Question about Campbell Hausfeld Garden
My Honda GCV160 surges after about 3mins the engine dies off whilst the operation is going and eventually shuts down. To restart it must be cooled off before you attempt to proceed your task
It was purchased in August at PRICESMART La Romain Trinidad & Tobago
  • 57 Answers
SOURCE: 98 honda shutts off and will not start until cooled off
you say the engine shuts down when it gets hot if it runs rough before doing so it could be the coolant temperature sensor allowing the engine to  overfuel  if the engine cuts out in a couple of seconds but sounds smooth it could be the fuel pump , if it cuts out instantly its electrical.
Posted on Mar 28, 2009
get_whitey
  • 3 Answers
SOURCE: The engine shut down while on stop and go traffic. Tried to restart but the throttle was weak and shut down again. After shutting everything down for 5 minutes, restarted the engine. The throttle w
If the car is having trouble maintaining idle (the tach dips and car dies) the common causes are the idle control valve and camshaft position sensors. The cam sensors failing will be indicated by a check engine light.
The ICV can removed and cleaned with good results (I think there is a write up on bimmerfest) or purchased new for about $100.
While you are in there check the intake boot that is Y shaped for cracks, it's prone to fail and will mess up your idle too.
read up on the major forums and you'll get more info
Posted on May 18, 2009
SOURCE: engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
Posted on Jun 01, 2009
  • 174 Answers
SOURCE: Honda GCV160 Engine Won't Start
Hello
You should siphon out all the old gas you can. Replace with new gas. Check that the spark plug is good and the air filter is clean. Spray some carb cleaner in the carburetor.. Also, you should check the oil level and change the oil if it is black. If it tries to start after you spray the carb cleaner in but won't keep going then you know the carburetor needs a good cleaning
Posted on Aug 08, 2009
  • 7353 Answers
SOURCE: I have a 1998 2.0 Honda accord CF9(Trinidad &
NO.
Posted on Nov 16, 2009
Why does the honda engine surge
I have two pressure washers and honda engines on both. Carb needs to be cleaned I would bet,had to on both of mine. Good luck.
Jul 15, 2014 | Troy-Bilt 12avb29q711 Tb260 21-inch 160cc...
Why does my hedge trimmer die after a few minutes operation
This sounds like worn main bearings beginning to seize. Worn bearings generate more heat which causes the metal bearings and their races to 'swell," thus getting tighter and generating more heat until the drag of the bearing friction is greater than the power of the motor. Eventually you can't restart it until the engine has fully cooled down.
Apr 30, 2014 | Poulan Pro PP2822 28CC Hedge Trimmer
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
2-yr old troy-bilt pressure washer with honda gcv160 engine. seems to run well, but when trigger is pulled get full pressure for less than 5 seconds before reducing to house water pressure. when left...
It sounds like an air lock. Try this: With the machine off, connect the hose to the washer and let it run for several minutes to get all of the air out of the hose, and to purge any air out of the pump. Shut off the water, and connect the high pressure hose, but not the gun. Let the water run for several minutes. stretch out the HP hose and make sure that the air is displaced. Shut off the water, connect the gun, and purge as before. Now crank it washer up. As quickly as safe to do so, open the trigger to keep water moving through the washer. It should come up on pressure very quickly. It is better during normal operation to keep water moving through the system. When I am through for a while, I shut down my washer, but leave the trigger depressed to allow the pump to stay full of water, and cool. This prevents further problems when I restart it.
Hope this was useful.
Regards --W/D--
Jul 17, 2009 | Briggs & Stratton Garden
Starts OK but after about 15 or 20 minutes starts losing power and after moving throttle up and down for five minutes or so to keep going dies After cooling for twenty or thirty minutes will start and go...
When your ignition coil get to engine temp. it will begin to lose its power, therefore your engine will eventually shut down, when it cools it will start up again,
Good luck
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to repair a hole in the wand tubing for pressure washer
my Honda ic2 ran greet, then all of a sudden it started to slowly shutting down,
i restarted it. and it ran for about 5 min and shut down. i did this 3thee to four times do i need a gas additive or what
Apr 27, 2009 | Garden
Mar 21, 2009 | 1998 Honda Civic
Honda GCV160 5.5 on a pressure washer runs only intermittently
The problem is the plastic float in the carburetor, it's not adjustable and after sitting up with gas in it it distorts. Save yourself the trouble and buy a new one, you can get them online for $15-$20.
Mar 17, 2009 | Campbell Hausfeld Garden
Honda accord 1996 v6 2.7 liter,rpm gage jump up and down
Here is the most common cause of surges and stalls, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Nov 28, 2008 | 1996 Honda Accord
Garden Logo
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
