How can I make an IDE Barracuda 7200.7 work with an AirLink 101 3.5" Enclosure Box?
I just bought an AEN-U35SE USB 2.0 SATA / IDE Enclosure Box to transfer all my data from an old Seagate IDE Barracuda 7200.7 160 GB hard drive. I cannot make it work. After failing, I tried the enclosure box with a Seagate SATA hard drive and it works. With the IDE drive, I have tried all jumper settings without success. The enclosure led lights up green, not red, which means the connection is OK within the enclosure I believe, but the USB external hard drive is not detected in Windows 7. The old drive has a Windows XP system installed.
    Top Expert:
  • Computers & ... Master
  • 14,162 Answers
Posted on May 24, 2016
gP4help
  • 12 Answers
SOURCE: External drive not being accessible from Vista Home Premium x64
format  the external drive,and try again,,,,,,
Posted on Jan 24, 2009
Benimur
  • 6966 Answers
SOURCE: Which USB enclosure for Seagate U6 Model ST360020A (60GB)
Hi and welcome to FixYa,
Would suggest a multiple to 1 adapter that would accommodate most if not all types of connection. The price difference would be negligible and since its multiple would work on just about any IDE, SATA, 2.5 or 3.5. A good example is this model.
Good luck and thank you for using FixYa.
Posted on Feb 08, 2009
  • 1481 Answers
SOURCE: Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Posted on Feb 18, 2010
bronk50
  • 27725 Answers
SOURCE: I have a Dell Dimension E520 running Windows XP.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Jan 22, 2011
fanaudi
  • 1381 Answers
SOURCE: my WD fell on the
Hello jazzmania67
The best solution in this case is to use a recovery tool to recover and store your data on another drive
Free Recuva works fine : http://download.cnet.com/Recuva/3000-2242_4-10753287.html
Do not try to recover all at once but each category at a time , documents , pictures , music ...etc...
If it fails , try this one . It's not free but very efficient : Tenorshare Data Recovery. It can recover data after deeply scanning your hard drive to look for lost data due to unwanted erasing , system sabotage, virus corrupted partitions,drives crash, physical damage,ect.. http://www.any-data-recovery.com/product/index.htm
If you still don't have success , you will have to go to a recovery office but let's hope not because it will cost you a lot of money .
Regards ,
fanaudi .
Posted on Mar 29, 2011
How do I read a barracuda 7200.12 1 TB drive? I need to get data off of it, not boot on it
Hi
The easiest way that I have found is to get a kit that allows you to power the drive from a separate wall socket and connect a data cable from the drive to a USB socket on the computer. Such a kit usually consists of four components:
A mains lead - wall socket to black box transformer
The black box transformer - has outlet 4 pin molar for IDE drives
A USB cable ending in unit for connecting to an IDE drive or SATA cable
A SATA cable for connecting to the SATA drive (your Barracuda 1Tb in this case)
The components can be seen on this Ebay site:-
USB 2 0 TO SATA IDE Cable for HDD with Power Converter Adapter UK
The one thing missing from this set up is a power conversion cable converting the molar 4 pin power connector to a SATA power connector. These can be a molar plug to go into the lead from the black box and either a single SATA power plug, or a double SATA power connector as shown here :
Molex to 2x SATA Power Dual Power Adaptor Splitter Cable Lead Hdd Cd DVD...
This option is inexpensive and offers great flexibility in the type of drives that can be connected to a USB port, 2.5 or 3.5 inch, SATA or IDE.
In your particular case you may be able to get a dock that connects to a power supply and a USB port, with an opening in the top to take a SATA drive. These tend to be more expensive and only suitable for SATA drives not IDE.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Seagate Barracuda 7200.12 1 TB 7200rpm...
Simple tech 320 gb not spinning
Try a new usb cable or a different usb enclosure.
Also try and remove the drive from it's enclosure and connect direct to a sata port on a desktop pc.
Aug 23, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
Info: barracuda 500 gig in a kingwin elite enclosure (sata) - usb to computer. being used as a backup and storage drive on H.P. Quadcore running windows vista. Prob: Cant be seen on any computer ive...
Quite commonly on external drives the usb interface will go bad in the external drives the hard drive enclosed is probably functioning ok. Would try a different usb cord just to make sure the cord is not the issue. If still does not work you may need to purchase a new enclosure that will have a new usb interface circuit board with it. If taken in for service they will probably tell you to purchase a new external drive.
Here is a video on recovering data a side from an external drive.Some steps are not necessary if you have access to an ide/sata to usb adapter. These are pretty inexpensive on ebay as well as replacement enclosures.
http://www.metacafe.com/watch/1000351/recover_data_from_external_hard_drive/
May 01, 2011 | Seagate Barracuda 7200.12 ST3500418AS Hard...
USB port broke off. Can I connect to something else to get the data off the drive? I cracked open the case and it's a barracuda 7200 but I don't recognize the pin connections. Please help? Thank...
Yes just fixed mine. Went to radio shack bought a gigaware sata 3.5 external enclosure.
Took the harddrive out of old enclosure. pryed off external alluminum case to expose a panel that sticks out to the side where the broken usb plug went. Wiggled that off then placed in new enclosure fits good. secured with old screws. plugged it in and it works great. The new usb plug is much sturdier. The external case cost me about $40.00 and some change but Im glad i retreaved my data. I will never buy another seagate. Hope this helps...Alan
Jan 04, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
What type of hard disk enclosure wll work for a 40 gig Seagate Barracuda ata IV drive?
I assume you want an external enclosure for this drive. Hard drives are built to standard dimensions and have the same power and data connectors, so any enclosure designed for a 3.5-inch IDE drive would work. Here's one I've bought several of for myself and others, and it's been reliable. There are many more available from many vendors. Just be sure you get one designed for IDE drives or that will take both IDE and SATA. If you get one meant for SATA only, the connectors inside won't fit your drive. Which enclosure you finally choose will depend on which you think is best (based on price, appearance, reviews, or whatever you look for), but any one will work.
Dec 02, 2010 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
External IDE enclosure problem
here's what a sata hdd connection looks like
here's what a IDE hdd connection looks like
here's a page that shows them side by side
Hopefully that should help with what you have there.
Jan 21, 2010 | Toshiba Satellite 2455-S305 Notebook
Install a seagate 7200.7 in a cool max enclosure
They sure are !
You need an IDE or EIDE enclosure.
If you bought the enclosure very recently you may want to try taking it back and swapping it for another one
If its a big box store you might want to try the "it just doesn't work and I am clueless" routine
Seen that work quite a bit much to my dismay. Then the people usually get money back and go to another store to get the correct item.
NOTE I dont condone that method !
Aug 20, 2009 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
What kind of case enclosure (3.5) should I buy?
Check out the review on the hard drive case we use in our shop at www.ccl-la.com We have been using these drive cases for a while and have had no complaints, and it works for both IDE and SATA.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 09, 2009 | Western Digital USB 2.0 External Enclosure...
How can i make my seagate hard disk an usb hard
It is quite easy, do not worry.
You only need to bought and USB enclosure, here is a link to many products on ebay
http://search.ebay.com/search/search.dll?from=R40&_trksid=p0.m37.l1313&satitle=hard+drive+enclosure+usb&category0=
then you have to connect your hard drive inside the enclosure and the enclosure to your computer using the usb cable and that's it.
Just be carefull about the enclosure, I guess it is a Hard drive from a desktop, is in it? because some enclosure are for laptop's hard drive.
Also you need to know if your hard drive is SATA or IDE, IDE is the normal gray bus cable with fourty some pins, and the SATA it is a really small cable (I do not use technicims to not confuse you even more).
Also, there are some adapters from IDE/SATA to USB that you can buy in your local computer store (do not go to bestbuy, compusa, ... they only sell external hd), or also get it from ebay.
The only diference between the enclosure and the adapter is that the enclosure looks better :D, and the adapter is just a bunch of cables.
Mar 19, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Help
An external USB drive consists of tow parts:
a hard drive (usually a standard IDE or SATA drive), and
an enclosure
The enclosure is the box containing the drive. It also includes an interface to convert the data from the IDE or SATA interface on the drive to a USB (2) signal. Some enclosures include and internal power supply. The Freeagent has the power supply externally.
Hope that's what you mean.
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
