Question about CRL SFC/18 x 28 Port Sunroof Molded Trim Ring - Solar High Performance Glass Shelf System
T port sunroofs
I was just looking to see if you all have the t port sunroofs in stock
If you live in the rancho cordova area..your in luck. we have a variety of sunroofs in stock and we also do repairs. any questions feel free to call 916 362 2018
Posted on Feb 05, 2009
I have a 2001 olds alero and the sunroof amongst other things arent working fuses are all good its cold out how do i manually close the sunroof?
Look for a small circular cover around the sunroof at the rear or front. Some have a plug you remove and you get a small crank handle with the tool kit.
Take a look at these links and videos.
manually close the sunroof Google Search
Nov 23, 2016 | Cars & Trucks
Sunroof needs adjustment over drivers seat ..leaks
Many fords have some minor adjustments of the roof, the brackets that support the Sunroof or power sunroof have very small Hex nuts you can loosen and shift the sunroof around, if its leaking it could be some other problem such as the drain tubes, there is usually 2 to 4 drains one on each corner that water drains down a tube through each door pillar, check the tube ports in the sunroof catch basin, they could be clogged with old leaves or dirt, run compressed air through each tube and verify at the other end its working.
Sep 29, 2014 | Ford F-350 Cars & Trucks
Sunroof leak
Are you getting a free shower when you stop after it rains? The rear drain hoses are typically connected to hoses that run back and eventually behind the rear wheel well and drain out through little rubber valves mounted in the floor back there. Give the valves a squeeze, and your water will come out. The valves get clogged with debris. You may have to do this every few months.
Nov 30, 2013 | Chrysler sebring tube. lower. sunroof...
Honda Civc Sunroof
run your vin it will tell you if it had a sunroof factory
May 13, 2013 | civic switch assembly, sunroof & map light...
My 2000 Lexus RX 300 Sunroof is stock and is not closing. electric motor seem to be working but is stock in one position. any idea how to fix this sunroof?
I have the same problem..... took my 2000 RX300 to the dealer - was told they need to replace the motor and the tracks and quoted me a price of $4500.00...... NO THANK YOU.... This dealer will not sell parts for this to local garages. Can't believe they can get away with that. Since I don't really us it a mechanic told me to take it to a glass company and just have them seal it closed to stop leaks.
Dec 04, 2010 | 2000 Lexus RX 300
Sunroof will not close
How to manually close a sunroof on a 94 lexus es300
Apr 21, 2009 | Lexus SC 300 Cars & Trucks
Part number: 316809100002-R02
I too have the same power board burnt out ... did anyone ever find the part you was looking for ... Thanks
Nov 20, 2008 | Computers & Internet
2005 Jetta, sunroof is broken
Go to the library and find the Manuel you need and photo copy it .or if you have a smart phone (goto how do I fix my vw year make and problem.and will have some thing there for shure.
Apr 02, 2017 | 1996 Volkswagen Passat
CRL SFC/18 x 28 Port Sunroof Molded Trim Ring - Solar High Performance Glass Shelf System Logo
96 people viewed this question
Top CRL Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a CRL Audio Player and Recorder Expert? Answer questions, earn points and help others
