Pelonis model hf 0034 owner manual - Heating & Cooling
3 Suggested Answers
  • 12 Answers
SOURCE: Unit won't turn off - it's a Pelonis HF-0034
Sounds like a faulty thermostat switch.
Posted on Dec 16, 2008
  • 4 Answers
SOURCE: Pelonis HF-0034 turned off 10 sec after starting; won't restart
I've been through 4 or 5 of these (and similar models) with the same problem after anywhere from 3 months to 1 year of use. It appears to be an overheat condition. Unplugging for about 10 minutes resets the overheat protector, but it will overheat again after running a short time.
Sometimes you can extend the life by blowing out the heater with compressed air, especially around the electronics at the very top and the contact points at the top of the circular heating element.
I'm currently trying a Lasko 755320 from amazon.com -- cheaper, more features, better user interface, more heat, and it almost has to be more reliable than the pelonis.
Posted on Nov 28, 2009
Model FS40-8M. Missing parts on 2 fans. Need 1 spinner, 1 plastic nut, 2 internal poles, 4 nuts, 2 screws
fans 10 a piece
spinner 2
nut 2
thats all you can get,you would have to make your own poles and find your own screws,1 305 883 0112/1 866 646 4332 , Pelonis FS40 G5 Owner Manual
its going to cost more to get parts than it is to buy a new fan,
sears has it for 32 dollars, http://www.sears.com/pelonis-fs40-8m-n-oscillating-pedestal-fan/p-SPM12785393819
Jul 06, 2015 | Dryers
HF-0020T Fan Forced heater
If the symptoms are as described, the heater probably has failed completely.
Nov 01, 2012 | Pelonis Heating & Cooling
What are the standard settings for hf 5024 sewing machine
Hello, Try doing a Websearch using your Machines name, model and other terms. You can try to find an Owners Manual and then download it.
You would enter something like HF 5024 Owners Manual, or Illustrated guide and go from there.
I once repaired the gas valving in my Maytag dryer with only diagrams pulled up on a Websearch. I then was able to order parts over the Web and never had to leave the house to get everything I needed.
Dec 11, 2011 | Sewing Machines
I do not have the manual to my fan forced heater (model HF-0034) and I am not sure how to work it. It keeps shutting off after a few seconds of heat. Then it will turn on again in 10 minutes and back off...
A lot of this, may be caused by the temperature setting and where the heater is placed. If the temperature is not set high enough, as opposed the ambient room temperature, it probably only turns ON briefly. Also, if the heater is placed near a heat source or in direct sun light, it's sensing the temperature from those sources, rather than the room air.
Try moving it to a another location and setting the temperature on the unit a bit higher.
Hope this helped you to solve the problem. Please let me know.
May 06, 2011 | Pelonis Heating & Cooling
I HAVE AN hp 0034 AND I CAN NOT GET IT TO RUN OR HEAT?? I DO NOT HAVE AN INSTRUCTION BOOK SO WHAT SHOULD I DO? I THINK IT MAY HAVE SOMETHING TO DO WITH THE TEMPERATURE CONTROL IRENE
Have you checked the outlet that the heater is plugged into, to be sure it's working. Unplug the heater and plug in a lamp. If the lamp doesn't turn on, than the problem is in the wall outlet or the circuit breaker has been tripped. Unplug the lamp, reset the circuit breaker and plug the lamp back in first. If the lamp works and doesn't trip the circuit breaker, unplug it and plug in the heater. If the heater trips it when you turn it on, there's an electrical problem in the heater.
Lowe's & Home Depot stock and sell this heater. See if either has one in stock. If they do, take it to the Customer Service Desk and they'll gladly make you a copy of the Owners Manual from the one in the box,
Hope this helps. Please let me know.
Feb 07, 2011 | Pelonis Heating & Cooling
Dec 26, 2008 | Pelonis HF-0019 OSCILLATING HEATER - OFF...
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
