Lennox Conservator III G16, Furnace, Burners stay lite for 90 seconds; no blower; but exhaust fan runs continuous. If I use a jumper from the white heat wire (including white heat wire) to the green blower wire terminal (removed the green thermostat wire) the blower fan runs (non-stop) & igniter & burners restart every 10 mins. when I remove the jumper (& wire to specs from the thermostat to the furnace) igniter & burners kick on for 90 seconds then nothing on the unit works except the exhaust fan which runs non-stop. In order to reignite the furnace I have to turn the thermostat heat switch off then on again. Can anyone tell how to troubleshoot this problem(s)?
JetJedi221
  • 25 Answers
SOURCE: The furnace burners won't stay lit
Could be a couple things. First and easiest is to check your intake combustion air supply. If it is blocked by anything or just not enough flow, it will put out the flame. Next would be the flame sensor, usually a temperature probe near the flame front. If it's not reading an increase in temp within a pre-programmed time, it will kill the flame. It can be checked with a multimeter.
Posted on Jan 25, 2008
wbwill
  • 68 Answers
SOURCE: Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Posted on Nov 22, 2008
SOURCE: Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Posted on Jan 06, 2009
  • 2920 Answers
SOURCE: Furnace fires for 10 seconds then cuts off
have the thermocoupler checked
Posted on Jan 17, 2009
SOURCE: Why Wont My Bryant Furnace Stay Running
You have a dirty flame sensor, it needs to be replaced
Posted on May 03, 2009
Lennox 80 MGF furnace heat only. Both diagnostic lights are indicating everything is ok with the ignition control but the furnace main fan runs continuously. The fan is on automatic at the stat
So no heating just blower? If you have a g wire on the tstat remove it first. Then possibly a stuck relay. Obviously if the blower stops when g removed the tstat is bad.
Aug 14, 2017 | Heating & Cooling
Lennox G12 furnace blower will not come on.
It may be a bad fan limit switch or a bad fan motor.to check the motor turn the thermostat fan setting to fan on or jumper between R and G where the thermostat wires connect to the furnace. If fan comes on the fan motor is probably good and it is probably the fan limit switch. If it does not come on it is probably the fan motor . This is assuming you haven't installed a new thermostat in which case it may be a heat anticipator setting too low.hope this helps.
Dec 07, 2013 | Heating & Cooling
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
I have 1990 Armstrong gas furnace Ultra III 80, Model EG6G75dc8-4 .\r\nWhen I turn thermostat up , furnace comes on, burners come on, motor that I believe turns blower turns on but i AM NOT GETTING AIR...
have you checked your filter yet? the other thing to check is open the fan door and jumper the door switch,if there is one, and turn the furnace on. is the fan blowing air now?
Mar 22, 2011 | Heating & Cooling
Lennox Fan will not come on when set to ''auto'' position.
Expensive is relative, service calls are never free. But if you have an idea what the problem is, you are armed against an unethical service company. Now to what you describe, could be a couple things, first let me explain the difference in fan speeds. Furnaces that both heat and cool have multi-speed blower motors. High speed is for cooling and lower speeds are for heating. The fan switch at the T-Stat turns on the high speed fan relay. The lower speed fan is turned on by either a temperature activated switch (silver box mounted on front on furnace above burners) or a time delay relay which is solid state. That being said, your problem could be a defective fan switch or one of your blower motor windings has gone bad. Most motors have 3 or 4 speeds and a technician could just change speeds and all would be good. A fan/limit switch is not so expensive that you would replace the unit. Bottom line, unless your really handy, a heating company is in your future. Good luck and please rate my answer if it was helpful to you.
Dec 31, 2009 | Superior Lennox Blower Thermal Sensor -...
Blower fan runs to long
ther might be dip swiches on the circuit board you might have to change
Dec 17, 2008 | Honeywell Power Humidifier: Furnace...
My heater turns on the gas starts but then it shuts down
Try to locate the red and white wires either behind your thermostat or on the furnace itself. Jump them out and see if the furnace stays on. If you do it at the furnace you will need to hold the door switch down. If it runs fine, you have found your problem (the thermostat) if it goes out again, the furnace will display a number of blinks on the circuit board. Look on the reverse side of the furnace access door and there should be an Error Code chart to get you started figuring where to look next.
Nov 10, 2008 | Goodman GMS90703BXA Heater
Gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Dec 16, 2007 | Heating & Cooling
Heating & Cooling Logo
288 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
