Question about Element ELC-HS321 32 in. LCD TV
Forgot my passcode to my element tv how can i reset it
How do i reset the parent passcode on my daughters leappad ultra
If you forgot the parent passcode/lock code you can reset it by following these instructions: Forgot Parent Lock code on LeapPad
Apr 10, 2016 | LeapFrog LeapPad Ultra Learning Tablet -...
My tv sharp model 21v-fw650s locked due to ,i forgot the passcode how can i reset it to factory setting
There should be a default code, that overrides the set code, and using it you can reset it by an other code. Refer its user manual to get this override code. Electro help Gopakumar Gopalan Google
May 22, 2014 | Sharp Televison & Video
How to reset menu password
Hello
The original initial reset passcode for your TV is '0000'. If you forgot the passcode you have entered just key in "9443", which will regain control over your TV. OK.
Jan 25, 2011 | Haier HLC19R 19 in. LCD TV/DVD Combo
I forgot my Apple TV parental control passcode. Today I tried renting a movie and can't do it without the passcode, and can't figure out how to reset, and there is no function to remind password as is...
Go to settings in the main menu screen, next go to general button. Then at the bottom you should see reset button. This will reset your apple tv to factory settings, which will erase your passcode.
May 09, 2010 | Apple TV MB189LL/A 160GB RTL 160 GB USB...
I forgot my sony erricson passcode
http://forum.gsmhosting.com/vbb/showthread.php?t=778208
Click on the above go to page 66, this is if you forgot your passcode.
If you think you need a master reset search master of the pdf.
Hope it helped.
Dec 23, 2009 | Cell Phones
Forgot the password to tv
Good Day,
Bypassing the V-ChipLock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
When changing or deleting your passcode, you must use the remote control included with this TV. You cannot use any Mitsubishi remote control from another component or a "universal" remote.
Good Luck, Big Irish.
Nov 22, 2009 | Mitsubishi WD-62327 62" Rear Projection...
PASSCODE HOW DO I RESET THE PASSCODE?
You cannot reset the passcode, however the default passcode is "0000"
Jul 17, 2008 | Samsung WEP170 Wireless Headset
FORGOT PASSCODE ON TV PARENTAL LOCKOUT
that's a big problem. sometimes using the 0000 can unlock it but it's not 100 percent.try the trial and error.
Apr 19, 2008 | Mitsubishi CS-40503 TV
V-chip password
how do i v chip passcode,cause i forgot my passcode
Nov 14, 2006 | Toshiba MW27FP1 27" Flat TV/DVD/VCR Combo
Element ELC-HS321 32 in. LCD TV Logo
229 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
