Question about Linksys Wireless-G WRT54GS Router (e125894)
I need to port forward 5900 to my linksys router how do i do that?
  • 928 Answers
You can follow the directions at the link below. Just replace the Aimtalk port with the port you want
http://www.portforward.com/english/routers/port_forwarding/Linksys/WRT54Gv5/AIM_Talk.htm
Posted on Jan 05, 2009
Port forward on linksys wrt54g2
Please follow the instructions found here: http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G2/Shareaza.htm
Dec 10, 2014 | Linksys Wireless-G WRT54G Router
Linksys port forwarding
This WEB site shows how to port forward.
http://www.wikihow.com/Port-Forward/Open-Ports-on-a-Linksys-Router
May 05, 2013 | D-Link DSL-G604T Wireless Router
How do I get two xbox 360s to have an open NAT on a Cisco Linksys WRT160N V2 wireless router?
you need to setup both your xboxes with a static IP address for example
192.168.1.50 xbox 1 192.168.1.51 xbox 2
on your linksys router you will need to setup port forwards for both xboxes
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
requires you to forward the following ports: 53,80,88,1863,3074
Mar 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Port forward VNC server. Not able to connect vnc viwer from external network.
What VNC product are you using? RealVNC? TightVNC? UltraVNC? The VNC software you installed will have a port# assigned to it by default (probably 5900) which can be configured. Find out what that is and forward that port# to the IP of your VNC "server." That should do it.
(don't fogot about any software firewalls on the VNC "server" machine)
Dec 07, 2009 | Linksys BEFSX41 Router (DHBEFSX41)
How do I do port forwarding with one static IP to put my address in my other computers . I need to shadow into with VNC after I install address on my computer is port forwarding marked on the menus are...
Find the IP-address of the computer that you want to accept VNC connections.
Access the router's web-interface.
Find its web-page for "port-forwarding".
Define 'TCP' port '5900' to be forwarded to the IP-address that you found.
Save the settings, and restart your router.
Hopefully, Verizon's FIOS network does not "block" all 'TCP:5900' traffic.
Nov 17, 2009 | Linksys Computers & Internet
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
Letting Ultra VNC go through a Dlink router to connect to a serve
You may have to define the VNC service under services then port forward that service on port 5900 to internal 5900.
Of if it has a Virtual Server option just forward port 5900 to 5900 and send it to the LAN IP Address of the computer you want to use.
If you need instuctions let me know and i'll post,
ta, HPC
Feb 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Port forward 5900
You can follow the steps here on how to forward port 5900 to your router, just go to this link http://portforward.com/english/routers/port_forwarding/Linksys/WRT54GSv4/RealVNC.htm
Jan 05, 2009 | Linksys Wireless-G WRT54GS Router...
How do I port forward?
You can go to the link below then select your router model number. It will give you a step by step
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
Nov 15, 2008 | Linksys Wireless-G Broadband Router
Forward ports in linksys wrt45g so magicjack will work
Check this link it has the step by step instruction on how to do a port forwarding on your linksys router , this is just a sample so what you need to do is just replace the value for the port number of your magicjack... http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/Lingo_VoIP.htm
Hope that helps..........
Oct 05, 2008 | Enterasys Distributed Forwarding Engine...
Linksys Wireless-G WRT54GS Router (e125894) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
