Question about GE 28112EE2 Cordless Phone
I dont have caller id but my number is still blocked
Everytime i call someone i get a message that this phone doesnt recieve phone calls from a blocked number
    Scholar:
  • 47 Answers
If you have a private number or unlisted number, you must dial *67 before dialing the number. This is only needed if the number you are calling rejects blocked/private numbers.
Posted on Jan 06, 2009
  • Ron Jan 06, 2009
    I am sorry, I meant *82 not *67. *82 unblocks your number, only on a per call basis.
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
I just received KX-T7730 phone with an LCD screen and it is not showing the caller ID # that is dialing in. It only displays CO 1. The previous phone similar to KX-T7730 shows the caller id #. So how can I...
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
Hope his help and rate please.
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
How do i block my number on an outgoing phone call?
i found the answer at http://support.sprint.com/support/article/Block_your_Caller_ID_on_your_outgoing_calls/case-wh164052-20100907-100732?&INTNAV=SU:SP:HDIB
Last Updated: Sep 08, 2010You can block your Caller ID information (name and phone number) on a call-by-call basis. Just dial *67 before dialing the number you're calling, and your information will not show up on their Caller ID display.you can also go to http://support.sprint.com/support/article/Know_the_difference_between_restrict_and_block_on_Caller_ID/case-wh164052-20100907-101149?&INTNAV=SU:SP:HDILast Updated: Sep 08, 2010Restrict Caller ID is a restriction that is placed on your account to completely block your information (name and phone number) from being displayed on any call you make. This has to be done by contacting our Customer Care team.Block Caller ID is something you can do yourself directly on your phone by dialing *67 before the number you're calling. This only affects one call at a time, so you have to dial the code before every call you want to block your Caller ID.**************i did some research and found the answer, please provide me with FAIR feed back i.e. 3 or 4 thumbs up. according to sprints website and also htc support forum there is no way to block the caller id automatically. dont kill the messanger i just wanted to pass the info found on htc and through sprint.
Jan 07, 2011 | HTC Snap S522 Cell Phone
When someone calls me,it displays 'call' on Nokia E71,what to do? I don't have duplicates on my phone and when i type in *#30#,it says 'number of caller is not available'.Please help me
In some instances the caller might have caller-id blocked or a *67 manaul caller id block.
You are correct if you have a duplicate contact entry it does not show the name of the caller incoming.
Nov 19, 2009 | Nokia E71 Smartphone
I have a Nokia e71, and everytime I call someone the caller ID on the person's phone says "private caller". How can I change this?
Telephone settings
Select Menu > Tools > Settings > Phone.
Select from the following:
• Call — Define general call settings.
Call settings
To display your phone number to the person you are
calling, select Call > Send my caller ID > Yes. To let
the network determine whether your caller ID is sent,
select Set by network.
Nov 13, 2009 | Nokia E71 Smartphone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Blocking of caller id
I can help you with that, if you dial *67 and then the phone number, for example ( *67-715-392-0123 ) it should block your phone number from comeing up on caller id...........Hope this helps........
Jun 27, 2009 | Nokia N70 Cellular Phone
LG KU990 Caller ID
  • If you answer the call, the number (or number and name) stays on the display until either you or the caller hangs up.
  • If you do not answer the call, most display units keep a record of the calls received, including the phone number (or number and name), date, and time.
  • If the letter P, priv, private, or a similar term appears, the caller may have blocked the display of his or her number.
  • If the letter O, ????, out of area, or a similar message appears, the caller either is in an area that does not support Caller ID or has placed the call using operator assistance.
  • Caller ID comes with Anonymous Call Rejection, which, when active, allows you to reject calls from callers who block their number. Your phone does not ring, and the caller hears a message saying blocked calls will not go through.
    • To turn on Anonymous Call Rejection, press
      *77 on a touch-tone phone (or dial 1177 on a rotary phone)
    • To turn off this service, press
      *87 on a touch-tone phone (or dial 1187 on a rotary phone)
or go through
http://www.decommunications.com/support/topics/repairs/phone/no-id-name.php
Oct 13, 2008 | LG KU990 Viewty
Long distance text message will not send. error code 00107. I would like know what that code number means. bat999@videotron.ca
The caller has caller ID block placed on their acct/ this can interfere with sending sms messages to a phone that does not accept sms or voice calls from a line with caller id block/ I had cust resprond to a text with send new to area code plus 10 digit number/ success/ removed caller id block from service and had cust click *star 67 then area code plus 10 digit number/ if you choose to have your contacts entered with *82 area code plus 10 digit cell number you will get error 00107/ can not receive or respont to blocked calls particularly long distance/resolves iss/ I am a technical suport agent for sprint/ Happy Texting
Jun 06, 2008 | Cell Phones
Blocking a phone number
I need you make and model as each phone is different.
Oct 26, 2007 | LG VX5200 Cellular Phone
GE 28112EE2 Cordless Phone Logo
242 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
