Question about Toshiba 32A33 32" TV
Is my toshiba 32A33 tv digital?
Do i need a converter box to use an antenna?
Happy2Help
  • 59 Answers
SOURCE: 36A50 Digital ready?
Hi duce1500,
Unfortunately, the 36A50 is not HDTV-ready. That means you will need a converter box. Here is a link to the model's specs, which includes this information:
http://www.amazon.com/Toshiba-36A50-36-TV/dp/tech-data/B00004YMBV/ref=de_a_smtd
I should mention, however, that if it's connected to cable (or certain satellite services), you won't need a converter to watch the TV - you'll receive the digital signal (although you won't have the 1080-pixel HD resolution - the 36A50 only has 850 lines of resolution).
I hope this helps. Please let me know if I can be of any further assistance.
H2H
Posted on Dec 13, 2008
SOURCE: Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Posted on Jan 08, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Is my Toshiba 27AF42 TV
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Posted on Mar 09, 2009
  • 22 Answers
SOURCE: converter box
If your tv only picks up analog tv stationsover the air, you will.
Posted on Jun 02, 2009
milkburp
  • 416 Answers
SOURCE: Bought a used Toshiba model# 32A33 tv with vchip
Hold down the Vol - key on the TV. When Volume is at the minimum, hold down the 0 button on the remote. Remain holding both keys for at least 1 full second. Be sure your arm or hand is not obstructing the remote IR beam to the TVs IR receiver.
Posted on Mar 13, 2010
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
I need a diagram of how to set up the analog converter box or instructions.
I am posting the instructions of how to set up the analog converter box :-
Hope it will you.
· Things you’ll need:
Analog TV, antenna, two coaxial cable, and converter box
· Instructions:
Step 1
Unplug coaxial cable on the back of TV "antenna in" (RF) port
Step 2
Insert coaxial wire into the "antenna in" on the converter box
Step 3
Use second coaxial wire and plug in the converter box, "out to TV" port. Plug the other end into
“antenna in" on the TV
Step 4
Power on the converter box and TV. Change TV channel to 3 or 4. Follow on screen instruction to
Complete setup.
Step 5
After setup you will begin to see more channels than before with better clarity. Some stations will broadcast two or three channels. Enjoy
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 18, 2009 | Televison & Video
JVC and the right converter box and antenna
If the tv got audio video inputs put the converter box on it,because any converter box got to work with all tv´s
Jun 30, 2009 | JVC AV-27230 27" TV
How to convert the J53 BW to receive digital broadcast signals
Certainly you can use your TV!
The converter box needs an antenna so it can tune the channels, but it doesn't have to be the antenna that's built into the TV. In fact, you'll get better reception if you use an antenna designed for the new DTV broadcasts. Several types are available at stores where they sell TVs, and they start at under $10.
Then you'll need to connect the converter box output to the TV so you can tune it in on channel 3 or 4. I'm not familiar with your Jensen set, but I've never seen a TV without some kind of connector for an external antenna. The most common type on small TV's is a jack similar to an earphone jack. Radio Shack sells an adapter that plugs in and allows you to connect the cable from the converter box. Take the set with you if necessary so you can find what you need.
Feb 08, 2009 | Jensen J53-BWR 5 in. Portable Television
Do you need a special antenna to hook up a dtv digital to analog
You need a TV antenna, nothing special about it. Hook the antenna up to the converter box, the box up to the TV.
Jan 10, 2009 | Insignia Digital-to-Analog Converter for...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
GE Spacemaker TV/Radio combination Model #7-7650
Yes, you will need an external antenna to pull in the digital signals. It will not work with the built-in antenna on the GE. Alternately, you can use an external antenna (ie, rabbit ears), connect them to the converter box, then connect the converter box to the antenna jack on the back of the TV (I think it has one). Granted, not an elegant solution for a kitchen TV, but it beats not using it anymore.
Cheers
Nov 11, 2008 | GE Televison & Video
Toshiba 32A33 32" TV Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
