Question about Suspension & Steering for Mazda MAZDA5
My 2008 Mazda5 is twisting from side to side when I accelerate, then let off the gas a bit.
The alignment is visibly off, as the car is pulling hard, often in different directions at different times, but something must be causing the hard swaying. I've already replaced the front sway bar end links - no change. New PS axle, driver side seems fine. Tie rod ends are tight. Tires are a little overworn on the insides, probably due to whatever is causing this swaying issue over time. Here's the timeline: Feb2012: replace shocks and struts, PS front lower control arm w/ ball joint May2012: car starts slightly pulling to right side Sept2012: pulling gets worse; investigation reveals PS front strut mount is bad; replaced thinking that was cause of pulling; wrong- still happenning Oct2012: Twisting starts to happen, along with pulling late Oct2012: bring to shop- they say it just needs an alignment. Alignment done, problem is actually worse now. Nov2012: shop says sway bar end links ad PS ball joint bad. Replaced links - no change. Ball joint looks like it could use greasing. I'm at a loss as to what is causing this swaying. Bad sway bar bushing allowing the bar to roam? transmission issue? steering- the recall was fixed, but could a bad module be causing some adverse reaction? Appreciate the help! -Don
  • Mazda Master
  • 3,904 Answers
Pulling hard seems to me that a bearing may be freezing up/going bad or a brake is not consistently releasing. Is this more noticeable as you break or is there any grinding?
Posted on Nov 13, 2012
  • Don Minichino II Nov 13, 2012
    Under the car yesterday, I noticed one of the bushings in the PS front lower control arm is shredded and there is a ton of play.
  • Jerry Kramer
    Jerry Kramer Nov 13, 2012
    That would do it and great you found it. Good luck!
How to get water out of my 2008 yukon xl headlight
I think that has 2 metal L shaped retaining bars on back sides of assembly. Pull those up and top section falls off basically..remove bulb by twisting and pour water out..can drill small hole in bottom back side to let future water drain..if hole is seen it can be failed for inspection...but so can water or condensation in light..
Replace assembly a seal is bad or cracked
The bottom light is held in w a tab behind light once top section is out it will visible le
Sep 03, 2014 | 2008 GMC Yukon XL
How do I replace the battery in my key fob?
Holding your fob you should see a seam running along the side. Follow that seam to the ring attachment point and you will see that it widens. Insert the corner of a credit card or a small flat head screw driver into this area and twist. The fob will pop open.
FYI: CR2025 is your battery type.
Good luck.
May 14, 2014 | 2007 Mazda MAZDA5
What will cause a 2001 mercury cougar to pull hard to the left? We already changed lower ball joints, caliper, bearing hub assembly, and outer tie rods.What's your problem?
Could be air in system and right side not applying brakes. Also the internal rubber in brake line where solid metal line attaches to can deteriorate and form a blockage for brake fluid to not reach caliper on right side.
Apr 11, 2017 | 2001 Mercury Cougar
Car pulls when accelerating
take it back they have not set it up correctly. its alway best to do wheel alignment on new tyres, defects in worn tyres affect the alignment.
Jan 10, 2018 | 1999 Mercury Cougar
How do i find out if its the cigarette lighter port or a fuse that needs replacing on my 2008 Mazda 5?
I pulled fuse 4 from the inside fuse box on the passenger side dashboard, but quickly realized it is for the rear power outlet, not the cigarette lighter outlet. The cigarette lighter outlet is fuse number 6. They are both blue 15A fuses.
Aug 17, 2011 | 2008 Mazda MAZDA5
I have a 2008 Mazda5 and i'm having problems rolling the driver side window up and down...Could there be a problem with the wiring?
If the window works as per norm but slow.........the motor is getting weak.Hope this helps.
Aug 13, 2010 | 2008 Mazda MAZDA5
Mazda5 6-CD changer stopped working
Hi! I am experiencing the same thing! Have you find any solution? Thank you!
Mar 19, 2010 | 2008 Mazda MAZDA5
Car pulls hard left when i gas it
it appears your car needs balancing and alignment of your wheels. also chek if your tyres are worn out or in good condition.
get your car computer aligned and ballenced and this problem should disappear.
Aug 10, 2009 | 1994 Dodge Spirit
Engine idles fine, stalls soon as its given gas
Hi there!
Open up the carb and clean the jets with pressurized air. I also suspect water on the carburetor reservoir, before opening the carb, drain it first then run. Also, make sure the plugs are clean. Pull on the choke when twisting the accelerator, if it accelerates well, then warm the beast at normal temperature first before twisting the throttle hard again.
hope this helps-
levibit-
Mar 29, 2009 | 2004 Yamaha V Star 1100 Custom
Suspension & Steering for Mazda MAZDA5 Logo
166 people viewed this question
Top Mazda Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
David Burbee
David Burbee
JOHN LAPIER
Are you a Mazda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
