Question about Kodak EasyShare C340 Digital Camera
I want to upgrade my card to more capacity. Mine is 512MB (came with the camera) Have tried ScanDisk 4gb and 8gb..The camera will not accept or format either. What do I do,,
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
The C340 works with SD cards, which top out at 2GB. Your new 4GB cards are actually SDHC cards. While they fit into the slot, they are electronically incompatible and will not work with this camera. You need to use SD cards, 2GB and smaller.
Posted on Nov 09, 2012
Agent Allan
  • 480 Answers
SOURCE: Memory Card Requires Formatting
Hey B418,
Formatting will delete all your pictures on your camera or memory card. The camera might be prompting you to format because the the camera's memory is full. To avoid losing your pictures I would connect your camera to a computer, download your images to your computer first, and then format the memory.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 01, 2008
  • 203 Answers
SOURCE: just bought a 4gb kodak
No way-that model will not support a 4gb card-yes it may fit but camera is to0 old for newer sdhc cards-go back to 1 or 2 gb max and no problems! 4gb only work on cameras within last 2 years
Posted on May 24, 2008
  • 39 Answers
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
Posted on Nov 28, 2008
  • 102366 Answers
SOURCE: My Kodak P850 do not accept SD cards 4 or 8GB,
Technically speaking, SD cards only go up to 2GB. (Actually, some very rare 4GB SD cards exist, but I doubt you have one of those.) Cards 4GB and up are SDHC (Secure Digital High Capacity) cards. Your camera was designed before the SDHC specs, and thus is not compatible with SDHC cards. This is not something that can be changed in firmware, since there is a hardware compatibility issue.
SDHC devices will accept SD cards, but the opposite does not hold true. SD devices will not accept SDHC cards.
Posted on Jan 18, 2010
  • 102366 Answers
SOURCE: How can you format a SD 4gb card for the Kodak
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
Posted on May 13, 2010
Kodak EasyShare C340,came with 512mbCard have tried two ScanDisk 4gb cards. It will not format either,,not locked. Do I need a special card for this camera
Nov 09, 2012 | Kodak EasyShare C340 Digital Camera
I have a Pentax Kx and recently bought an 8Gb memory card. However I get a lot of blank images with the error message 'image cannot be displayed' especially if I use the continuous shooting mode....
Dear,
First of all you need to confirm that what kind of memory card your are using. The officially recommended type and brands are here
Toshiba *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
Panasonic *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
SanDisk *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
rather than these might be problematic or not compatible...
Check this first
Best of luck!
Jul 10, 2011 | Pentax Cameras
What memory card does fujifilmpix ax200 take
The camera takes 2 kinds of memory cards.
It supports 512MB to 2GB SD memory cards and 4GB to 8GB SDHC memory cards.
Regards.
Dec 09, 2010 | FUJIFILM FinePix AX200 Digital Camera
If it says up to 8gb on your vivitar instructions what does that mean
It means that memory cards of sizes up to 8GB will work with this camera. 8GB, 4GB, 2GB, 1GB, 512MB, etc. Such cards will work. 16GB and 32GB cards will not work.
May 25, 2010 | Vivitar ViviCam 8025 Digital Camera
Scandisk memory card keeps saying error
Some cameras will not work with the larger flash cards. Also the SDHC requires an adapter that accepts the high density. Many built into the computers do not accept the high density and will demand they be formatted. Verify the requirements of the devices you have for compatibility.
Apr 27, 2010 | SanDisk 4GB microSDHC Memory Card
I bought a new SanDisk 4GB SDHC Card. When I put it in the camera the camera comes on but will not go past the intro screen "Vivitar-We makeit easy". If I take the Card out it works. Is the 4G card not...
I haven't heard of anyone having this problem, and they're all using 4gb Scandisk cards, so...I would suspect that the card is bad. Try to get it exchanged, but first try an older, card you used before, to make sure the camera is ok as far as detecting a card. Hope this helps.
Apr 18, 2010 | Vivitar ViviCam 5100 Digital Camera
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Dec 27, 2009 | Pentax Optio S4 Digital Camera
I carent get a memory card to work at all. Tried a 2gb and it comes up with ERROR and askes if i wanna format the card, so I formated the card, and it went to picture display screen, took a photo and it...
these cards is too much for the cam can hold and would cause errors just like u said try 512mb memory card or even less should work good and then clean it up by downloading all on ur pc and re use it i use 128mb even for mine lol,hope that helped ty
Oct 30, 2009 | Vivitar ViviCam 3750 Digital Camera
Scandisk 4gb ultra car will not format in any of my cameras
put the card into a card reader and format it using your computer...
Jul 21, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Card has wrong format
I also have the same problem, but I found the solution. The camera will only support cards up to 2GB
Jun 27, 2008 | HP PhotoSmart M627 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
24 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
