Question about Philips CDR765 2-Disc CD Recorder
Re: w302 d1103. I forgot to mention
I bought a lens cleaning disc from RadioShack, but it did not make any difference.
  • 4,234 Answers
These lens cleaning discs are nothing but smal brushes that may on occassion brush off any loose dust on the lens. If you can open up the unit, try cleaning the lens carefully using a cotton swab and alcohol. That MAY resolve the problem. If not, I think that the optics have failed and may need to be replaced.
Keep us posted.
Dan
Posted on Jan 06, 2009
Where is the lens to clean on Sharp component system?
Hello
To clean the lens, you have to open the device and access the loading mechanism. it is really a skilled job. If you want to clean the lens only, there is a simple way. Just put in a lens cleaning disc into the device, and play it for about three times at least. Take the disc ejected each time, and put it in after. The lens cleaning disc can be bought from most of the electronic spare part selling shops at your town, and won't cost more. You can clean the laser head lens, by this way, without opening the device. OK.
Dec 22, 2011 | Teac Audio Players & Recorders
Whenever I am inserting any dvd in my DCR-DVD 405E Sony handycam it is showing "Disc error, remove disc." Error code 13.00. I bought original Sony DVd. It is occurring even with disc in which I...
It sounds like the lens. I know this is actually a problem many people are having with different models of handycams. Try taking a q-tip and use 91% alchohol (rite aid, cvs, walgreens, etc) then clean the lens. Depending this may or may not work. The only permanent solution is to change the lens altogether.
Aug 22, 2011 | Cameras
My lg dvd writer is not detecting dvd but it is detecting cd...
the laser (lens) of the Rom is very weak, that's why it cannot read DVD discs. DVD discs are usually larger that CD's and it takes an active lens to play DVD disc.
So if its still under warranty, you can return it, if not, get a lens cleaner and use it to clean the lens of your ROM.
Good luck.
Jul 03, 2010 | LG GSA-H55N DVD-RAM Burner
Samsung dvd-v6800 not reading disc
hi..
Try buying a Laser Lens Cleaner Disc from Wal-Mart, FYE music store, or any other place that might sell DVD players. Your Laser Lens that reads the DVD'S is full of dust. Try using the laser lens cleaner disc i mentioned to clean the laser lens...
thank u
rate me
Aug 23, 2009 | Televison & Video
Disc Error
I reccomend going to radioshack and grabbing one of their dvd/cdplayer lens cleaning kits. This should hopefully clean your lens and fix the problem. If it dosen't I'd reccomend contacting samsung and look into the possibility of sending it in for repair:
http://www.samsung.com/us/info/contactus.html
May 24, 2009 | Samsung HT-X40 System
CDR 765. Recording side will not recognize disc.
Try to clean laser with cleaning disc.I had the same problem and cleaning disc resolved the problem
Mar 09, 2017 | Philips CDR765 2-Disc CD Recorder
Disc not being read - reading reading reading
That looks like a lens problem, when there is a fault of different kind you usually get an error message.
If you use a CD cleaner , use a good one , the $2 CD cleaners do not work, you need a kit with cleaning solution. Check here.
Run the CD cleaner a couple of times more , and see if this work.
If it does not work , the unit must be taken apart, and the lens cleaned directly with a cotton stub and cleaning solution, or isopropyl alcohol.
If the lens is defective, then the lens pick up should be replaced.
Oct 26, 2008 | Philips DVD633 DVD Player
Disc not working
I'm either thinking get the receipt and return it for the same game or clean with the lens cleaner down at radioshack and if you choose radioshack, that whole ps2 will work like brand new.
Jul 07, 2008 | Sony PlayStation 2 (PS2) Console
Will not read disc
Threw it out. Bought a different more reliable brand. Thanks for nothing.
Apr 18, 2008 | Durabrand DUR7 Portable DVD Player
Games initial load before Play Starts receive error 'cannot read disk see instruction manual'
If this happens for only some games, you should try cleaning the discs with a disc cleaner. Otherwise, you could try asking around at stores like circuit city, radioshack, best buy, etc. for what you could use to clean the lens, the part that reads the disc in your gamecube. If that doesn't work, chances are that the lens is damaged and your only hope is to send it in for repairs or get a new gamecube (or Wii).
Oct 13, 2007 | Nintendo GameCube Console
Philips CDR765 2-Disc CD Recorder Logo
97 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
