Question about AOpen AX34-U Motherboard
Printer Problem I've just ungrade my AOpen AX34-U CPU PIII computer and everything was working fine when I use Windows2000 Professional installed on that motherboard, but after I changed from Windows2000 Pro to XP Professional that is where I have problem with my Printer. The montherboard maye can't detect the printer connected to my computer. Few things I do before saying this. 1. I change the printer cable 2. I install the printer software first before conecting the printer. 3. Connect the printer to another computer and it it working just fine. I need your answers to this problem. Skud
    Scholar:
  • 125 Answers
Are you using Printer cable (LPT) or USB cable? If you are using Printer (LPT) cable, do the following test: Activate command prompt (Start-Run and type CMD) On command prompt, type dir >prn This command sends the directory list on to the printer. This command works even without driver. It is like a hardware test. Make sure that the printer is ready and has paper. If the pinter uses USB interface then do the following: Make sure that the USB interface is working, you can verify this by viewinf the hardware list (right click Mycomputer select properties and then hardware, device manager. At thebottom you can see Universal Serial Bus Controllers. Expand the tree and look if there are errors (? or !) If the USB is not installed properly maybe you have to install the motherboard XP driver from AOpen or you can install Service Pack 2 .
Posted on May 24, 2007
    President:
  • 2,961 Answers
Two possibilities, if you are in possession of the motherboard drivers you will need to install them as windows xp will be using generic ones and may not be suitable for your board, also try installing in a different usb port. The other is that the drivers you are using will probably be win 2000 and in your case it wont work with XP, so go to your printer manufacturer web site and download and install XP drivers.
Where can i download the sound driver for my AOpen AX34 PRO motherboard?
You can find the audio driver on the manufacturers website using the following link.
http://usa.aopen.com/userdownload_List.aspx?RecNo=4018&Model=147
Hope this helps.
Aug 20, 2011 | AOpen AX34 Pro (91.88910.101) Motherboard
Constant beep at startup
THIS BEEP SOUND INDICATE YOUR RAM/RAM SLOT PROBLEM
OPEN YOUR CPU AND REMOVE RAM
CLEAN YOUR RAM SLOT USING CLOTH
AND REINSERT YOUR RAM
T
PLEASE VOTE IF YOU SATISFAID
Dec 06, 2010 | AOpen AX34-U Motherboard
Find maximum processor size for aopen ax34-u motherboard
u wont be able to install a cpu much faster than 1ghz without flashing the bios.....
if you do not know how to do this then plz do not attempt it as if it geos wrong or you have a power surge then the mobo will be NFG.......
Feb 24, 2009 | AOpen AX34-U Motherboard
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
thanks
roger
Nov 12, 2008 | AOpen AK77-8XN Motherboard
Aopen ax34 tamper alarm--how to reset????
I don't think that board actually has a tamper alarm in the bios, password security yes but I saw no mention of a tamper alarm. Besides, a tamper alarm won't stop the pc from booting, it just lets you know that the case has been opened....sorry. I think you likely have a mainboard/ram issue.
First thing is to clear the bios. Here's how. Right beside the floppy connector, there is a jumper labeled 'JP14'. Please do the following
  1. Turn off the pc and remove the ac power cord.
  2. Remove the atx power connector from the mainboard (from power supply).
  3. Locate jp14 and move the jumper from pins 1 and 2 to pins 2 and 3. Wait 10 seconds.
  4. Put jp14 back to pins 1 and 2
  5. Reconnect the atx power connector.
Or you can just unplug it from the waal and remove the bios battery for an hour.
sa code
Try to fire it up again. If it still won't boot, then let me know the number of beeps it makes and the pattern to the beeps ie: one long beep then another long beep or 1 long beep then 2 short ones. These beep are actually telling you what the problem is.
Hope this helps! Post a comment and let me know how you make out.
Aug 24, 2008 | AOpen AX34-U Motherboard
Problems with AOpen AX34 motherboard or procesor Intel Celeron 900
if you installed windows with out formating the driver then nothing would change.
Jul 17, 2008 | AOpen AX34-U Motherboard
Aopen motherboard: MS-6378 VER:3 Faulty
just u clear the cmos and load the defaults settings in bios then  restart the computer.,if not check the cmos voltage +3v,if voltage not appear pl change the battery it self
Was it helpful to u pl give the rating for me
Thank u
Oct 23, 2007 | AOpen AX34-U Motherboard
AOpen AX34-U Motherboard Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
