Question about Plantronics .Audio 326 Stereo PC Headset
I recently brought a PLANTRONICS .AUDIO 326 headset, the sound is perfect but the microphone doesn't work?
I got them last night and tested them in teamspeak, they were perfectly fine but today I got home and reconnected to teamspeak and was testing the microphone to make sure it still works, and it's name came up in red with a line going through it, a pop up then came but i didn't read it properly and clicked yes and it's somehow removed it completely? -tried a restart -tried unplugging and plugging back in Anyone got any ideas?
  • Nick Handley Nov 09, 2012
    Whoever posted this: "i found a solution under the control panel. to configure some settings under the default view of the control panel, use the Ease of Access icon. this does not allow you to see the actual device. by switching to the classic view, use the Speech Recognition Option, which showed that i had 3 microphone drivers installed. all that needed to be done was to select the one i was using as the default." just solved my problem :D
SOURCE: pc microphone
Posted on Mar 09, 2008
  • 5 Answers
SOURCE: Noise reproduction problems
I called into Plantronics  Support Phone Number: 1-800-544-4660  with similar issue;  Noise at other end.  Tech (Oscar) told me if I had evidence of purchase date, the one year warranty valid and to send in unit with copy of original receipt.  A replacement will be sent back within 3-5 days of receiving.  He told me to just mail it in an envelope.  No box is necessary.  Hope you call in and get same response.
Posted on Mar 12, 2008
  • 32 Answers
SOURCE: Plantronics headset crapped out after black out
The black out or power surge could have affected the unit and caused it to short circuit.  If you have purchased it within 1 year of today's date, it is still under warranty and can be replaced by plantronics.
Posted on Apr 28, 2009
  • 32 Answers
SOURCE: Headset has static
Perform a reset on the headset.  Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times.  Release both the mute button and the call answer button.  See if it works now.  If it doesn't, try a re-subscription (should be available in the manual).
SOURCE: Issue with Music Going Through Headset...
put in 0000
Posted on Dec 05, 2009
I have my plantronics discovery 975 paired to my computer and my phone. It is supposed to automatically connect when I skype and it doesn't. When it is connected it only lasts for less than a minute...
  1. Make sure you are using the latest version of Skype.
  2. Make sure that Bluetooth works on your computer. You can refer to your computer manufacturer's documentation or website for details on how to set up Bluetooth on your computer. You want to ensure that the Bluetooth software and drivers (known as the Bluetooth stack) on your computer supports the Headset Profile (HSP). It's recommended that you download and install the latest drivers for your Bluetooth stack.
  3. Pair your Bluetooth device with your computer. How you do this will depend on both the Bluetooth stack on your computer, and the Bluetooth device you are using.
  4. Make the Bluetooth device your Skype audio device:
  • Sign in to Skype and in the Tools menu, select Options...
  • Under Audio settings, select your Bluetooth device from the Microphone, Speakers and Ringing drop-down list.
  • Remember that not all Bluetooth headset features may be available when making a call with Skype. For example, whether the buttons on your headset function correctly depends on your Bluetooth stack.
Good luck from Headsets Direct!
Jul 28, 2011 | Plantronics Discovery 975 (8164001 P)...
Headset installed but doesn't work
We used the following steps recently with a customer and it fixed his problem:
In Windows, click Control Panel / Sounds and Audio Devices / Audio tab / Sound playback box / Default device: Plantronics C620 (instead of RealTek HD Audio Output)
He also had to restart WMP (Windows Media Player) and it worked great.
Good Luck from Headsets Direct!
Jun 14, 2011 | Plantronics Blackwire C620 Headset
When I plug in my Audio 625 Plantronics to my usb port it shows an error - Device not recognized, please help..
If you are using a Mac computer your Plantronics .Audio headset will not work The microphone plug on the .Audio analog headsets is not compatible with a Mac. It will physically fit into the Mic input jack on a Mac; however, it will not function. Basically, the digital sound card does not recognize the analog signal coming in from the headset.
Apr 16, 2011 | Plantronics Audio 625 Headset
I have a headset that I can hear my calls, but cannot be heard
You want to make sure that both your speaker and microphone are your default device. Go to the Sounds & Audio Devices in the control panel of your computer to confirm that. If it's still not working, contact Plantronics at 800-544-4660 x5 x5538 for warranty service (they have a 1 year warranty).
Mar 30, 2011 | Plantronics - Usb Multimedia Headset...
I have a Plantronics monoaural headset Audio 310 which is failing to give me a strong microphone signal - going through Control Panel (Sounds and Audio Devices - testing). I am using a voice to text...
Disconnect the microphone from the headset and connect another microphone to eliminate the possibility that it's bad. If the other microphone has the same symptom, then adjust the the sensitivity of the mic through the sound card properties. Or, try another sound card - it may be bad.
Feb 23, 2011 | Plantronics .Audio 310 Headset
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
Aug 11, 2007 | Plantronics 510 Voyager Headset - PLN-510...
ITunes or sound card line in with my USB Plantronics DSP-500 headset
Recently on an HP desktop computer I found setting the device in the Sounds and Audio Device Control panel Voice Tab (and possibly Audio Tab) to reduce the issues with the device ceasing to work. Setting the device from the Sound Icon in the System tray recently only a very temporary fix where the settings reverted to the Sounds and Audio Device Control panel settings in at most minutes. This is at best an I hope it helps solution as I do not know your specific hardware and software configuration we cannot test a solution.
Jan 04, 2007 | Plantronics DSP-500 Headset
Plantronics .Audio 326 Stereo PC Headset Logo
241 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
