Question about Garden
Norlett belt size - Garden
I have a 91Murray 42inch riding mower need proper size belt to run blade,a blade belt
Contact a local auto parts store, a full service one, bring in the old belt and they can match it.
Jun 23, 2016 | Murray Garden
What is the size of the belt on a craftsman Lt1000 21 horse Briggs and Stratton 42 inch deck
do not just buy a belt that is "close" to your size belt. the size of the belt is not always a standard size, there is a width as well as a length and also a power rating , that is critical in belt replacement. you must have the model number of the Mower unit "not the engine model" to get the correct belt. OEM belts are made to certain specifications to withstand certain actions of the mower and the wrong size belt could result in a dangerous situation of the blade not stopping or engaging sporadically, or if it is a transmission belt , the mower may not go forward or not stop moving which again is dangerous.
Mar 05, 2015 | Craftsman Garden
Looking for manual for norlett 3hp
the little conter wieghts have catch tabs to engage a hub. sticking springs are causing this problem spray some wd40 or similair blow gun and clean the entire assemble
Jun 29, 2014 | Garden
PIONEER CT-W511R BELT SIZE...
I doubt that any manufacture is going to give you belt sizes. You best bet if you do not want to measure the belt sizes yourself is just to pay Fred Marrs to do the research for you and buy a belt kit from him. It is not the least expensive way but one that eliminates you from the belt size equation.
http://marrscommunications.com/
Feb 12, 2013 | Audio Players & Recorders
John deere lx188 48 deck belt size
Contact John Deere directly to inquire about belt size.
May 26, 2017 | John Deere Starter Tractor Lx188 Kawasaki...
1996 nissan pickup v belt size
The tensioner adjustment bolt for the alternator has a lot of adjustment. Are you sure you ran it to the limits with both belts?
For instance, Gates makes belts in 1/2 inch increment lengths from 2 inches shorter to 2 inches longer than the size listed for your application. I am sure your adjuster covers more than 1/2 inch difference.
Feb 26, 2018 | Nissan Pickup Cars & Trucks
Hi I need a new serpentine belt put on my 1999 alero however I do not know how many grids the belt is supposed to have can you help me please
drive belt has 6 ribs.to buy a new belt take old drive belt with you you so you will get the right size belt.tell the auto parts store the year and model type car.tell them your engine size.and they will find the belt size you need.
Apr 25, 2011 | 1999 Oldsmobile Alero
Need belt sizes
The best is to take a thick thread - the size of the belt and place it around the flywheel- capstan and the motor pulley. Now take the correct length of this loop and buy a belt with a fraction of size smaller than the thread loop.
The belt size must be just correct to be tight around the pulley and capstan.
Jan 12, 2011 | Teac Audio Players & Recorders
Im trying to find out what size belts do i need for my 1996 nissan sentra
Look at the belts themselves, the size is written on the surface of the belt.
May 19, 2010 | 1996 Nissan Sentra
What size A/C belt does a Mazda 3 use?
It is Unusual to have a Belt "Size" As the Belt Size is determined by the Application, Why a Parts store Cant Get this Info By Use of > Year-Make-Modle-Engine Size is VERY Unusual. Try Another Parts Store, or try this Info.
NOTE: You Did Not Say Engine SIZE so this is for the 2.3L Engine
This Info is for the " 2.3L " Engine
Parts Information Part OEM Part Price Drive Belt Serpentine Belt Manual Trans L373159099U $26.99 Notes Auto Trans L37215909A9U $26.99 Notes AC Belt LF5015908 $19.95 Notes Labor Skill
Level
Mfg.
Warranty
Standard Drive Belt Replace AC Belt C 0.0 0.5 Notes Serpentine Belt C 0.4 0.6 Notes
Jul 21, 2009 | 2005 Mazda 3
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
