Having difficulty seting bit depth
I'm not familiar with that brand, but no, normally you need only loosen the lock so the router can move up and down, and either twist it or plunge it into the correct position, lock it, check the depth, repeat.
If it's a plunge router you'll have a depth stop rod that you can use in conjunction with the stop nuts to dial in the correct height of the bit. If it's a conventional router you just have to twist it into the correct height and lock it in place without moving it.
If your router table is fairly light and portable, sometimes its easier to turn the whole thing upside down on a pair of sawhorses to adjust, then flip it back over. Otherwise, you just have to crouch down under there, aim a work light so you can see what you're doing, and adjust away.
Make sure you unplug it first!
Also be aware that you might need a fence for your work to ride against, that you may need to make your cut in successive passes rather than trying to hog off too much at once, and that even routers can grab the work and kick it, so be cautious and feed from right to left as you face the bit, (with the work closest to you).
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
