Question about Memorex Ultra Traveldrive - 80GB 80 GB Hard Drive
Memorex ultra traveldrive 120GB not recognized
Hi all!
Actually my Memorex ultra traveldrive 120GB was working fine, but i accidentally moved all folders & files in another folder in the same disk by pressing ctrl+A. Now my external HDD is not recognizing by any computer.
May be i have moved the autorun files also. I don't want to format the drive, because i have important data in it. I can see the drive letter
''G'' for my external HDD, but i am unable to access. It is not opening(right click is also not working for it). I have also tried with cmd promp, but no use. Green light is on.
I also tried total media back up software, but in vain. Is there any chance to take backup of my files?
If any body knows the solutio please tell me what to do.
Thanks in advance.
  • 163 Answers
SOURCE: I have had my Memorex
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 26, 2008
  • 15 Answers
SOURCE: MY VISTA NOTEBOOK WON'T RECOGNIZE THE MEMOREX 4 TRAVELDRIVE
Lb44145 ,when you got the item did it come with the disk? And if you have the packaging does it say 'Vista Compatible' if not i would recommend you buy one which is vista compatible.
Good luck,
Ben
Posted on Feb 02, 2009
  • 252 Answers
SOURCE: I purchased a memorex 160GB traveldrive. I would
Things to ponder before deleting
Rather then deleting them right away, try moving the "day the files were uploaded" to another drive. Then try accessing the files on your memorex. Do the files and folders open properly? There not corrupt? Has the memorex hdd drive recreated the folder you just moved? etc...
Once your satisfied that yes there are two copies then you could safely remove one.
Posted on Nov 07, 2009
JaxPlanet
  • 922 Answers
SOURCE: Device Manager says ok but can not open
Open Windows Help and Support.
Search for "assign drive letter".
Make sure the drive is using a drive letter that is already in use on your computer.
I hope this helps.
Posted on Feb 04, 2010
SpideRaY
  • 687 Answers
SOURCE: Computer Not Detecting External Hard Drive
Try a new cable this may work if not it sounds like the HDD has failed you can try placing the drive in a zip lock bag and but it in the fridge overnight then try again if this fails then its U/S.
Posted on Mar 08, 2010
Memorex ultra traveldrive usb 2.0 driver windows 7
it looks like is empty but i now it has my records!!! what I must do?
Feb 27, 2013 | Memorex Ultra Traveldrive - 160GB USB Hard...
Computer doesn't see memorex ultra traveldrive, its a new computer and i lost the cd
to be detected by the computers need to install the driver if there is no need in looking on the web and download its drivers
Jul 23, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
Good day. I have a memorex ultratravel drive USB 2.0 160GB. Everytime I connect to any computer I get the message:The pc does not recognize the USB device code 43. Please let me know what i can do. thanks...
Code 43 is the death code - the pc simply cannot communicate with the attached device because the device is not working. This means that the Memorex is dead . Since the electronics board inside it cannot be repaired or replaced it means that yo must buy a new one.
Apr 09, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
I have a Memorex Ultra Drive connected via USB to a Windows XP machine. It shows up in My Computer as a folder but then disappears again. It does this repeatedly. The drive is formated as a FAT32. How...
As you have described that your Memorex Ultra Traveldrive re-appears repeatedly, indicates that the communication between your computer and your external hard drive is intermittent. The FAT32 format does not produce these types of issues. What we can do first is identify what causes the problem.
Assuming that the hard drive in your Memorex Ultra Traveldrive is in good shape:
Troubleshooting Method #1. Try connecting your Memorex Ultra Traveldrive into another USB port. If the problem persists, use another USB cable for your external hard drive. If the problem still persists, you will have to replace the external casing of your external hard drive. If your external hard drive works with the other USB port perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. That USB port might need some repairing.
Troubleshooting Method #2. Try connecting the external hard drive into another computer and perform the same troubleshooting as Method #1. If your external hard drive works with other computers perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. The USB port might need some repairing.
If the problem only occurs with your Windows XP machine, assuming all USB ports are in good shape, your Windows XP needs to be checked for some software issues.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 06, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
I have a Memorex Ultra TD v1.0 USB Device 160 Gb and has 120Gb free. The problem is that I can't copy a file that is 8 GB.
Right click your usb hard drive and press format. When the formating options menu pops up , under file system choose NTFS.
Mar 13, 2011 | Imation 120GB USB MEMOREX...
Nov 07, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
Some pc's don't recognize my travel drive
I have a USB hard drive, and I have noticed that on some systems the current Draw on the USB port is too high for systems with unpowered / Low power USB ports, and therefore it doesn't work for that system,
this issue can be bypassed by using a "powered" USB hub
Mar 24, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
Memorex 160gb external hd
Hi and welcome to FixYa,
Sorry to be bringing you the bad news, but chances are, the Memorex is a goner. You could still of course try removing the actual/internal hard drive, connect it to an IDE/SATA to USB adapter and see if that in turn would be recognized by any of the computers. If yes, then it is the electronic/data interface of the Memorex that is defective. If likewise not also, then the actual hard drive is faulty. If the hard drive still spins and makes no mechanical noises, there is a slim chance that the contents could be recovered using file recovery software such as GetDataBack.
Good luck and Thank you for using FixYa.
Jan 03, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
Memorex Ultra Traveldrive - 80GB 80 GB Hard Drive Logo
108 people viewed this question
Top Memorex Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Piyal Perera
Piyal Perera
Jax Planet
Jax Planet
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
