Question about GE Security Simon 3 Wireless Home Security System
Disarming / Access Code/ Resetting
I bought a house that came with GE Simon XT now the thing is I can not disarm the unit for I do not have the code. How can I reset the code. I tried unplugging the unit and using the factory 4321 and still does not work. When I hit disarm and put the #'s in on the display does not show asterix but when I hit the enter key and put 4321 for the code I can only change the time go figure. Basically how do I disarm the unit.......
Ask seller or previous owner the code, or read in the manual how to reset the system to factory defaults
On the previous version (Simon3) it was press cancel + clock set + Minutes+ at the same time and the power up from battery
Posted on Jan 12, 2009
How do I permanently disable a GE Simon XT alarm system? Recently moved in and I want it off so I can leave my front door open for air.
do you own the property or rent . if renting there is nothing you can do but ask landlord to do something if yours you can cut the wires feeding it if you want .
Sep 10, 2014 | General Electric Ge Simon Xt Wireless...
Once a week at 4:00am my GE Simon XT does an auto phone test. At 4:12am it notifies me that the phone test has failed by beeping continuously until I press disarm. How do I get the system to stop running...
You will need the installer code to change the setting. Factory default is 1234. press the up or down arrow until "system programming" appears on display. press "OK" and "enter code" appears. Enter installer code. If it accepts it, "access codes" appear on the display. Use the down arrow until "timers" shows on display. Press"OK". Press the down arrow until "auto phone test tm" appears on display. Press" OK". use up and down arrows to adjust to "off". Press"OK". press "Status" and "timers" is shown. Press up arrows until "phone numbers" is showing on display. Press "OK" press "OK" again press "disarm" press "OK" press "Status" 4 times. You have now completed removing the phone number and turning off the phone test.
Nov 21, 2012 | GE Security Simon 3 Wireless Home Security...
Just bought a simon xt system and setting up the touchpad. the touchpad can arm the system but it won't disarm the system when I type in the code?
Note: The default master code is 1-2-3-4 when the security system is shipped from the factory. You should change your code after your system is installed. See Code options on page 26.
If you have already changed the default master code, press the numbers in for the correct code and press enter.
Barring a faulty system the correct code and then 'enter' should sub-disarm or disarm.
Aug 25, 2011 | GE Security Simon 3 Wireless Home Security...
GE Simon XT how do I reset the code
You neet to reset the system to factory defaults. Contact me and I can go through it for you.
Apr 16, 2010 | GE Security Simon 3 Wireless Home Security...
When I plug in GE Simon 3 panel it is already armed
Is your Simon 3 new or used? The default Utility Access Code 1 or 2 (i.e. the code you use when you open up the cover) is 654321, 54321, 4321 or 321. The default Master Access Code (i.e. the code you use to arm / disarm without opening the cover) is 123456, 12345, 1234, or 123. The length of the code depends on option 54. Default is 4 digits. If it's a used one that has non-default settings, you can reset memory to factory defaults.
Nov 17, 2009 | GE Security Simon 3 Wireless Home Security...
Motion sensor wasn't working, replaced battery. Now says sensor tampered. How do I reset
In your motion there is a tamper switch. make shure your caver was properly installed.
at the panel enter your code as you would to disarm your system and repeat disarming a second time.
Nov 07, 2009 | GE Security Simon 3 Wireless Home Security...
New house, existing Simon3. How to access to add new sensors
Go to the GE Security website, register and download the installation manual. Heres the link:$SM$wqmXYZlDF%2bp9wEfLtfJfgbvvO8xuG0aMyW%2fdUiDGhFTao1t%2b10TkWhV0hWcBh7VC&TARGET=$SM$$%20Instructions
The master codes are in the manual.
Or google "Simon 3 access code" or "Simon 3 ADT code" or such...
Jun 12, 2009 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
853 people viewed this question
Top GE Home Security Experts
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
