Question about Rheem Water Heater Pressure Relief Valve
What is the cavity size for the relief valve that I need Model 22V50F1
  • Rheem Master
  • 5,245 Answers
TP valves screw into 3/4" opening.
End of probe MUST extend into upper part of tank, and cannot be located on pipe away from main body of heated water.
http://waterheatertimer.org/How-to-replace-TP-valve.html
Posted on Nov 10, 2012
2 Suggested Answers
SOURCE: how to replace a faulty pressure relief valve on
Open following link to see step-by-step.
BE CAREFUL, tank must be turned OFF and water COOL before removing TP valve.
Posted on Feb 15, 2011
New installation I tightened relief valve and it sits right over wiring connections. If I turn it back it feels loose but no leak so far?
The relief valve is supposed to have a 3/4 line leading away and down to 9" from the floor . That said if it is loose, tighten it slightly and then run piping away from the controls.
Jun 09, 2014 | Rheem 50 Gallon FVR NATGAS Water Heater...
Leaking relief valve on hot water tank
It is 3/4 threads and it can be replaced any hardware store should have one. It may require a pipe wrench to break loose. they do go bad from time to time.
Shut water off and drain water down below relief valve opening and break loose to replace..
May 12, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pressure relief valve
The pressure relief valve only leaks when there is excess pressure in the system, possible causes could be excessive static pressure, overheating, faulty pressure vessel or undersized pressure vessel.
Apr 11, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Gas water heater is discharging out the pressure relief valve? what problems do i have?
The water heater is over heating the water, possibly boiling it and causing steam pressure build up. The thermostat is not sensing the temp to shut off the flame. It would be wise to either have a repairman come out or replace the heater. If pressure builds too high and the relief valve cand keep up ,theer could be a rupure of a water lineSoooooooooooo, turn the gas off and git er done.
Nov 09, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Relief valve constantly releasing water.
lower your thermostats a bit. If your temperature is set to the hottest setting, then chances are no relief valve will do
Jan 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem Water Heater Pressure Relief Valve Logo
125 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
