Question about Acer Aspire E500 PC Desktop
Instal new rams to up grade from 1 gb to 2 gb
I bought two sticks of 1 gb each from crucial I ordered according to the spec of the computer a Aser ASE500-u-P6200 desktop 620 intel pentium 4 processor. When I put them in and run up comp. It don't work screen said no signal and comp. fan runs wide open
  • 1 more comment
  • sbmin Jan 05, 2009
    tried all of your suggestions with exception of resetting the BIOS but I will need help on that
  • sbmin Jan 06, 2009
    I put original memory back in and it works I there is also a P8 cable disconnected but I think it was already like that.
  • gerrick Jan 24, 2009
    I have the same problem. I tried installing two PC2-3200 1GB ram modules into each of the two slots, and when I powered up, the fan ran on high, but nothing else (no OS splash screen, etc.). I then returned the original ram (2 sticks of 50MB each) and that didn't work. After trying every different configuration of memory + slot, I ended up only being able to use 50MB in one slot!
    I am miffed and confused -- please help!
    Master:
  • 461 Answers
Either the RAM is not compatible or not inserted correctly. Try removing and reseating both modules, if no change try with only one stick then switch and try just the other to see if the problem is just with one. You could also try resetting the BIOS to factory defaults.
Posted on Jan 05, 2009
  • Curtis Richner Jan 05, 2009
    To reset the BIOS on a system that won't boot is to disconnect the power and remove the CMOS battery from the motherboard and short the battery connections with a screwdriver or use jumpers if documentation is available for your particular board.
    Did you try using the original memory?
    Did you check that you didn't accidentally disconnect something in the process of the upgrade?
  • Curtis Richner Jan 06, 2009
    Well at least the system is still functional. An easier way to reset the BIOS would be to press whatever key necessary to enter the BIOS setup (F1, F2, DEL) and select the option to reload defaults
Hello, I was looking to upgrade the ram in my old dell 5150. The specs say you can use a Max of 4 1 gig sticks yet these specs where released prior to windows 7 ultimate which uses far more ram. What are...
Check www.crucial.com. Use the downloadable program to analyze your system or use the interactive menu system to explore your options.
Check online forums using google searches for terms like 'dell 5150 memory upgrade'. Sometimes, the maximum in the manual is not the real maximum. My Dimension 1000 laptop accepted a certain 1 GB card when the manual said the max was 256MB. Still running it after nearly ten years. The laptop was **** with 512MB (256 built-in and 256 add-on card) but the gf uses it every day.
Sep 13, 2012 | Computers & Internet
I have the HP Pavilion a1330n computer, I just installed 4G of memory (4 X1G) to replace my previous 1G (2 X 512). The memory specs are correct but every morning the computer has a black screen and I have...
NO OS stated, Blues screens you mean the BSOD with the halt? statement on screen? i bet yes. (with words on blue screen)
words matter.....
Bought new memory or old?
no, (to supposed) yes, to , back to beginning done wrong or luck bad.
so put back the old RAM, does that work.?
or use just 1 stick of old ram. ? 1 by 1.
then repeat, new ram 1by1,
see? one stick is bad, if it all ran perfectly before you touched ram.
buying RAM for such and old PC is not easy.
step1:
first ASK HP, you asked now at yahoo, why here, and not HP>?
but HP long long ago retired the A series.
per HP pages. here
https://support.hp.com/us-en/retired-products
personally I do go the used PC store and buy $20 PC vastly newer.
sure would, but lets follow the rules for yours, step by step
step 2, (1 was hp , no support)
next is to lean what Memory was uses and what the processor spec is on the same,
the mobo is 2005 era. (as old as) 12 years ago...
its not Intel, its Athlon 64 (S) 3800+ 2.4 GHz
if it was intel , the intel chip drives the memory with its MMC
its not.
ASUS made this mobo by HP contract.A8AE-LE
hp name is: AmberineM-GL6E
max mem
4 GB* (4 x 1 GB) requires the replacement of the installed 512 MB DIMMs
PC-3200 MB/sec , speed ( not slower !) faster ok.
184 pin, DDR SDRAM
Dual-channel memory architecture
4 x 184-pin DDR DIMM sockets support unbuffered non-ECC 4 GB 400/300 MHZ DDR memory modules
page 7 is sparse in your manual.
https://www.manualslib.com/manual/721818/Asus-A8ae-Le.html?page=7#manual
the Athalon 64 has an ON DIE mmc, memory controller
this sets the base limits of all possible memory.
the memory speed is not by FSB, speeds
simpler terms, the memory is always running at a set fraction of the CPU speed
this chip has the advantage for running , cleaner DDR signals.
that other FSB designs.
what that means , to the user more memory choices.
I see this maker selling memory , a top maker,
http://www.crucial.com/usa/en/compatible-upgrade-for/HP-Compaq/pavilion-a1330n-series
test the sticks all 1 by 1,,, one good way to test it is run fast games.
DDR stick density rules and numbers and types of memory pre stick and pre side can cause problems on old processors.
I could not find the Athalon 64 rules on this, AMD can tell you at there site but im too lazy to look it up..
best is to let Crucial or Kingston guy you , here. for SURE>
Jul 13, 2017 | HP Pavilion a1330n (EL466AA) PC Desktop
I upgraded my gategay gt-5428 computer memory 1 gb to 2 gb but still runs with i gb, what i did wrong?
Hello Erik,
Are you absolutely certain that the new module is compatible with your system? Go into the BIOS and see if it is recognized there.
Crucial shows that your computer takes DDR2 memory with support for DDR2 PC2-5300, DDR2 PC2-6400 speeds.
Make sure it is not ECC memory. ECC is not compatible.
If you are sure of the compatibility, I would try to install the old one by itself first and make sure the system boots. Then I would remove the old one and install the new one by itself. Try booting. If it doesn't work, you may have gotten a bad module. (It happens.)
Just FYI, here is the crucial link for your computer:
http://www.crucial.com/store/listparts.aspx?model=GT5428
Thanks for using Fixya.
Feb 27, 2011 | Gateway GT5428 PC Desktop
Acer Aspire Memory problem
check hardware compatability,vista is touchy,get xp
Sep 23, 2009 | Acer Aspire 5315 Notebook
Ram questions
it has 1 gb ram. if you bay 1 gb it will be 2 gb.  if you buy 2 gb you can use together but it supportes only 2 gb. you can only see 2 gb.
May 27, 2009 | Sony VAIO VGC-RB53 PC Desktop
Buy ram
the crucial website will tell you how much
Apr 20, 2009 | Computers & Internet
I FOUND 1 MEMORY SLOT
Hi there.
The memory slots are more or less on top of each other.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Acer Aspire 4315 Notebook
ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
YES THE FREQUENCY OF BOTH RAMS DO NOT MATCH ... THATS BOOTING WITH EACH BUT ONLY ONE BY ONE ... YOU NEED RAMS OF SAME FREQUENCY AND SYSTEM WILL SUPPORT BOTH OF THEM TOGETHER ...
Sep 16, 2008 | Computers & Internet
Ram Memory
I did this 2 days ago on my gf's aspire 5315-2153 (walmart special $348). the underside panel has four tiny screws which must be removed and then the fun begins. The plastic panel is large and doesn't want to be removed. After 20 minutes of cursing, i was able to get it out with two hands and a small screwdriver. The plastic panel has about 7-8 tabs which also hold it in place. The original two memory modules must be removed and the two new ones installed in their place. i bought crucial memory from newegg.com (CT2KIT12864AC667) for $17 delivered (took a week to get) which was much cheaper than buying it direct from crucial.com Save the old memory modules just in case you have a problem with the new ones. After putting them in, I restarted the computer and it booted up fine. No BIOS changes or any of that were necessary. So for $17 and about 30 minutes, this lappy is now running strong with 2gb instead of 1gb. Initial impression is that it boots up faster and shuts down faster but that is about it in terms of improvement!!!
Aug 24, 2008 | Acer Aspire 5315 Notebook
Ram upgrades
Does'nt matter which goes where as long as they are all compatible with the motherboard.
Mar 18, 2008 | E-Machines eMachines Desktop PC
Acer Aspire E500 PC Desktop Logo
157 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
