I had the lamp my Sony Bravia X2 replaced last nov 2011. Ithasbeen lots of green andredcolors in tv programs and have tried to change the color barson remote etc butpictures still aren't right. Its or
    Problem Solver:
  • 18 Answers
Unfortunately, this is a very common issue with Sony rear-projection televisions. The optical block fails, causing discoloration, usually blue or green. There was a class-action lawsuit which ended in 2009 regarding many Sony models, including the Bravia X2.
It can't be repaired, at least not for a reasonable amount of money.
The silver lining here is that as recently as 2011, Sony was offering discounts on brand new TVs, to people who called in with their "green blob" issues. It's worth a shot, give Sony a ring at 1-888-476-6972
Posted on Nov 17, 2012
SOURCE: Sony Bravia 40" LCD TV generating heat.
First, you will have to define what you mean by "hot to touch" ie.:
can you or can you not hold your hand on it for a few moments.
Posted on Apr 27, 2008
SOURCE: POLAROID FLM-2011 REMOTE CODES
My cox remote guide lists for the Polaroid TVs the following codes:
LCD TVs: 1276 and 1316
TVs: 0765, 0865, 1276, 1314, 1316, 1326, 1327, 1328, 1991, and 1992
I hope one of them works.
Posted on Oct 12, 2008
  • 435 Answers
SOURCE: Remote Codes for new Sony Bravia
Hi, By any chance are you trying to use the remote in dark room ?
Some LCD TVs have that problem.
if not, try this which I found in Fixya
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
provided by rmgills
Posted on Nov 17, 2008
MNfisherman
  • 11896 Answers
SOURCE: programming remote to operate Sony Bravia TV
You can find your codes here:
www.tvcodes.com
OR
www.remotecodelist.com
OR
www.remotecontrolsrus.com
Posted on May 10, 2009
welcomejee
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
"My sony bravia kdf46e3000 wont always light the lamp when first turning tv on. I can see it sparks the lamp but the lamp only stays lit for about 3 seconds. The power light on the front stays green a
does the lamp fan stay on? you can see thru the back if the fan is running. If it is not running you need to replace it.
If it running you may need a new lamp driver/ballast part# 1-480-180-21 https://www.encompassparts.com/model/SONKDF46E3000/_/_/Sony/KDF46E3000/
then there is the possibility the new lamp is bad,, Sony's like Sony OEM lamps
Dec 20, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
When I connect my pc to my Sony Bravia via HDMI cabel and try to play PES 2011, after a while, it changes color to green, and only green. When I change the "Source" on my TV, and then change it...
I would start by checking to make sure the cable is connected firmly on both ends. This could also be a case of the TV not noticing the signal in a way that keeps it from going in to a screen saver type mode. There may be some information available for your specific TV model through google.
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Open link in new incognito window
  • Download file
  • Copy link address
  • Edit PDF File on PDFescape.com
Feb 26, 2011 | Computers & Internet
When you turn it on, the green LAMP light goes on, then it clicks and the STANDBY/TEMP red light goes on, then clicks and back to the green LAMP light. It does this a few times, then The TIMER green light...
Usually if all 3 indicator lights come on this could be the color wheel is not functioning or the DINe chip needs to be re-soldered. Be sure the lamp door is closed all the way, but the color wheel needs to be looked at first.
http://tvtechwork.webs.com/
Nov 17, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Green light blinks and eventually turns solid green but only black screen no picture
When did you replaced lamp last time in tv?
If lamp has not been replaced in last 2-3 years then its time to change lamp.
Buy Sony original lamp for good picture in tv.
Aug 27, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Bravia KDL 46V100 has only black & white picture-no color
I bought Sony Color Bravia TV 60 inch, moved with it Kenya, Africa, when i try to tune the color is not coming. I can only get black and white. Please anybody with idea on how to change it for Africa (Kenya). Model:KDL-52SS100. My e-mail. fredwagah21150@yahoo.com
Jun 30, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Color is terrible - lot of green
If this is a CRT type most probably loosely connection of the other color gun. Commonly attached to the backend of the CRT.Dust problem or transistor is busted for color red and blue. Or some minor component connected to driving color.
Apr 08, 2009 | Sony Televison & Video
TV background in green and most of the people have green tint
http://www.breakitdownblog.com/class-action-lawsuit-against-sony-for-green-haze-or-green-blob-sxrd-problem/
Dec 17, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
SONY BRAVIA KDL-40S2010 40"
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
Apr 08, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
