Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Need to replace parts 5304468029 and 240542901; water cap and relay and plug kit have parts
  • Official Brand Answer
  • 4,342 Answers
Hello Virginia House - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. In most cases this information can be found on the internet; however it is not provided directly from the manufacturer. Typically this is something that you want a certified professional to install for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly repair/install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process.
Posted on Nov 15, 2012
Overheating
replace thermostat and radiator pressure cap, what i would do is flush out the coolant system go auto parts store buy a radiator flush kit replace water pump do all this see what happen you need to add 50/50 antifreeze and water to coolant system.
Sep 07, 2012 | 1997 Saturn SL
95jeep limited overhears and pushes freeze plugs out. What could be the problem?
if its overheating and pushing the freeze plugs out then the cooling system is creating excessive pressure which can only happen if the head gaskets are no good causing combustion chamber pressure to enter the cooling system.if the freeze plugs are the correct size then it takes alot to force a freeze plug out of the block.
Jun 24, 2011 | 1995 Jeep Grand Cherokee
82 1100 has a bad miss in the upper rpm about 4 to 5000. It even feels like it wants to stall out, someone said the coils.
Old coils have wires that arc and 5000 OHM caps with blown resisters that can cause your problem. You could try replacing the plug caps on the end of the wires (they unscrew) (NGK about $20) Accel makes some bolt in replacement coils for the gl 1000 and gl1100 ($150 to $200). The kit comes with yellow wires and spark plug caps. I substituted snap on Ford truck wires because they were black. With this kit you need screw on tops for spark plugs (Honda snaps there caps on to the threaded plug top with out the screw on aluminum dome). Start your bike when it is dark out side and spray water on the wires to look for shorting. Also, does it cut out in the rain? Your cheapest fix would be to try the new plug caps first, unless of course, the wires are shorting.
Aug 21, 2010 | 1982 Honda GL 1100 Gold Wing
I need a rebilding kit for a.osmith motor mod c48k2pa105 1 hp 115/230
There are no rebuilding kits per say. Rebuilding a motor entails stripping it down and replacing what's bad. whole inside should be cleaned of debris, dust, rust etc. Almost always bearing are replaced. Armature, rotor and stator are cleaned, motor windings tested, start/run caps tested and replaced as necessary. Thermal overload, contactor, relay, centrifugal switch, etc, tested and replaced if needed. You can order bearings and capacitors from several places online, other parts can be harder to find. I local pump repair shop may sell you parts as well.
Jul 14, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
Both freezer and refrigerator are warm and fan is running and compressor is hot
check model number. if the first 3 numbers are 106. this is a whrilpool made refrig. they have a lot of start kits going bad, It consist of a relay, overload and a relay. you need to replace all three. you can purchase a 3 in1 start kit that will work on all the home refrigs. Check local refrig parts house. usally the small hp kit is fine.
Mar 05, 2010 | Kenmore 26.0 cu. ft. Side-By-Side...
Runs but not cold relay on freon tank clicks and clicks again after few seconds
the freon tank is the compressor and the clicking you hear is the relay trying to start the unit . i don't know how old this unit is but it needs a new relay and it may work . there are hard start kits that can be installed also . called 3 in one and this replaces the relay and give's a kick start . ok for older units / if newer with run cap then i would use the org replacement part., hope this hepls mm
Feb 03, 2010 | Refrigerators
Amana refrigerator stopped cooling.
Have you been hearing a clicking noise coming from behind the unit? This is the first indication of a failed compressor relay. Pull the unit out and unplug it. Remove the back cover and go to the compressor. You will find a device on the side of the compressor that has the wires hooked to it. This is the compressor relay and overload. It may be under a black cap. Remove the cap to access it. It may have 2 pieces to it or it may just have the 2 pieces encased in a white and tan box. Remove this box and shake it. If it rattles like gravel in it then it is bad. If it is in 2 pieces then it will have a brown relay. This is the piece that will rattle if bad. The white and black piece with one wire is the overload. They most never go bad. Use this replacement part kit...8201786 and follow the detailed instructions included in the kit. Thanks for the question. Hope this helps.
Apr 11, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Compresser dose not come on refrig compartment lower shelves are cold freezer compartment warm.
Have you been hearing a clicking noise coming from behind the unit? This is the first indication of a failed compressor relay. Pull the unit out and unplug it. Remove the back cover and go to the compressor. You will find a device on the side of the compressor that has the wires hooked to it. This is the compressor relay and overload. It may be under a black cap. Remove the cap to access it. It may have 2 pieces to it or it may just have the 2 pieces encased in a white and tan box. Remove this box and shake it. If it rattles like gravel in it then it is bad. If it is in 2 pieces then it will have a brown relay. This is the piece that will rattle if bad. The white and black piece with one wire is the overload. They most never go bad. Use this replacement part kit...8201786 and follow the detailed instructions included in the kit. You also could have a bad compressor or a bad evaporator. Thanks for the question. Hope this helps.
Apr 08, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool start device
k here we go, thinkkn we can get this to work for you.
the difference is going to be the white overloads in the bag9s). depending on size of compressor they will change, as far a s the relay thinkin ther is onl one in that bag'box/ (brown with 3 possible connections..
if this is the cas e ill asume that the old relay/overload was a onepiece white plastic with smaller connectors.. .you will need to cut off and resplice a new spade connector on the wires to fiut the new piece..
the extras are just that extras, its easier for them to stock and store one part number for a multitude of repairs( youll need only one)
Mar 09, 2009 | Kenmore 50522 / 50524 Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
65 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
