Question about IBM ThinkPad T20 2647 Notebook
My laptop will not keep the correct time or date.
I know the main battery needs to be replaced because it only lasts about 10 minutes.
  • Ambrosia Williams
    Ambrosia Williams May 11, 2010
    Your time and date is kept by your BIOS battery located inside of your laptop. These batteries are made to generally "last forever" However sometims they can go bad/die etc. I once bought a brand new desk top with a bad bios battery, so there you have it.
    Now if you can tell me the make and model of your laptop I can help you in locating it and replacing it,
    its very easy, all you need is to buy a new battery ( or if you are still under warenty you may be able to call the manufacturer and get a new one for free, and if its a dell they will send you a free one regardless ) and you will ned a mineature phillips.
Hi
Try running a bios update on your system. Make sure your charger is plugged in while running the update. Bios file can be downloaded from your manufacturer's website.
Also sometimes rarely firewalls blocks the windows from being able to access the time servers.
http://community.mcafee.com/showthread.php?t=212688
Issues like this one discussed in the above mcafee link can also cause issues like this.
Also try these things http://support.microsoft.com/kb/307897.
Well I am not sure in the earlier solution, that Dell will replace even if its out of warranty. Normally they do not. Definitely you could try if you believe that is the issue.
Rakesh
Expert Dell Laptops
Posted on Jan 06, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Ibms r20 is a old computer mite try battery plus for new battery or www.ebay.com
Advent 5431 date keeps changing back to 2008
IS your TimeZone is Correct?
Right click on your clock, choose Adjust Date/Time.
Click Time Zone Tab. Make sure your Time zone is correctly set.
Boot into the BIOS (setup) screens and check the date and time there. If the date is off by years then that verifies you need a new CMOS battery. Do not confuse the CMOS battery with the large external battery you run the computer with.
Jul 25, 2012 | Advent Netbook
HI, I have a IBM Thinkpad R50e and i had a CMOS battery failure. After replace the battery it has now started to ask me to check the date and time and when i press enter it is asking for a BIOS...
Dear john, replacing CMOS Battery usually RESET password ( plug out your laptop battery,then plug out the CMOS battery. keep it out for 5 minutes.)
After 5 minutes by, put back on the CMOS battery. put it back all together. laptop battery the last one.
On the first boot you need to set the time and date. or by pass it by pressing ESC. >> If your Operating System goes >>> right click on clock task bar >>Adjust Date/Time >> set as you wish >> apply >> ok >>>RESTART your unit.
akee_akee@live.com
Aug 16, 2011 | IBM ThinkPad R50e Notebook
How to know if the battery of the motherboard is empty
use multitester to check the battery of the cmos..
set the multitester to DCV 10..
and watch out for the pollarity of the battery..
Mar 18, 2010 | EliteGroup ECS GF6100-M754 Motherboard -...
Battry
The BIOS battery keeps the Date and Time correct, if the battery is flat the date and time will be wrong or you will get an error date and time error.
You need to replace the battery with a new one. Your friendly computer shop can help you if you don't know how to change the battery.
Sep 28, 2009 | ASI CL51-15 Notebook
Inspiron laptop clock incorrect
Go into the BIOS by turning on the laptop and pressing F2. In there i believe on the main screen you can change the time and date. Do that, save changes and exit and then go into windows and see if it keeps the right time and date.
Let me know how it goes.
May 12, 2009 | Dell Inspiron 1525 Laptop
Batterie
Your internal CMOS battery(button battery) needs to be replaced. That keeps your date & time always working. Therefore when your main Battery runs out and external power is not present the date and time goes back to the date of manufacture.....sodeep
Mar 24, 2009 | Computers & Internet
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
Bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Feb 03, 2009 | IBM ThinkPad R52 Notebook
The clock on my laptop dosn't keep the right time
It may not be the main battery that's causing the problem. There is a small button battery on the motherboard of all computers and this ensures correct system time.
You probably need to replace this.
Jan 05, 2009 | IBM ThinkPad T20 2647 Notebook
IBM thinkpad 600x
The battery that might be dead is not the main battery. It's the cmos battery, which is a coin cell battery located on the motherborad. It stores the setting in the bios and keeps the date and time accurate. Errors 161 and 163 mean the date and time are wrong. If the cmos battery is dead then, the date and time go back to 1/1/2000 every time the pc is restarted. Thus, you get the "wrong date and time" errors 161 and 163.
Dave
Jul 24, 2008 | IBM ThinkPad 600X Notebook
IBM ThinkPad T20 2647 Notebook Logo
2,022 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
