Question about Midland 1001Z 40-Channels Base CB Radio
I can't hear.
With my CB everyone else can hear me and the signal transmits fine and I have tested to see that my CB is picking up the signal, but their voices don't play through my mic of my PA.
  • 32 Answers
I am not completely sure i understand whats going on. it seems like it could be a few things because of different parts of the question.
how? A meter on your radio should either light up or a needle should swing if you are receiving.
A Mic is a microphone, i think you mean speaker.
Ok this may be the cause of the problem....
Try a couple of these.
First, unplug the PA Speaker, this simple act should make you to be able to hear the incoming signal.
Make sure the CB is on AM or CB not PA
If you can not hear the speaker may be busted or an internal part may be blown. (needing the expertise of a required technician)
If you can here when you do this make sure the speaker is working by plugging it into a computer. (mp3 players will barely put out enough power to make a sound audible) if this works, make sure you plug it into EXT not PA on the back of the radio.
one more thing to check. i dont know what radio you have but try turning it untill you hear static. if its all the way the other way you may not hear anything, also turn up any RX or rec. knobs.
i have limited knowledge about whats going on, but i hope this will help fixya
Posted on Jan 11, 2009
Transmitting and Receiving Signals
Modulation being muffled could be the mic or it could be an adjustment in the unit.
May 21, 2013 | Cobra 19 DX IV CB Radio
Handheld Radio Shack CB radio TRC-230 I can hear people but no one can hear me
First, lets make sure that the unit does transmit. Get a power meter and see how much power it transmits. If no power is being radiated, you need to have a technician check out the unit.
If you have power then pick a less crowded time to test out if anyone can hear you. Other people with more powerful equipments can only be a problem when you are transmitting on the same channel and both of you happen to transmit at the same time all the time. Chances are remote that this is your problem. Good luck. es
Mar 23, 2013 | Radio Communications
No signal at night
What you are hearing during the day must be what is called "skip". Skip is active during the day where you will hear radio operators from hundreds of miles away. Their signal is bouncing off an atmospheric layer well aboe the earth's surface. At night this atmospheric layer degrades and then so does the skip. Unless there is someone close to your vicinity transmitting on the channel you are listening too, you will not hear much at all. Try changing the channels until you pick up a conversation.
Dec 13, 2012 | Cobra 29WXNWBT CB Radio with Bluetooth &...
I can hear everyone talk to me but i cant transmit to them,they can hear me key up but no voice to them.i have checked all connections and grounds,still the same.
Mic may have audio wire broken in cord at mic plug wire solder connection.
1- Shield
2- Audio
3- Transmit
4- Receive
notice the numbers on the black plug after you pull it out of the radio.
Sep 12, 2011 | Cobra 29 LTD CB Radio
I have a Clarion factory audio system on my 1999 Yamaha Venture motorcycle that hums when I transmit - other radios show signal strength but hear no sound.
You probably should inspect the CB antenna and connections.....I would really recommend not trying to transmit till its looked at as a bad antenna can draw too much power transmitting and could damage the CB.
Aug 26, 2011 | 1999 Yamaha Royal Star XVZ 1300 A
My cb transmits with a very weak signal and won't recieve anything. The weather band recieves with no problems. I couldn't even pick up a signal on my SWR meter but a friend of mine tested it on his home...
There are a few things that could be wrong. If there is something wrong with the mic, you may not hear anything on the radio. but weather will work.
Other then that, the receive section of the radio could be blown.
Try a new mic, and if it doesn't work, then there is something blown in the radio. It needs a tech.
Sep 25, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Can recieve but not transmit
The mic wires are soldered incorrectly. Get another cobra mic for that radio or have a qualified radio tech correct the wiring.
Apr 15, 2009 | Cobra 29 LTD CB Radio
Not real sure
Make sure that the mike gain & RF gain controls are turned clockwise & the squelch is counter-clockwise.
Jun 07, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Recieving problems
turn the RF gain all the way up and leave it there. Also turn the squelch down until you hear white noise, then turn it up just until it goes away.
RF gain is how sensitive your receive is. The higher it is, the more range you have. There really is no need to turn it down ever, unless you are trying to not hear some one out in the distance. Normal operation, RF gain should be all the way up.
Now squelch is used to quiet non signal noise. Like white noise or interference noise, Or other radios with a really weak signal that you can't hear completely any way.
You just want it so it just quiets the fuzz noise. Depending on background interference and the amount of radio traffic, the may have to be adjusted to silence the noise you don't want to hear. When a strong audio signal is received, it will break the squelch, the higher the squelch is set, the stronger the signal needs to be to break it, otherwise it will silence it.
May 03, 2008 | Cobra 19 DX IV CB Radio
Midland 1001Z 40-Channels Base CB Radio Logo
290 people viewed this question
Top Midland Radio Communications Experts
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
