Question about Pass & Seymour 1595SWTTRWCC4 COMBINATION GFCI REC/SWITCH 15A WHITE
I have two hot wires and two neutrul wires coming from the box. how do I hook them up so everything works
  • Pass & Seymour Master
  • 5,245 Answers
Open following link to see specific wiring diagram:
http://waterheatertimer.org/How-to-wire-switches.html#combo2
There is only one Hot wire inside each household 120volt single-phase wall or ceiling box.
Unless wiring is off-code.
Hot wire is usually the black wire coming from circuit breaker.
White wire that arrives inside same cable with Hot black is the Neutral wire.
The other black and white wires evidently go to light fixture.
Which wire is Hot?
Separate black wires, turn power ON, tape tester leads to wood sticks, test each black wire to bare ground wire. Tester lights up on hot wire. Or separate black wires and use non-contact voltage tester.
Posted on Nov 10, 2012
Replaced stereo system in my 2000 sonata. When I turn off the ignition and restart it the stereo resets it self it has no memory.
you did not hook up the memory power wire, the factory wirring has two power wires a orange wire that is hot all the time and this is the one you hook to the memory circuit and there is a yellow wire that is hot with the key on this is the power supply wire for the unit it take both wiires to make the system work....
Sep 01, 2011 | 2000 Hyundai Sonata
WAS IST HPSU-0004 WIE KANN ICH ES INSTALLIEREN
Hi!
Erstens verzeih mir bitte wegen Schreibfehler. Meine Muttersprache ist nicht Deutsch.
Jetzt zur loesung:
1. Auf der support-seite von HP suche und lade herunter die (sehr grosse) Datei welche die FULL drivers und applications fuer dein Drucker beinhaltet;
2. Starte die gerade heruntergeladene Datei bis zum Punkt wo es anbietet die software zu installieren;
3. Click NICHT auf "Install", sonder verlasse den Installer (z.B cancel). Am diesem zeitpunkt haben wir auf die festplatte alle spaeter notwendige Dateien;
4. Jetzt finde den Ordner wo alle diese Dateien gespeichert wurden. In diesem Ordner soll der Ordner "setup\hpupdate" sein. (der Ordner musste in TMP oder TEMP sein - am besten verwende die option SUCHEN;
5. Nur nachdem du den Ordner gefunden hast koennen wir fortsetzen:
6. In Windows Systemsteuerung, programme entfernen, werden wir das programm"HP Update" entfernen. Kann sein dass mache Fehlermeldungen dabei entstehen, aber das ist normal unter diese Umstaenden
7. Jetzt gehen wir zurueck zu dem Ordner den wir bei Schritt 4 gefunden haben. (setup\hpupdate), und doppleclick die einzige *.msi Datei die es dort gibt. Dadurch wird die HP Update Utility neu und richtig installiert;
8. Wenn die Installation (Schritt 7 ) vollendet ist, kann die HP-Update utility ausgefuhrt sein, um updates fuer alle Deine HP anwendungen zu erhalten.
Hoffe es war hilfreich
Beste Gruesse!
Aug 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
My memory wire is yellow & my power wir is red. I have them all hooked together so that the stereo will turn on. My kenwood cd player will not hold memory. Can you help??
The red wire goes to the ignition 12 volt source, and the yellow to the battery 12 volt source. The yellow wire must remain hot with the key out to retain memory.
Nov 19, 2010 | Kenwood Car Audio & Video
I just bought a switch to control both fan speed and light control (dual switch) i hooked it up every thing worked fine. then to realize that the outlets that follow dont work. just as a clue on the...
The key seems to be that you changed wiring in the ceiling box.
I suggest you make a drawing of the wires before and after. Track the route that the Hot wire takes.
The key question is this: Does Hot wire from breaker box arrive in the ceiling box first? Or does it arrive in wall box first?
I think Hot from breaker arrives in wall box first. And from there Hot wire goes to ceiling box ... and from ceiling box the hot wire goes to other plugs in room. If this is true, you will be one wire short for installing fan control switch.
I always make a drawing of existing wires before starting, so I can put it back the way it was. It sounds like you got a good handle on which wire goes where.
We used to solve the one-wire-short problem by making a simple project bigger. Figure out which direction ceiling joist run. See if you can slide fish line from fan ceiling box over to wall. If that works. Over at the wall, chop small hole in ceiling so you can feed wire up to fish line. Pull wire over to ceiling box. Next, staple other end of wire along ceiling over to location above wall box. Chop another small hole so you can feed wire down to wall box. And then install beautiful crown molding to hide the mess, and paint the room so you need new furniture.
Oct 02, 2010 | Electrical Supplies
1988 Kawasaki 250 El Eletrical
You might try to check the horn first by shortcircuiting it ( two leads from the battery.) If the horn itself works , find your way up: check with your contact switched on, the wires that lead to the horn by using a small light bulb or an Voltmeter: if you push the horn button, the licht should go on or the voltmeter should read 12 v.. If not , check the horn switch itself, there could be some corrosion. Good luck , allways a puzzle , the electricity..
Apr 02, 2010 | 1988 kawasaki ZL 250 Eliminator
Does the red wire coming out of the ceiling go to the blue wire in the fan. i cant get the lite kit to come on
The white wire in your ceiling box is USUALLY the neutral wire. Green or bare wires are ground wires. Any other colored wires are generally hot, switched or unswitched. If changing the position of a wall switch makes a white wire hot, it is NOT a neutral wire. You need a test light, generally an inexpensive neon test light available at any hardware store, and a book on basic wiring would help. To control the fan and light separately, assuming you have not installed a wireless control, you need two switches, one for the fan and one for the light. If you do not have these, you need a wireless control unless you have a spare wire in the wall switch box or you need to be satisfied with controlling the separate functions with the pull chains. Check the ceiling box wires. Put one lead on the ground wire or, if you have steel boxes, on the box. Remove the wire nuts on the other wires, being careful not to touch any wires or touch any of the wires to each other or the side of a metal box. Touch the other lead to the other wires, one by one. If the light comes on, the wire is hot. Try the wall switch(es) on and off and see what changes. To make the fan or light work it has to be hooked up to a neutral wire (white, never hot regardless of any switch positions) and a hot wire. The same is true for the light kit. If you do not have or want two wall switches, one for the light and one for the fan, you need to identify the wire that is hot when you turn on the wall switch and hook it up to the black (fan) wire AND the blue (light)wire. You then control both with the single wall switch in conjunction with the pull chains. If you have two switches in the same wall box, and they make two different wires hot in the ceiling box, hook one to the black fan wire and one to the blue light wire. If you're set up with only one switch, and you're lucky, you may have an extra wire in the same cable from the ceiling box to the wall box, with a wire nut on each end. In that case, install a second switch for the light (or a combination switch designed to control both a fan and light). Hook the hot wire from the wall box to both switches (or the hot terminal on the combination switch) and the other two wires to the other two terminals that go to the ceiling box to feed the light and fan. Never use a light dimmer switch to control a fan or a fan speed switch to control a light. If two or more switches in different areas controlled the original fixture in the ceiling box, things can be complicated. If the same wall switch makes two different wires hot depending on it's position, for example, it's a three or four way switch. The above description also assumes the wall box is fed from the ceiling box, but the opposite may be true. There may also be wires in either box that are feeding other circuits in the house. Electricity can kill or burn down your house. If unsure of what you are doing, hire a licensed electrician. Also be aware that if you touch the leads of the test light to two wires that are both hot, the light may not come on. Always test with one lead on a ground or a wire that you are sure is a neutral wire. I recommend tuning off the power to all the circuits in the boxes that you are working on, after you have determined what the wires are, by shutting off the circuit breaker(s) or removing the fuse(s). There may be more than one circuit in a box.
Feb 12, 2010 | Hampton Bay 24002 Ceiling Fan
1999 jeep grand cherokee heater fan quit. 40amp fuse under hood good. both wires at motor test hot. motor turns strong when wired direct to battery. now what?
the blower motor resistor is bad replace it and it will work good as new the resistor is located in the same heater box as the blower motor mounted on the outside of the heater box follow the wirring from the blower motor to find it or just simply buy the part and match it up
Jan 11, 2010 | 1999 Jeep Grand Cherokee
Generator wirring
The generator output hooks to the transfer switch. It senses the power from gen or land power and switches accordingly to allow power into the breaker panel.
Jun 21, 2009 | Honda 6370C - Parallel Power Kit For ...
Electrical box not working
unfortunately it sounds like the main electic wire is shorted out. Not the one to your fan, but the one that provides the power supply FOR the fan. The only way i know to fix this is to get an electrician. I am certain the wire needs replacing.
Nov 29, 2008 | Hunter 52" Ceiling Fan With Light And...
Wont turn on
There is a short some were check all hot wirs for any bare spots . If that is not it most likley when you installed it you blue italways hook main hot wire last.
Oct 25, 2007 | Kicker ZX10001 Car Audio Amplifier
Pass & Seymour 1595SWTTRWCC4 COMBINATION GFCI REC/SWITCH 15A WHITE Logo
139 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Mike
Mike Squire
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
