I have a 15" Flat screen Tv/PC monitor I hooked it up to my computer and changed the channel to PC and Nothing my desktop did not come up says Going Into DPM Mode What would be the problem? Also do you guys have a online owners manual I can look at
Thank you
Josh Edberg ,IL I have the exact same issue and I've contacted Zenith about my problem. I have checked all available resources and tried many things to try to fix the problem, but they've all failed. My computer is not the problem, either, it works with all my other TV/monitors including my 50" plasma (though I never use it for the computer, due to the burn-in problem) I've even tried adjusting the resolution on both the TV and computer to resolve the issue, with no progress. It seems to be a Zenith problem, my NAXA (generic) and VIZIO have no problems running the computer. They start right up every time.
Sponsored Links
Same Problem
May 09, 2009
-   I have the same problem with my zenith tv when using it as a monitor through its dvi port. what I found is that if I have the input set to video or something else and turn on the computer, wait for it to boot, and then switch to pc it works fine. I don't know how i figured that out but it is the only way i can get mine to work and it is a bit of a pain.
-   Guest
The tv in the store the picture filled the screen, what do I have to do to get my picture fill the...
(More)
The tv in the store the picture filled the screen, what do I have to do to get my picture fill the screen
i have a p50hidm vizio and time warner cable synergy v remote the auto find code does not work on my...
(More)
i have a p50hidm vizio and time warner cable synergy v remote the auto find code does not work on my tv it turns it off and acts like its working but will not program to tv any one know the code for my setup thanks
Just changed the lamp on my Hitachi LCD projection tv. Now the my right side of screen has green...
(More)
Just changed the lamp on my Hitachi LCD projection tv. Now the my right side of screen has green tint that I cannot adjust out. Put the old lamp back in and set still has the greenish color on the right center side of the set. Also, now some times see a few wide vertical lines in the same area. Any suggestions?
