Question about IBM ThinkPad T20 2647 Notebook
The clock on my laptop dosn't keep the right time
I know the main battery needs to be replaced because it only last about 10 minuets.
  • 37 Answers
It may not be the main battery that's causing the problem. There is a small button battery on the motherboard of all computers and this ensures correct system time.
You probably need to replace this.
Posted on Jan 05, 2009
Equity model 29002-1
Anon, replace battery with a good strong AA Energizer or Duracell Alkaline not a cheap battery, make sure battery contact point in clock are clean and no corrosion. If this does correct the problem, the clock mechanism is probably just wearing out from age which is normal unless it is digital. Read through the links and learn how some time mechanisms can be made to work properly again. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Maintain Battery Powered Quartz Wall Clock
Save Money Quartz Battery Wall Clock Repair Fixing Disney Winnie The Pooh...
Clock repair and troubleshooting
How to identify and replace quartz clock movement
Feb 15, 2014 | Equity By La Crosse Equity 29003 10"...
Hp pavilion clock won't keep time
try finding the time zone you are in and use that to set the time, changing the numbers individual will end up with the time going back to the time zone time. So change the time based on the time zone
Aug 04, 2012 | HP Computers & Internet
The clock on the laptop does not keep the right
Why does the clock on my laptop keep incorrect time? Your laptop has two or more clocks, and FreeBSD has chosen to use the wrong one.
Run dmesg(8), and check for lines that contain Timecounter. The last line printed is the one that FreeBSD chose, and will almost certainly be TSC.
# dmesg | grep Timecounter
Timecounter "i8254" frequency 1193182 Hz
Timecounter "TSC" frequency 595573479 Hz
You can confirm this by checking the kern.timecounter.hardware sysctl(3).
# sysctl kern.timecounter.hardware
kern.timecounter.hardware: TSC
The BIOS may modify the TSC clock--perhaps to change the speed of the processor when running from batteries, or going into a power saving mode, but FreeBSD is unaware of these adjustments, and appears to gain or lose time.
In this example, the i8254 clock is also available, and can be selected by writing its name to the kern.timecounter.hardware sysctl(3).
# sysctl -w kern.timecounter.hardware=i8254
kern.timecounter.hardware: TSC -> i8254
Your laptop should now start keeping more accurate time.
To have this change automatically run at boot time, add the following line to /etc/sysctl.conf.
Or
Take it back to the place where you purchased it and explain the
situation to them as it is still under warranty.
Jun 04, 2010 | HP Pavilion ze2000 Notebook
Sony vaio vgn-fs775p laptop real time clock not keeping time
Hi
thank you for your query
If the time is not keeping up then it would seem that you will need to change your CMOS battery, this is a small battery found on the motherboard responsible for clocking etc
The battery is cheap to purchase, however I do highly recommned the laptop be booked into a reputable PC shop for replacement as you will need to take the whole laptop apart to get the motherboard
I hope this has been helpful
Mar 09, 2010 | Sony VAIO VGN-FS790 Notebook
Hi,the clock my acer aspire5630 stops as soon as it is powered down? Could it be internal battery ? If yes how do you replace? Thanks
yes the problem is with your internal battery..don't take the risk to replace it yourself..contact your customer support or the shop where you bought it.
Feb 07, 2010 | Acer Aspire 5630 Notebook
Inspiron laptop clock incorrect
Go into the BIOS by turning on the laptop and pressing F2. In there i believe on the main screen you can change the time and date. Do that, save changes and exit and then go into windows and see if it keeps the right time and date.
Let me know how it goes.
May 12, 2009 | Dell Inspiron 1525 Laptop
Date keeps reverting to 10/08 and clock won't keep time
i donno much........ may be ur comp inbuilt[battery used 4 time setting] battery would hav run out....... i think so
May 11, 2009 | Compaq Presario 1275 Notebook
Clock not keeping correct time
The CMOS battery keeps the laptop configuration stored in the CMOS chip and the main battery has no effect on the CMOS.
If the date and time drift off, it indicates the CMOS battery is nearly flat and needs to be replaced.
If you had ticked the Daylight saving box in the Time Zone tab in Control Panel - Date and Time setting then the time would automatically adjust for Daylight saving.
Apr 05, 2009 | IBM ThinkPad T40 2373 Notebook
My laptop will not keep the correct time or date.
ibms r20 is a old computer mite try battery plus for new battery or www.ebay.com
Jan 05, 2009 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
62 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
