Question about Magic Chef Washing Machines
My Magic Chef Portable Washer mcstcw21w2 drum off center, stabilizing rod is missing in back, how do i get parts of help fixing it
  • 521 Answers
SOURCE: Outside of drum has four
complete details and all the queries for ur machine are mentioned on the link below to guide u completely step by step
http://www.applianceaid.com/washers.html
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 29, 2008
  • 5 Answers
SOURCE: MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Posted on Jan 03, 2009
  • 6 Answers
SOURCE: water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Posted on Jul 19, 2009
Karthik316
  • 187 Answers
SOURCE: Magic Chef 20lbs hd won't agitate
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.......
Posted on Jul 23, 2009
  • 410 Answers
SOURCE: Washer stopped mid cycle
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 02, 2009
Yes, where & what is the internal rubber ring on a Magic Chef 2.1 cubic ft. Portable Washer?
Go www.repairclinic.com and enter model. You will be presented with a list of common replacement parts and may be able to view a video that shows disassembly.
Aug 02, 2016 | Magic Chef Washing Machines
MCSTCW21W2 will not drain
According to the diagram there is a filter near the top of the drum on the inside left.
Jul 13, 2016 | Magic Chef Compact 2.1 cu. ft. Top Load...
What is the error code E2 for Magic Chef 2.1 cu. ft. Top Load Portable Washer?
I put this answer in the comments but re-posting here because I didn't know what I was doing : )
The Magic Chef 2.1 cu ft Portable washer manual says that its a door malfunction and the solution is to open and close the door. That did not work for me so if you're having the same issue that I am it may be that your washer is not level. I had placed mine on top of a few folded throw rugs to stifle noise (I live in an apt, on the second floor) and the rugs were uneven. As soon as i adjusted them, the washer began to work again. I hope this helps.
May 26, 2014 | Magic Chef Washing Machines
The drum on my washing machine is off center after spinning violently with an out-of-balance load. This machine is more than 10 years old. Is it cheaper to repair it or replace it?
would recommend repair as this is probably an easy fix. if it is a top load model then there will be some springs that stabilize the unit at the base . You will have to remove the cabinet from the washer to access and inspect the parts. look for something out of place.
Dec 31, 2010 | Magic Chef Washing Machines
MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Feb 02, 2010 | Magic Chef CAV4000AWW Top Load Washer
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
Washing Machines Logo
110 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
