Question about Kodak EasyShare C182 Digital Camera
When i turn it on the zoom opens but the screen is black and wont take pics when i shut it off the zoom starts to go in but comes back out
I have to push the zoom in when i hit the power button
    Genius:
  • Kodak Master
  • 1,019 Answers
Camera suffers from serious problems. needs to be repaired or would be cheaper to replace this model.
Posted on Jan 24, 2013
jackboy
  • 2985 Answers
SOURCE: powers off only when I hit the zoom button......
The zoom mechanism is shot- Kodak will quote a repair price you wont like.
Posted on Oct 05, 2007
  • 126 Answers
SOURCE: Kodak Easyshare DX7630 screen is black and won't take anymore pic
your image sensor is bad it will have to be replaced by a camera technician .
Posted on Jun 03, 2009
SOURCE: Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Posted on Aug 06, 2009
  • 12 Answers
SOURCE: screen turns black after taking a picture
If the cam has never been dropped i would suspect a software issue.
Check the manual and see if there is a master reset, if so try it and see if that solves the issue. if not i would tend to think you will need service.
As i doubt there is little that can be done from the outside of the cam to
correct the problem.
Posted on Aug 11, 2009
leepania
  • 1099 Answers
SOURCE: My Kodak V1233, isn't working right. If I turn it
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 12, 2009
Camera zoom does not work
that is an error condition on the lens
take it back its jammed
Apr 19, 2014 | Fuji Film FinePix JX500 14 Megapixel...
DSC-HX5, Lens is Stuck in Zoom out mode. Turn On works but screen stays black. Automatically turns off after 10-20 seconds.
Since there is nothing you can do to fix this at home you have 2 choices, replace the camera or send it back to the manufacturer for exchange (very expensive)
Jul 27, 2017 | Sony Cyber-Shot DSCHX5 Digital Camera
LCD screen Black - manual Zoom not working
Hey,
It sounds like you're having the same problem,
Here is a link
http://www.e18error.com/repair.html
It may be usefull,
good luck mate!
Jul 26, 2010 | Canon PowerShot A630 Digital Camera
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Iphone freezing when i took a call now wont go back
I use my iphone as my alarm. The alarm won't off but when I went to shut it off and touched the OK button it wouldn't do anything. It froze! The screen went black with the "Snooze & Ok" buttton is still showing. I tried turning it off but it won't shut off. The only buttons that's working is the volume and the silent button. I can still receive calls but can't hear them...
Sep 09, 2009 | Apple iPhone Smartphone
Kodak easyshare c533 lens is stuck
after 4 seconds view screen pic melts and goes blurry
Oct 19, 2008 | Kodak EasyShare C533 Digital Camera
I have a very nice 35 mm nokia camera with a zoom lens and lately when i get the pics developed, the pics come back blank or black. what could be the problem?
Black pictures mean under exposed or un- exposed film
Underexposed film can mean incorrectly set up or metering failure
Un exposed film simply means the shutter has failed
Open camera and look through the back and operated the shutter
Does it work?
Sep 02, 2008 | Cameras
Zoom Error
this usually happens when you turn on the camera with the lense cover still on. just turn it off and remove the lense cover and turn it back on again. hope this helps.
Mar 16, 2008 | Fuji FinePix S5100 Digital Camera
I can not take pictures
update, possible solution..
I pulled the batteries for 24 hours, attempting to force a reset of the camera. Today it worked, took pictures and zoomed just fine. I shut it off after about 10 pics and turned it back on and back to the start... Took the batteries out for a few minutes and put it back in and back in business. Hope this helps at least get SOME functionality out of it. This won't serve as a long term solution for me, but perhaps will lead towards a full answer.
Dec 17, 2007 | Olympus Camedia D-540 Zoom Digital Camera
Canon sd450 - spilled a little lemonade on the camera
maybe the lemonade was sticky and the shutter can't open? otherwise the circuitry could have been fried if you turned it on before it dried inside.
Nov 09, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
Kodak EasyShare C182 Digital Camera Logo
21 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
