the fan relay going bad it is located normally inside control box behind panel where wiring enters unit
Jan 04, 2009 | Heating & Cooling
Loud humming or buzzing when set is in operation
Does the picture gets distorted in any way when you hear the buzzing noise?
I would suggest to check all the cooling fans for proper operation.
Jul 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
SAMSUNG DLP BUZZ ONLY WHENBULB IS ON
A friend of mine does warranty work for samsung ,name is chip call him if you need too! 256-778-0300, most of the time when lamp needs replacing set will not play,the fan behind lamp is there to keep lamp cool when playing ,DO NOT touch lamp if you do this will leave fringer print and lamp will burn your inprint on it when hot!!! then you will have to replace lamp ,they are not cheap.replacing lamp is fairly easy, besides i really dont think lamp is your problem,most likely it would be fan making noise.
Jan 18, 2008 | Televison & Video
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
