Question about Fahrenheat FBE15002 Baseboard Heater
Heater turns on, but intermittenly
LenoxC26-51, elite series
Just installed a new thermostat today, but the problem is still occuring. The heater was blowing warm air right after I installed the new thermostat, but I just returned home (after 2 hours) and now it's 57 degrees again in the house. Checking the heater, the gas isn't blowing. Help! It's 32 degrees outside and getting colder.
  • 61 Answers
Turn the power to the furnace off and then back on and see if it resets. If not you may have a bad ignitor or dirty sensor.
Hope this helps.
Matt
Posted on Jan 07, 2009
How to pull a thermostat and where is locateed
Assuming you have the 2.7 liter engine, the thermostat is where the lower radiator hose returns to the engine.
2.7L Engine
  1. Disconnect negative cable.
    CAUTIONDo not remove pressure cap with the system hot and under pressure because serious burns from coolant can occur.
  2. Drain cooling system.
  3. Remove radiator lower hose from thermostat housing.
  4. Remove nuts from heater tube flange studs.
  5. Loosen starter bolt at heater tube bracket.
  6. Pull heater tube out of thermostat housing and position out of the way.
  7. Remove bolt and two studs.
  8. Remove thermostat housing, O-ring and thermostat.
  9. Remove thermostat housing bolts.
To install:
  1. Clean gasket sealing surfaces.
    NOTEInstall thermostat with the bleed valve located at the 12 o'clock position, between tabs on seal.
  2. Install thermostat and seal into thermostat housing .
  3. If removed, install two studs.
  4. Install thermostat, thermostat housing and O-ring and bolt. Tighten attaching bolts to 105 inch lbs.(12 Nm).
  5. Lubricate new heater return tube O-ring with coolant.
  6. Position heater return tube flange over two studs. Install nuts.
  7. Tighten retaining nuts to 53 inch lbs.(6 Nm).
  8. Tighten starter bolt to 40 ft. lbs. (54.3 Nm).
  9. Connect the lower radiator hose to the thermostat housing. Install hose clamps.
  10. Refill cooling system.
  11. Inspect for leaks.
  12. Connect negative cable.
Mar 18, 2012 | 2001 Dodge Intrepid
How to change the thermostat house in a Dodge 2004 intrepid
Check this procedure for...
2.7L Engine
    CAUTION Do not remove pressure cap with the system hot and under pressure because serious burns from coolant can occur.
To install:
    NOTE Install thermostat with the bleed valve located at the 12 o'clock position, between tabs on seal.
3.2L & 3.5L Engines
  3. Raise vehicle on hoist.
  4. Disconnect electrical connectors from engine oil and power steering pressure switches.
  5. Disconnect radiator and heater hoses from thermostat housing.
  6. Remove thermostat housing bolts.
  7. Remove housing, thermostat, and gasket.
    NOTE The OEM thermostat is staked in place at the factory. To ensure proper seating of replacement thermostat, carefully remove the bulged metal from the thermostat housing using a suitable hand held grinder. It is not necessary to restake the replacement thermostat into the thermostat housing.
To install:
  1. Position gasket on thermostat and housing.
  2. Install thermostat housing, gasket and mounting bolts onto block. Tighten attaching bolts to 105 inch lbs. (12 Nm).
  3. Install radiator hose.
  4. Install bypass hose.
  5. Connect electrical connectors from engine oil and power steering pressure switches.
  6. Connect negative cable.
  7. Fill cooling system.
  8. Inspect for leaks.
  9. Lower vehicle on hoist.
Hope helps (remember to rate and comment thius answer).
Apr 28, 2011 | 2004 Dodge Intrepid
Looking for a picture of the diagram of where the thermostat is located on my 1998 2.7 liter dodge intrepid PLEASE!!!!!
Hi, I don't have a picture, but trace the big hose from the bottom of the radiator to the engine, and it will be under the housing where the hose connects.
2.7L Engine
To install:
Mar 26, 2011 | 1999 Dodge Intrepid
This is for the 2.7L:
2.7L Engine
    CAUTION
To install:
    NOTE
This is for the 3.2L and the 3.5L:
3.2L & 3.5L Engines
    CAUTION
    NOTE
To install:
Nov 01, 2010 | 2002 Dodge Intrepid
How do I change the thermostat on a 1999 dodge intrepid 2.7L
The thermostat on the 2.7L and 3.5L engines are located on the lower left side of engine, near the front. The thermostat on both engines are on the inlet side of the water pump.
2.7L Engine
To install:
Hope helps (remember to rate and comment this).
Sep 29, 2010 | 1999 Dodge Intrepid
Remove thermostat
300M, Concorde, Intrepid, LHS, 1998-2004
THERMOSTAT - Removal & Installation
2.7L Engine
To install:
3.2L & 3.5L Engines
To install:
Hope this help (remember comment and rated this).
Apr 04, 2010 | 2000 Chrysler Concorde
How to replace thermostat
300M, Concorde, Intrepid, LHS, 1998-2004 - Thermostat Removal & Installation 2.7L Engine
To install:
3.2L & 3.5L Engines
To install:
Hope helps with this (remember rated this) Good luck.
Feb 02, 2010 | 2001 Chrysler 300M
Rheem Classic Series Super Quiet 80 gas furnace problem
I have this same POS model. It is not the thermostat. this model is just garbage and cant wait to get something that works right. i have been fighting this thing for 4+ years now.
Dec 25, 2009 | Heating & Cooling
Honeywell RTH230B will not call for heat.
On a call for heat an internal switch should connect Rh and W, if it does not the stat is bad. Try it with no wires connected.
May 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Changing out old thermostat
your old thermostat is a milivolt and the wire runs from the heater to the thermostat. You have to open the back of the new one and connect the wire as per the instructions on the wireing diagram that came with the new one. I just installed a similar one myself, you will be very happy with it.
Jan 24, 2009 | Honeywell Electronic Programmable...
Fahrenheat FBE15002 Baseboard Heater Logo
102 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
