Question about HP Photosmart C4280 All-in-One InkJet Printer
I cleaned the cartridges, unplugged the printer to reset and did a little dance. Please help!
  • HP Master
  • 7,627 Answers
Try unplugging the printer and plugging back in. What are thr levels on the ink carts?
Posted on Nov 10, 2012
4 Suggested Answers
  • 46 Answers
SOURCE: HPPhotosmart C4250 mgs "Printer Cartridge missing or not detected
There may be debris that is blocking the communication between the cartridge and the printer, especially if you are using a remanufactured cartridge. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
Posted on Mar 15, 2010
  • 652 Answers
SOURCE: C4280 photosmart printer - printer screen says
Uninstall the program from your computer. Plug in your printer first replace with new cartridge making sure to remover the film on the cartridge Then plug in patch cord to computer, program should reinstall if need be you may have to have your disk that comes with the printer. Hope this works, Printers are going for very cheap I would suggest buying a new one if this does not work.
Posted on Apr 01, 2010
My lexmark 640 printer is not printing ie blank page after printing, yet the ink levels are high as i've hardly used it. what can i do, please? sandy
Print quality issues can be due to clogged print cartridge nozzles. Please follow the steps below to fix the problem:
  1. Try to remove the cartridges from your printer
  2. Close the printer cover.
  3. Unplug and re-plug the printer into the power source to reset it.
  4. When the printer turns on, reinsert the cartridges.
  5. Your printer will then try to print an alignment page. It will help clean the cartridge nozzles.
  6. After the alignment page comes out, try to print a document again to verify if problem is resolved.
If the problem continues, try to launch the Lexmark Solution Center on your computer. Go to Maintenance and select Clean Cartridge.
You can also try to insert a different known working cartridge to determine if it's a cartridge problem.
Aug 18, 2011 | Lexmark Z640 InkJet Printer
We replaced the toner cartridge and the waste receptical and the little red light "Add Toner:" is still on and the machine won't copy. We have removed the cartridge and did the dance...
If it is a Kyocera toner than that is the problem. The key to turn the toner is different for the Kyocera toner cart. It will fit and appear to work but won't. Also turn the unit off and unplug for 15 sec. will reset and perform boot up procedures might help.
Jul 07, 2011 | Copystar CS-1810 Copier
Have Lexmark 4200 series all-in-one center. I just replaced black cartridge (71) and it keeps giving us an message - Black Cartridge Missing. The tape is off, I've unplugged it, I search for the #71...
It could be that your cartridge needs some cleaning or the cartridge is not seated properly in the carrier. Open the printer cover. Remove the cartridge and wipe the cartridge nozzles with a moistened soft cloth to clean it from dirts and clogs. Close the printer cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, reinsert the black cartridge and make sure it's properly inserted.
May 20, 2011 | Lexmark X4270 All-In-One InkJet Printer
Cartridge error appearing
please mention, what error.
clean the ink cartridge (the golden contacts) and also the inside of the printer. after cleaning the ink cartridge, do a semi full reset.( unplug the power , and then press and hold # and number 6 button together, and while holding them down plug in the printer again.. you will have to continue holding the buttons down for some time until the display says semi/nvram reset).. nOw release the button.
then turn the printer on , and after that insert the ink cartridges
Aug 12, 2010 | HP Officejet 4355 All-In-One InkJet...
HOW TO STOP THIS PRINTER FROM ALIGNING, EVERYTIME I PRINT SOMETHING IT BEGINS THE PROCESS OF ALIGNING PRINTER, PLEASE HELP...
Reset the printer and align it successfully, remove the cartridges, clean the copper contacts with a clean lint free cloth and distilled water and then perform the reset, insert the cartridges when asked by the printer.
reset is below/
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Apr 10, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
R220 printer ink light won't stop blinking and I can't print.
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Feb 20, 2010 | Epson Stylus Photo R220 InkJet Printer
Hp deskjet 882c printer carriage is stuck
Hi first of all you need to make sure that everything is in good shape on the carriage and the cartridge holder,
also check if you have any broken plastic pieces in the printer.
you mentioned the reset a well
was it a partial or a semi full reset
another thing which we can try is
1>take out both the cartridges
2> unplug the power cable while the printer is on
3>press the power button for 30 sec to remove the static
3>replug the power
now let the printer lights blink prompting you to put the cartridges
4>put the black cartridge first
some Hp printers work on single cartridges as well.
5>see if you hear the same grinding noise again
6>try cleaning the rollers with a little damp lint free cloth
7>try putting the color cartridge
make sure that the cartridges snap inside properly.
8>see if the problem persists
Jun 15, 2009 | HP DeskJet 882c InkJet Printer
Replacement Cartridges and Reset Button Orange Led
That usually means that the chip on a re-manufactured cartridges had not been reset properly.
Ensure you removed the little cello strip from bottom side of cartridge.
Try unplugging printer power cord for five minutes, and also re-fitting cartridges.
If that does not work call the company and have them replaced.
Note: for the future, it is better buying always original new cartridge rather than refilled/refurbished ones, as you do not know as many times a refilled had been used. On sporadic occasions refilled cartridges can fail and damage the printer.
Apr 11, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Wrong Printer Cartridge error
have you tried changing the printer mother board i think that could be the problem of your printer
Sep 29, 2008 | HP PSC 1210v All-In-One InkJet Printer
HP Photosmart C4280 All-in-One InkJet Printer Logo
13 people viewed this question
Seeker5211
Seeker5211
