No sound on left channel in all digital modes
Hi, i have Marantz SR 4001 HDMI ,and it started to give me problems with left output ! Left channel stopped working in all digital modes but it works when i listen to it in direct/stereo mode . I tried changing speakers ,wires, everything even used the two ways to reset my receiver but the problem is still happening . That problem just happen one day when i was listening to music, btw i use this receiver in my home from the first day i both it with out overloading it ! It even toke it to a service but even that didn't help Please can you give me some suggestions what can i do whit this problem ? Thank you !
SOURCE: Only the main speakers are functioning...
Replace the A/D converter CS4228A on the DSP Board
Posted on Nov 24, 2007
  • 5 Answers
SOURCE: Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Posted on Aug 29, 2008
tech48
  • 624 Answers
SOURCE: listening modes not working??
I am a little hesitant to tell you what this is because sometimes people give bad ratings to an expert when they do not get the answer they want to hear. I will take a chance here and assume you are a reasonable person and tell you what the most likely cause is. I have been reparing these type of receivers for as long as they have been making them, and every time I see this particular problem it is always something on the digital board. This is the board the the optical and coax inputs go into on the back. They also run all the audio thru this board, and when you only get the audio that you have, a problem is going to be found there. There is some good news and some bad news that goes with this, first the good news. Many times (about half), the digital board only needs to have some of the solder reflowed on a few of the IC's and it will return to normal operation. If this is the problem your repair should only cost from $90 to $150 depending on the rates of the shop. Now the bad news, if the board has a couple of bad compnents on it, it will need to be replaced. The reason that is bad news, is because those boards are very expensive, usually over $250 just for the board, if the board is even available. Many of these receivers you can not get the digital board for them. Most all of audio equipment is component level repair and there are not many technicians who can troubleshoot these boards, they are a very difficult task.
I hope this free information was helpful, and if so a "FixYa!" would be the appropriate rating. You do not need to have your receiver fixed in order to give a good rating, only that you are given the correct information.
Let me know if I can be of any more help to you, good luck with your Onkyo.
Dave
Posted on Nov 10, 2008
SOURCE: NAD 775 will not play surround sound from XBOX
try to calibrate the speakers from audessy rom menu,i did it and it lokes like it just needed to register all the channels,hope it helps.
Posted on Mar 09, 2009
dunnbiker
  • 8546 Answers
SOURCE: marantz receiver SR-5000:
Swap the speakers with each other to isolate the speaker from the wire and the amp. What fails now? Isolate accordingly.
Posted on Jan 21, 2010
Hdmi to component connection for surround sound
Does you tv have an optical audio output? That would be the easiest way.
Jan 07, 2013 | Marantz Sr8200 Thx Ex Surround Dolby...
My Marantz sr 4001 receiver has no output. Is
There is no fuses for the speakers. Check setup. If the receiver has 7.1 channel input try to connect a source there so you can check output (amp) section and the speakers.
Jul 18, 2010 | Marantz SR4001
No surround modes produce any sound . only have sound on s direct mode. marantz sr 5200
Not having the ability to look at it on the bench, more than likely your DSP chip is bad. If you have a local repair house that is willing to confirm that is the problem without charging you an arm and a leg, that's your best bet. It is an expensive repair, anywhere between 300 to 500. At that point, I would say to replace the unit. Sorry for the bad news, but that's my "best guess" The only other thing to check would be your "Audio input Settings" Make sure it's either on "Auto" or whichever type you are using. "Digital Coaxial", "Optical", or "Analog" (RCA) hope this helps! If you have any further questions, just post a reply and I can help further. Best of luck!
Jun 03, 2010 | Marantz SR-5200 Receiver
Marantz support question
This is the problem with computerized stereo's. The old analog stuff we could fix forever, but many of these digital problems, only the maker has the tools to repair. Feel fortunate that yours will even offer you support, even though expensive.
Good luck.
Jan 28, 2008 | Marantz SR-7200 Receiver
Playstation 3
I assume that the Marantz has an Optical lead input. If so you should connect an digital optical lead directly between the PS3 and the Marantz receiver for the sound while keeping the HDMI lead to the projector for the picture. You will need to configure the PS3 to be outputting the sound to the optical output (done through the settings menu).
Jan 08, 2008 | Marantz SR-5200 Receiver
Marantz SR 7200 Receiver
DSP (Digital Signal Processing) Board is probably defective or has Poor solder Connection on one of the Ic's on that board. Board cannot be Obtained from Marantz. Must be troubleshot at component Level and requires a very knowledgable tech to repair it. I have done a few of these in the past and usually charge $50 to Evaluate and Give estimate. kstahl65@att.net
Dec 26, 2007 | Marantz SR-7200 Receiver
Loss of volume on left channel
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Oct 15, 2007 | Marantz SR-5200 Receiver
No output from left channel after crackling sound
Jul 08, 2007 | Marantz SR-4200 Receiver
 Grubhead
Grubhead
